  chriss said:
true... i thought about using other software.... but i gotta control karaoke with the arcade sticks (especially the page function i need)... so i think of installing an old gameex version!
Bummer! Well good luck. Hope you're karaoke jam comes through.
  • Replies 75
  • Created
  • Last Reply
Top Posters In This Topic
19:31:40.3 12.10.2008: GameEx: Version 9.60: Starting Log
19:31:40.3 12.10.2008: Operating System Platform: Win32NT
19:31:40.3 12.10.2008: Operating System Name: Windows XP
19:31:40.3 12.10.2008: Operating System Version: 5.1.2600
19:31:40.3 12.10.2008: Checking for versions of .net Framework installed
19:31:40.3 12.10.2008: .net Framework 2.0 Installed
19:31:40.3 12.10.2008: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+, 1023MB
19:31:40.3 12.10.2008: 2,21Ghz - 2 Cores or CPU's
19:31:40.3 12.10.2008: Running Randomize()
19:31:40.3 12.10.2008: Loading PlugIns
19:31:40.4 12.10.2008: Checking for applications to Launch On Startup
19:31:40.4 12.10.2008: Running Misc startup tasks
19:31:40.4 12.10.2008: Setting Menu types
19:31:40.4 12.10.2008: Opening Configuration File
19:31:40.4 12.10.2008: Getting Configuration Values
19:31:40.4 12.10.2008: Using Theme: Default - Media Center
19:31:40.4 12.10.2008: Checking for alternate Image Directory for Theme: Default - Media Center
19:31:40.4 12.10.2008: Using Images from theme: Default - Media Center V1\MEDIA\
19:31:40.4 12.10.2008: Launching HideOS.exe
19:31:40.4 12.10.2008: Initialising Video/MNG DLL's
19:31:40.4 12.10.2008: Arcade Mode is on
19:31:40.4 12.10.2008: GameEx will check for media insertion (may affect performance)
19:31:40.4 12.10.2008: Hiding Taskbar
19:31:40.4 12.10.2008: Using Cabinet Friendly Control System
19:31:40.4 12.10.2008: Is Media Center running?
19:31:40.4 12.10.2008: Checking/Creating LCD Registry values
19:31:40.4 12.10.2008: Check Media Center Exit/Start Mode
19:31:40.4 12.10.2008: Media Center Mode 2
19:31:40.4 12.10.2008: Video previews on. Warning: Only recommended on modern systems
19:31:40.4 12.10.2008: Custom Keyboard Input enabled: Getting custom codes
19:31:40.4 12.10.2008: Snap Delay set to: 6
19:31:40.4 12.10.2008: Get other settings
19:31:40.4 12.10.2008: Mouse Input is disabled
19:31:40.4 12.10.2008: Set: Find emulator artwork on best match basis
19:31:40.4 12.10.2008: Using DirectInput for keyboard input
19:31:40.4 12.10.2008: Start work for Form
19:31:40.4 12.10.2008: Getting Original Screen Size
19:31:40.4 12.10.2008: Opening Database Connection
19:31:40.5 12.10.2008: Initializing Component
19:31:40.5 12.10.2008: Retrieving resolution setting
19:31:40.5 12.10.2008: Initialising Windows Media Player Component
19:31:40.5 12.10.2008: MAME Path is: D:\Games\mame
19:31:40.5 12.10.2008: daphne Path is: D:\Games\DaphneLD
19:31:40.5 12.10.2008: daphne EXE file is: daphne.exe
19:31:40.5 12.10.2008: Use daphne on. daphne.exe will launch games
19:31:40.5 12.10.2008: ZiNc Path is: D:\Games\mame
19:31:40.5 12.10.2008: ZiNc EXE file is: zinc.exe
19:31:40.5 12.10.2008: Use ZiNc on. zinc.exe will launch PSX games
19:31:40.5 12.10.2008: MAME EXE file is: mamep.exe
19:31:40.5 12.10.2008: ROM Path is: D:\Games\mame\roms
