Halo,
sorry I´am a german guy, bad englich sorry :)
OK, i have a problem at first start GameEx.
I have MS MC05, installed mame32.0.99.9 and GameEx V5.07.
I have configured the folders, but I becam the error below.
20:10:36.7 12.09.2005: GameEx: Version 5.07: Starting Log
20:10:36.8 12.09.2005: Operating System Platform: Win32NT
20:10:36.8 12.09.2005: Operating System Name: Windows XP
20:10:36.8 12.09.2005: Operating System Version: 5.1.2600
20:10:36.8 12.09.2005: Checking Registration
20:10:36.8 12.09.2005: Running Randomize()
20:10:36.9 12.09.2005: Initialising Video/MNG DLL's
20:10:37.3 12.09.2005: Running Misc startup tasks
20:10:37.3 12.09.2005: Setting Menu types
20:10:37.3 12.09.2005: Opening Configuration File
20:10:37.3 12.09.2005: Getting Configuration Values
20:10:37.3 12.09.2005: Using Theme: Default - Default
20:10:37.3 12.09.2005: Checking for alternate Image Directory for Theme: Default - Default
20:10:37.3 12.09.2005: Text/Language: German
20:10:37.3 12.09.2005: Applying Language/Text
20:10:37.4 12.09.2005: Creating Scancodes.txt (List of DirectInput scan codes)
20:10:37.4 12.09.2005: Snap Delay set to: 1
20:10:37.4 12.09.2005: Is Media Center running?
20:10:37.4 12.09.2005: Media Center is running
20:10:37.4 12.09.2005: Check Media Center Exit/Start Mode
20:10:37.4 12.09.2005: Media Center Mode 2
20:10:37.4 12.09.2005: Closing Media Center
20:10:42.5 12.09.2005: Checking for applications to Launch On Startup
20:10:42.5 12.09.2005: Get other settings
20:10:42.5 12.09.2005: Using 2D Animations
20:10:42.5 12.09.2005: Launching HideOS.exe
20:10:44.1 12.09.2005: Hiding Taskbar
20:10:44.1 12.09.2005: Start work for Form
20:10:44.1 12.09.2005: Getting Original Screen Size
20:10:44.1 12.09.2005: Loading ICON
20:10:44.1 12.09.2005: Initializing Component
20:10:44.2 12.09.2005: Initialising Bass Audio Library
20:10:44.6 12.09.2005: Loading default loading screen
20:10:44.7 12.09.2005: Using General Font: Trebuchet MS
20:10:44.7 12.09.2005: Using Title Font: Trebuchet MS
20:10:44.7 12.09.2005: Initialising DirectDraw
20:10:44.8 12.09.2005: Creating DirectDraw Device
20:10:44.8 12.09.2005: Setting Resolution to 800x600 32 bit color
20:10:44.8 12.09.2005: Creating DirectDraw Surfaces
20:10:44.8 12.09.2005: Creating Primary Surface - Full Screen Mode
20:10:44.8 12.09.2005: Creating Back Buffer
20:10:44.8 12.09.2005: Loading graphic surfaces
20:10:44.9 12.09.2005: Creating Surfaces Misc and Dialogs
20:10:45.0 12.09.2005: Creating Surface Volume
20:10:45.0 12.09.2005: Creating Surfaces Arrows
20:10:45.1 12.09.2005: Creating Surfaces GameEXlogo Text
20:10:45.1 12.09.2005: Creating Surfaces Toolbar
20:10:45.2 12.09.2005: Creating Surfaces Backgrounds
20:10:46.4 12.09.2005: Creating Surfaces Toolbar Controls
20:10:46.5 12.09.2005: Creating Surfaces GameEx Logo
20:10:46.5 12.09.2005: Could not find file "C:\Programme\GameEx\themes\Default - Default\MEDIA\unselected.bmp".
20:10:49.4 12.09.2005: ERRORS DETECTED: EXITING
But in the Folder are the Image, but all in png not in bmp.
Can I rename all Files ? or what can I do!
BIG THX
Cyberbob
Halo,
BIG THX
Cyberbob
Hi,
No worries, you speak English 10000% better then I speak German ;)
This is simply a bug in version 5.07. Go download the latest version which is currently 5.09.
All the best.
Hi,
All the best.
Supi, big thx, it works!
it works with the new version and when you convert the png files to bmp, I have do it with irfanview.!
Thx
Cyberbob
  • 2 months later...
<_< Hi Tom,
I just installed your latest version - 5.16 - and I'm getting this error. It's looking for bmp files, but all I have are .png files. Could something have crept back in again? Thanks! I look forward to using your software :)
<_ hi tom>
Could you please post the log.
Thanks.
