hiya all,
im having problems with the dvd player feature
ive downloaded and installed fraunhofer dvd codec
this is what is in the list of dvd codecs.
it is installed in C:\program files\fraunhofer
i have a dvd drive, and i go to play dvd option on gameex menu
the screen goes black and then just hops back to the menu....
i get no error, no messages nothing.
any idea's has anyone actually got this dvd feature to work????
also second.
i have znes, ive put it in, all games can be selected, however when it comes to exiting a game with plater 1 and player 2(my excape key) the screen just goes black and the game music still plays and well thats it,,,, i dont get gameex back or anything.
and last problem, the box i have only has 3 buttons per player, for znes does ayone have any ideas for a select key..... i have tried player 1 and 2 but they take out the grathic layers, ive also tried the credit button, but that does the same.
anyway thanks
hiya all,
also second.
anyway thanks
It does not like some DVD Codecs. PowerDVD and WinDVD deffinitly work.
Try setting the MAPKeys to on.
I would not bother trying to run ZSnes on a 3 button cab and dont have any suggestions.
lol okay
i just thought with the dvd codecs been within the config app that they were recommended.
if i install power dvd, how do i change the codec, and where will it be.
thanks
lol okay
thanks
its in the main config tool, then multimedia/htpc the last option is dvd/mpg decoder. it should be in there if its installed on the system,