19:31:40.5 12.10.2008: Catver.ini is located at: C:\Programme\GameEx\DATA\catver.ini
19:31:40.5 12.10.2008: controls.ini is located at: C:\Programme\GameEx\data\controls.ini
19:31:40.5 12.10.2008: History.dat is located at: C:\Programme\GameEx\DATA\history.dat
19:31:40.6 12.10.2008: nplayers.ini is located at: C:\Programme\GameEx\DATA\nplayers.ini
19:31:40.6 12.10.2008: MAMEinfo.dat is located at: C:\Programme\GameEx\DATA\mameinfo.dat
19:31:40.6 12.10.2008: Loading Controls.ini map file
19:31:40.6 12.10.2008: Snap Path is: D:\Games\mame\snap
19:31:40.6 12.10.2008: AVI Snap Path is: D:\Games\mame\avisnap
19:31:40.6 12.10.2008: Flyer Path is: D:\Games\mame\flyers
19:31:40.6 12.10.2008: Cabinet Path is: D:\Games\mame\cabinets
19:31:40.6 12.10.2008: Title Path is: D:\Games\mame\titles
19:31:40.6 12.10.2008: PCB Path is: D:\Games\mame\pcb
19:31:40.6 12.10.2008: Artwork Preview Path is: D:\Games\mame\artwork
19:31:40.6 12.10.2008: Panel Path is: D:\Games\mame\cpanel
19:31:40.6 12.10.2008: Manual Path: Not Found
19:31:40.6 12.10.2008: Icon Path is: D:\Games\mame\icons
19:31:40.6 12.10.2008: Marquee Path is: D:\Games\mame\marquees
19:31:40.6 12.10.2008: Loading Custom Emulators
19:31:40.6 12.10.2008: Loading Emulator 1: Nintendo SNES
19:31:40.6 12.10.2008: Loading Emulator 3: Nintendo NES
19:31:40.7 12.10.2008: Loading Emulator 4: Nintendo N64
19:31:40.7 12.10.2008: Loading Emulator 5: Sega Dreamcast
19:31:40.7 12.10.2008: Loading Emulator 6: Sega Naomi
19:31:40.8 12.10.2008: Loading Emulator 7: Sega Mega Drive
19:31:40.8 12.10.2008: Loading Emulator 8: Sega Master System
19:31:40.9 12.10.2008: Loading Emulator 9: Sony PlayStation
19:31:40.9 12.10.2008: Loading Emulator 10: Sony PlayStation Better 3D
19:31:41.0 12.10.2008: Loading Emulator 11: Commodore Amiga
19:31:41.0 12.10.2008: Loading Emulator 12: Commodore 64
19:31:41.1 12.10.2008: Loading Emulator 14: Atari ST
19:31:41.1 12.10.2008: Loading Emulator 15: Pinball
19:31:41.2 12.10.2008: Loading Emulator 16: PC Games
19:31:41.4 12.10.2008: Using Version 3 Themes Animations
19:31:41.4 12.10.2008: Using General Font: Verdana
19:31:41.4 12.10.2008: Using Title Font: Verdana
19:31:41.4 12.10.2008: Attempting to load game list
19:31:41.6 12.10.2008: Initialising DirectDraw
19:31:41.6 12.10.2008: Applying GameEx is Loading Image
19:31:44.0 12.10.2008: Creating DirectDraw Device
19:31:44.0 12.10.2008: Using Device: ATI Radeon 9600/9550/X1050 Series
19:31:44.1 12.10.2008: 120mb video memory available
19:31:44.1 12.10.2008: Setting Resolution to 1024x768 32 bit color
19:31:44.1 12.10.2008: Creating DirectDraw Surfaces
19:31:44.1 12.10.2008: Creating Primary Surface - Full Screen Mode
19:31:44.2 12.10.2008: Creating Back Buffer
19:31:44.2 12.10.2008: Loading graphic Surfaces
19:31:44.2 12.10.2008: Display is running at: 1024x768 32bit color, 85hz
19:31:44.3 12.10.2008: Creating Surfaces Flags
19:31:44.3 12.10.2008: Creating Surfaces Misc and Dialogs
19:31:44.3 12.10.2008: Creating Surfaces Volume
19:31:44.3 12.10.2008: Creating Surfaces Arrows
19:31:44.3 12.10.2008: Creating Surfaces GameEXlogo Text
19:31:44.3 12.10.2008: Creating Surfaces Toolbar
