Frequency/Gerble, On the other systems speed issue, did the new gameex.exe make any difference? The update was not for the Karakoe issue.
Frequency, you said you have the same issue as Gerble, can you try it?
  • Replies 75
  • Created
  • Last Reply
Top Posters In This Topic
just checking now tom
i have just replaced the gameex,exe with the one you posted,i then loaded gameex,
and went into emulators fine then into snes and it cached for 20 mins,
OUCH
then i rebooted and it was a lot quicker, :D
i have uploaded 4 logs
in order as this
before changed gameex,exe
strait after changed gameex,exe
reboot 1
reboot 2
even the second reboot was quick,still a pause but reasonable :)
hope this helps
before_changed_gameex_exe.txt
strait_after_changed_gameex_exe.txt
reboot_1.txt
reboot_2.txt
OUCH
in order as this
reboot 1
reboot 2
hope this helps
Good, looks like its working.
i just tested 9.61 but still the same prob:
karaoke works in queue mode but nothing happens in instant mode (not even a message in the log)
instant play works in jukebox mode though
:( . Still no love from karaoke!
let's try to make it a bit easier for tom and narrow the bug down...
freq, can you use the queue mode function or is that not working for you either?
Will check now. Log into IM if you can chriss.
Just tried and no luck with the way you suggested. That is of course I did it the right way. I select Queue Mode, select some songs, then click Start Karaoke?
yeah exactly, thats how i did it and it worked for me... so it seems there are two issues with karaoke possibly.
IM is on but didn't receive a message from you yet
  TSpeirs said:
Ive tried to increase performance even further. By the look of your log once cached it looks like about 35 second. The attached should hopefully be quicker.
Can you try it please and post the log?
just trying now,i take it im looking for a quicker reload of saved cache,
its a litttle quicker
here is the log
i just updated to 9.62 but still no luck with instant play and karaoke. now tom i don't wnat to annoy you with this problem...
if there is anything else I could try out, please let me know.
How do I reinstall gameex? Just uninstall completetly, then replace the gameex.ini? or am I missing something then? could this even change anything?
  • 4 weeks later...
  fRequEnCy said:
Yes Tom that was the fix! Figured it out a few days ago. And told Chriss I had a fix for him. I didn't post cuz no one else seemed to be having the issue or was into the karaoke thing. LOL.
Good. Ive set GameEx to turn that off in the registry everytime it launches. So theres not even a need to add a FAQ item now.
Nice. Thanks Tom! I wish we could have figured it out for Chriss a lot sooner since he's the one who really needed it for this karaoke parties.
Hey guys,
i wish i could report success, but i still have the same issue :(
wmp plays cdg files fine but when i try to click on a song in gameex it's not doing anything. a strange thing i noticed... in setup wizard i set gameex to instantly play songs but inside gameex its set to queue mode. anyway queue mode works fine but when i set it to instant play selection inside gameex it does not work
I guess something is wrong with my whole setup... everything else like emulators and radio and so forth works
but when i updated to the newest version i got an error message about a missing hiscore txt file in the gameex data folder. i fixed this issue by creating the file... if there was just a similar easy way to fix karaoke :lol:
  chriss said:
Hey guys,
I had that same problem when updating to the newest version as well. I just did a manual install and it took care of it. Not sure if that will help with your karaoke issue but here's hoping.