19:31:44.3 12.10.2008: Creating Surfaces Backgrounds
19:31:44.5 12.10.2008: Creating Surfaces Toolbar Controls
19:31:44.6 12.10.2008: Creating Surfaces GameEx Logo
19:31:44.6 12.10.2008: Creating Surface Unselected
19:31:44.6 12.10.2008: Creating Surfaces Home & Exit
19:31:44.6 12.10.2008: Creating Surfaces Snaps
19:31:44.6 12.10.2008: Creating Surfaces Menu and List Bars
19:31:44.6 12.10.2008: Creating Fonts
19:31:44.6 12.10.2008: Creating Game Font
19:31:45.0 12.10.2008: Creating Game Font Faded
19:31:45.6 12.10.2008: Creating Title Font
19:31:45.6 12.10.2008: Restoring Title Font From Cache
19:31:45.7 12.10.2008: Creating Font Black
19:31:45.9 12.10.2008: Creating Font Black Small
19:31:46.0 12.10.2008: Fonts Created Succesfully
19:31:46.0 12.10.2008: 62mb video memory left available
19:31:46.0 12.10.2008: Creating instance of global keyboard hook
19:31:46.0 12.10.2008: Playing Startup Video on thread
19:31:46.0 12.10.2008: Text/Language: Custom
19:31:46.0 12.10.2008: Applying Language/Text
19:31:46.2 12.10.2008: Initialising Bass Audio Library
19:31:46.3 12.10.2008: MAME CMD options:
19:31:46.3 12.10.2008: Loading last used Game List
19:31:46.4 12.10.2008: Loading Start Page
19:31:46.5 12.10.2008: Setting Music Volume
19:31:46.5 12.10.2008: Loading music
19:31:46.8 12.10.2008: Sound Disabled
19:31:46.8 12.10.2008: Creating ICONS
19:31:46.8 12.10.2008: Restoring Cached ICONS from File
19:31:47.0 12.10.2008: Gamepad/Joystick disabled
19:31:47.0 12.10.2008: Initialising DirectInput for Keyboard support
19:31:47.0 12.10.2008: Initializing MCE Remote
19:31:47.0 12.10.2008: Initialization OK! Starting GameEx!
19:31:47.1 12.10.2008: Testing Main Loop Once: Processing Frame
19:31:47.5 12.10.2008: Testing Main Loop Once: Main Loop ran successfully
19:31:59.2 12.10.2008: No Karaoke Cache, scanning files
I just updated to the newest version, i reinstalled the karaoke dx plugin and changed the karaoke folder with only a few karaoke songs in it... no change! gameex still won't do anything if i click on a song! even the log doesn't record any action... wmp plays the cdgs fine.
any other suggestions? can i somehow reset the karaoke settings?
im not using karaoke
but i got a problem
i just updated gameex from 49 to 60
and now when i go into any game emulator and click a game u would usually get the page that says
click play to start (or something)
but it takes about 10 mins for that to appear,
i tried 2 restarts and checked to see if i changed anything,wich i didnt,
any ideas on that one
p,s
i do get the scrolling bar whilst waiting
and i just realised that it only does it once,
like it caches all the games for about 10 mins then its ok
still id like to turn that caching down or off if thats the problem
but i got a problem
p,s
With this release i forced it do it once only recache for the other systems feature. It won't do that again. I meant to put it into the release notes but forgot.
It should be quicker after restarts though unless theres some problem. You can turn it off by turning off the other systems feature. You must have hundreds of emulators setup if its taken a long time every time?
  TSpeirs said:
By the way, please start a new topic next time.
no probs,
and yea i am using about 25 emulators,
and i love the other systems feature,
is there anyway to cach at startup and not when i acctually look for a game
cheers
  gerble1000 said:
no probs,
cheers
I want to double check it not a bug first. Can you be very specific and honest about how long it taking and your system specs. Did it take an even longer time the first time you ran this version. It should have done. It really shouldnt take 10 minutes every restart of GameEx.
im just going to double check now,
i probably exajurated a bit,
but its way noticable as usually it is within 2 seconds
ok i just done a test
i did exajurate a little,lol
gameex started up as normal
and when i went into the emulators all is ok but when i click a game it takes exactly 2 mins and 35 secs
to bring up the play this game page,
p,s
my specs are as follows
geforce 6500
1gb ram
pentium 4 3,0ghz hyperthread
and i have 27 emulators plus mame
i got 46810 games in total (you could do with making a little counter at the start of gameex :P )
p,s
geforce 6500
1gb ram
Can you post your gameex log after loading up game info for a game. Cheers.
  chriss said:
uh oh tomorrow is our karaoke party and i still haven't fixed it.... anything new on this topic?
Chriss, I didnt think it would be something as simple as this, as you said youd tried "everything", but if clicking on a song does absolutely nothing then it sounds like you have Karaoke in Queue mode instead of instant play mode, perhaps? Just click the menu item.
Still not working for me either Tom! In the Karaoke Settings I have Play Mode: Click to play any Song. It just goes to a black screen and then comes back with still the same thing I posted in the log. Now I also went to the Audio Settings and changed from JukeBox Queue Mode: Clicking songs queues them to Clicking songs instantly plays and got a different result. No switch to black screen but doesn't give any errors in the log.
yo tom, thanks for helping me figure this out... i don't think it would be as simple as changing from queue mode to instant play. i got these settings right..
but i experience hd failures lately (chkdsk had to fix index structures twice in a week) so I'm not feeling this sure of my setup in general... though all emulators and video playback work in gameex... but i think of setting up my system again, maybe 64bit this time.. I'm pretty sure this will fix the error, sicne it still seems to work for others besides frequency and me!
since we both have big collections i reckon it could have something to do with the sheer size of files gameex has to process (21 gb in my case). I saw the karaoke chache file in the gameex data folder, so maybe this file got corrupted. is it safe to delete this? I'm a bit clueless about what's going on...
But setting up the system again will hopefully fix this error
i will report back
but i experience hd failures lately (chkdsk had to fix index structures twice in a week) so I'm not feeling this sure of my setup in general... though all emulators and video playback work in gameex... but i think of setting up my system again, maybe 64bit this time.. I'm pretty sure this yould fix the error, sicne it still seems to work for others besides frequency and me!
since we both have big collections i reckon it could have something to do with the sheer size of files gameex has to process (21 gb in my case). on the other hand changing the karaoke folde rwith only 10 songs in it didn't fix the error. I'm a bit clueless about what's going on...
i will report back
I tested with a small folder as well. Again I don't use GameEx for karaoke but tested for chriss to verify he wasn't the only one having problems. I did have it working at one time but now no longer works. I even did a manual install in hopes it would fix it and even deleted the KaraokeData.dat and KaraokeFiles.dat but no luck. :(
No HD failures for me chriss! I even tried putting on different HD's and was unsuccessful. I tried 5 different ones. It's gotta be a setting or something that is conflicting. Cuz as I posted earlier when I switched setting for JukeBox mode I got no errors but still didn't work.
thanks for checking this out frequency... I appreciate your help!
I hope tom is getting an idea about what causes this error. :unsure:
No problem! I'll keep playing around with settings to see if I get any results cuz looks like you and I are the only ones with this problem. Or maybe the only ones who are into karaoke. ;)
here you go m8,
it says something about not caching <_<,
i have also tried booting up gameex then leaving it till attract mode,
and after that it works fine,
dunno if that helps
i also experienced longer load times before games were starting actually... but i think it was only once and after that the games started right away
  gerble1000 said:
here you go m8,
dunno if that helps
I'm experiencing the same thing gerble1000. You're not the only one. ;)
Since you're still dealing with this then you should start a new topic so it can get noticed more. Also maybe can ask a Mod to move things over for ya so it's not hidden here in the karaoke section. Not many people always read everything that's posted and especially if it has karaoke in the title. Chriss and I have learned that as of late. LOL.
if u can move this conversation to a new topic (be my guest)
im glad it aint just my computer :rolleyes:
Nope not just you! ;)
I would move If I could but I'm not a Mod! Hopefully one will jump in and see and maybe move it for you.
I think the issue is that databases are selected for emulators but no matches are found, and GameEx is scanning again. Hence why its saying not restoring from cache.
Can you try the GameEx.exe in this post:
http://www.gameex.info/forums/index.php?sh...amp;#entry47005
Go through the motions, it will recache everything initially and that will take a while. Then hoepfully there should be an improvement on next restart. Post the log again after its done all that.
Let me know.
ok an update!
i got it working ... kind of...
instant play mode is still not working but when i click on queue mode and then select some songs, then click on the start karaoke button the songs will play!
i just installed the gameex.exe that tom was referring to in the previous post so I don't know if it has something to do with this!
but at least its working for now!
yey!
15:20:19.4  15.10.2008:  GameEx: Version 9.60: Starting Log
15:20:19.4 15.10.2008: Operating System Platform: Win32NT
15:20:19.4 15.10.2008: Operating System Name: Windows XP
15:20:19.4 15.10.2008: Operating System Version: 5.1.2600
15:20:19.4 15.10.2008: Checking for versions of .net Framework installed
15:20:19.4 15.10.2008: .net Framework 2.0 Installed
15:20:19.4 15.10.2008: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+, 1023MB
15:20:19.4 15.10.2008: 2,21Ghz - 2 Cores or CPU's
15:20:19.4 15.10.2008: Running Randomize()
15:20:19.4 15.10.2008: Loading PlugIns
15:20:19.4 15.10.2008: Checking for applications to Launch On Startup
15:20:19.4 15.10.2008: Running Misc startup tasks
15:20:19.4 15.10.2008: Setting Menu types
15:20:19.4 15.10.2008: Opening Configuration File
15:20:19.4 15.10.2008: Getting Configuration Values
15:20:19.4 15.10.2008: Using Theme: Default - Media Center
15:20:19.4 15.10.2008: Checking for alternate Image Directory for Theme: Default - Media Center
15:20:19.5 15.10.2008: Using Images from theme: Default - Media Center V1\MEDIA\
15:20:19.5 15.10.2008: Launching HideOS.exe
15:20:19.5 15.10.2008: Initialising Video/MNG DLL's
15:20:19.5 15.10.2008: Arcade Mode is on
15:20:19.5 15.10.2008: GameEx will check for media insertion (may affect performance)
15:20:19.5 15.10.2008: Hiding Taskbar
15:20:19.5 15.10.2008: Using Cabinet Friendly Control System
15:20:19.5 15.10.2008: Is Media Center running?
15:20:19.5 15.10.2008: Checking/Creating LCD Registry values
15:20:19.5 15.10.2008: Check Media Center Exit/Start Mode
15:20:19.5 15.10.2008: Media Center Mode 2
15:20:19.5 15.10.2008: Video previews on. Warning: Only recommended on modern systems
15:20:19.5 15.10.2008: Custom Keyboard Input enabled: Getting custom codes
15:20:19.5 15.10.2008: Snap Delay set to: 6
15:20:19.5 15.10.2008: Get other settings
15:20:19.5 15.10.2008: Mouse Input is disabled
15:20:19.5 15.10.2008: Set: Find emulator artwork on best match basis
15:20:19.5 15.10.2008: Using DirectInput for keyboard input
15:20:19.5 15.10.2008: Start work for Form
15:20:19.5 15.10.2008: Getting Original Screen Size
15:20:19.6 15.10.2008: Opening Database Connection
15:20:19.6 15.10.2008: Initializing Component
15:20:19.6 15.10.2008: Retrieving resolution setting
15:20:19.7 15.10.2008: Initialising Windows Media Player Component
15:20:19.7 15.10.2008: MAME Path is: D:\Games\mame
15:20:19.7 15.10.2008: daphne Path is: D:\Games\DaphneLD
15:20:19.7 15.10.2008: daphne EXE file is: daphne.exe
15:20:19.7 15.10.2008: Use daphne on. daphne.exe will launch games
15:20:19.7 15.10.2008: ZiNc Path is: D:\Games\mame
15:20:19.7 15.10.2008: ZiNc EXE file is: zinc.exe
15:20:19.7 15.10.2008: Use ZiNc on. zinc.exe will launch PSX games
15:20:19.7 15.10.2008: MAME EXE file is: mamep.exe
15:20:19.7 15.10.2008: ROM Path is: D:\Games\mame\roms
15:20:19.7 15.10.2008: Catver.ini is located at: C:\Programme\GameEx\DATA\catver.ini
15:20:19.7 15.10.2008: controls.ini is located at: C:\Programme\GameEx\data\controls.ini
15:20:19.7 15.10.2008: History.dat is located at: C:\Programme\GameEx\DATA\history.dat
15:20:19.7 15.10.2008: nplayers.ini is located at: C:\Programme\GameEx\DATA\nplayers.ini
15:20:19.7 15.10.2008: MAMEinfo.dat is located at: C:\Programme\GameEx\DATA\mameinfo.dat
15:20:19.7 15.10.2008: Loading Controls.ini map file
15:20:19.7 15.10.2008: Snap Path is: D:\Games\mame\snap
15:20:19.7 15.10.2008: AVI Snap Path is: D:\Games\mame\avisnap
15:20:19.7 15.10.2008: Flyer Path is: D:\Games\mame\flyers
15:20:19.7 15.10.2008: Cabinet Path is: D:\Games\mame\cabinets
15:20:19.7 15.10.2008: Title Path is: D:\Games\mame\titles
15:20:19.7 15.10.2008: PCB Path is: D:\Games\mame\pcb
15:20:19.7 15.10.2008: Artwork Preview Path is: D:\Games\mame\artwork
15:20:19.7 15.10.2008: Panel Path is: D:\Games\mame\cpanel
15:20:19.7 15.10.2008: Manual Path: Not Found
15:20:19.7 15.10.2008: Icon Path is: D:\Games\mame\icons
15:20:19.7 15.10.2008: Marquee Path is: D:\Games\mame\marquees
15:20:19.7 15.10.2008: Loading Custom Emulators
15:20:19.7 15.10.2008: Loading Emulator 1: Nintendo SNES
15:20:19.7 15.10.2008: Loading Emulator 3: Nintendo NES
15:20:19.8 15.10.2008: Loading Emulator 4: Nintendo N64
15:20:19.8 15.10.2008: Loading Emulator 5: Sega Dreamcast
15:20:19.9 15.10.2008: Loading Emulator 6: Sega Naomi
15:20:19.9 15.10.2008: Loading Emulator 7: Sega Mega Drive
15:20:20.0 15.10.2008: Loading Emulator 8: Sega Master System
15:20:20.0 15.10.2008: Loading Emulator 9: Sony PlayStation
15:20:20.1 15.10.2008: Loading Emulator 10: Sony PlayStation Better 3D
15:20:20.1 15.10.2008: Loading Emulator 11: Commodore Amiga
15:20:20.1 15.10.2008: Loading Emulator 12: Commodore 64
15:20:20.2 15.10.2008: Loading Emulator 14: Atari ST
15:20:20.2 15.10.2008: Loading Emulator 15: Pinball
15:20:20.3 15.10.2008: Loading Emulator 16: PC Games
15:20:20.5 15.10.2008: Using Version 3 Themes Animations
15:20:20.5 15.10.2008: Using General Font: Verdana
15:20:20.5 15.10.2008: Using Title Font: Verdana
15:20:20.5 15.10.2008: Attempting to load game list
15:20:20.7 15.10.2008: Initialising DirectDraw
15:20:20.8 15.10.2008: Applying GameEx is Loading Image
15:20:20.8 15.10.2008: Creating DirectDraw Device
15:20:20.8 15.10.2008: Using Device: ATI Radeon 9600/9550/X1050 Series
15:20:20.9 15.10.2008: 120mb video memory available
15:20:21.0 15.10.2008: Setting Resolution to 1024x768 32 bit color
15:20:21.0 15.10.2008: Creating DirectDraw Surfaces
15:20:21.0 15.10.2008: Creating Primary Surface - Full Screen Mode
15:20:21.0 15.10.2008: Creating Back Buffer
15:20:21.1 15.10.2008: Loading graphic Surfaces
15:20:21.1 15.10.2008: Display is running at: 1024x768 32bit color, 85hz
15:20:21.2 15.10.2008: Creating Surfaces Flags
15:20:21.3 15.10.2008: Creating Surfaces Misc and Dialogs
15:20:21.3 15.10.2008: Creating Surfaces Volume
15:20:21.3 15.10.2008: Creating Surfaces Arrows
15:20:21.3 15.10.2008: Creating Surfaces GameEXlogo Text
15:20:21.3 15.10.2008: Creating Surfaces Toolbar
15:20:21.3 15.10.2008: Creating Surfaces Backgrounds
15:20:21.6 15.10.2008: Creating Surfaces Toolbar Controls
15:20:21.6 15.10.2008: Creating Surfaces GameEx Logo
15:20:21.6 15.10.2008: Creating Surface Unselected
15:20:21.6 15.10.2008: Creating Surfaces Home & Exit
15:20:21.6 15.10.2008: Creating Surfaces Snaps
15:20:21.6 15.10.2008: Creating Surfaces Menu and List Bars
15:20:21.7 15.10.2008: Creating Fonts
15:20:21.7 15.10.2008: Creating Game Font
15:20:22.0 15.10.2008: Creating Game Font Faded
15:20:22.6 15.10.2008: Creating Title Font
15:20:22.6 15.10.2008: Restoring Title Font From Cache
15:20:22.7 15.10.2008: Creating Font Black
15:20:22.9 15.10.2008: Creating Font Black Small
15:20:23.0 15.10.2008: Fonts Created Succesfully
15:20:23.0 15.10.2008: 62mb video memory left available
15:20:23.0 15.10.2008: Creating instance of global keyboard hook
15:20:23.0 15.10.2008: Playing Startup Video on thread
15:20:23.1 15.10.2008: Text/Language: Custom
15:20:23.1 15.10.2008: Applying Language/Text
15:20:23.2 15.10.2008: Initialising Bass Audio Library
15:20:23.4 15.10.2008: MAME CMD options:
15:20:23.4 15.10.2008: Loading last used Game List
15:20:23.5 15.10.2008: Loading Start Page
15:20:23.6 15.10.2008: Setting Music Volume
15:20:23.6 15.10.2008: Playing Station: [url="http://www.dradio.de/streaming/dkultur.asx"]http://www.dradio.de/streaming/dkultur.asx[/url]
15:20:23.6 15.10.2008: Loading music
15:20:23.9 15.10.2008: Sound Disabled
15:20:23.9 15.10.2008: Creating ICONS
15:20:23.9 15.10.2008: Restoring Cached ICONS from File
15:20:24.1 15.10.2008: Gamepad/Joystick disabled
15:20:24.1 15.10.2008: Initialising DirectInput for Keyboard support
15:20:24.1 15.10.2008: Initializing MCE Remote
15:20:24.2 15.10.2008: Initialization OK! Starting GameEx!
15:20:24.2 15.10.2008: Testing Main Loop Once: Processing Frame
15:20:24.7 15.10.2008: Testing Main Loop Once: Main Loop ran successfully
15:21:10.6 15.10.2008: No Karaoke Cache, scanning files
15:24:16.6 15.10.2008: Open Karaoke: D:\karaoke\( Hans Albers - Auf der Reeperbahn Nachts um .......cdg
15:24:18.3 15.10.2008: Playing Karaoke: D:\karaoke\( Hans Albers - Auf der Reeperbahn Nachts um .......cdg
