hey guys,
does anyone else experience that? when i go into my karaoke library i see all the songs listed as usual but no song starts playing. nothing happens on selection...
i tried all sort of things but nothing seems to work...
is this just my setup or is that maybe an overseen bug in the new version?
  • Replies 75
  • Created
  • Last Reply
Top Posters In This Topic
Just tested and not working on this end either. Was workin before. But don't know when it stopped workin since don't use GameEx for karaoke. :(
ok good to know, thanks for having a look frequency!
so it's not just my setup!
theres a karaoke party comin up at my place because 2 buddys just finished uni.
Urgent call to tom, can you fix that easily? or provide me a link to an older version... can i even install an older version over the newer?
Working fine for me. In the last release I added support for an exernal video player. I would check this is not turned on.
weird...
i made an update after karaoke wasn't working
so it seems the problem was not only in the latest version. i will keep trying out things...
  chriss said:
weird...
Does the log show anything? Post it.
Here's my log Tom! I marked the section in red bold letters where it seems to be happening for easy reference. ;)
11:22:28.4 10/9/2008: GameEx: Version 9.58: Starting Log
11:22:28.5 10/9/2008: Operating System Platform: Win32NT
11:22:28.5 10/9/2008: Operating System Name: Windows XP
11:22:28.5 10/9/2008: Operating System Version: 5.1.2600
11:22:28.5 10/9/2008: Checking for versions of .net Framework installed
11:22:28.5 10/9/2008: .net Framework 1.1 Installed
11:22:28.5 10/9/2008: .net Framework 2.0 Installed
11:22:28.6 10/9/2008: Intel® Pentium® 4 CPU 3.00GHz, 3070MB
11:22:28.6 10/9/2008: 2.99Ghz - 2 Cores or CPU's
11:22:28.7 10/9/2008: Running Randomize()
11:22:28.8 10/9/2008: Loading PlugIns
11:22:29.2 10/9/2008: Checking for applications to Launch On Startup
11:22:29.3 10/9/2008: Running Misc startup tasks
11:22:29.3 10/9/2008: Setting Menu types
11:22:29.3 10/9/2008: Opening Configuration File
11:22:29.3 10/9/2008: Getting Configuration Values
11:22:29.4 10/9/2008: Using Theme: Default - MCE Glossy V3
11:22:29.5 10/9/2008: Checking for alternate Image Directory for Theme: Default - MCE Glossy V3
11:22:29.5 10/9/2008: Using Images from theme: Default - MCE Glossy\MEDIA\
11:22:29.6 10/9/2008: Launching HideOS.exe
11:22:29.7 10/9/2008: Initialising Video/MNG DLL's
11:22:30.1 10/9/2008: GameEx will check for media insertion (may affect performance)
11:22:30.1 10/9/2008: Hiding Taskbar
11:22:30.1 10/9/2008: Is Media Center running?
11:22:30.1 10/9/2008: Checking/Creating LCD Registry values
11:22:30.1 10/9/2008: Check Media Center Exit/Start Mode
11:22:30.1 10/9/2008: Media Center Mode 2
11:22:30.1 10/9/2008: Video previews on. Warning: Only recommended on modern systems
11:22:30.2 10/9/2008: Snap Delay set to: 2
11:22:30.2 10/9/2008: Get other settings
11:22:30.2 10/9/2008: Start work for Form
11:22:30.2 10/9/2008: Getting Original Screen Size
11:22:30.2 10/9/2008: Opening Database Connection
11:22:32.4 10/9/2008: Initializing Component
11:22:32.5 10/9/2008: Retrieving resolution setting
11:22:32.6 10/9/2008: Initialising Windows Media Player Component
11:22:33.0 10/9/2008: MAME Path is: C:\Emulators\MAME
11:22:33.0 10/9/2008: daphne Path is: C:\Emulators\Daphne
11:22:33.0 10/9/2008: daphne EXE file is: Daphne.exe
11:22:33.0 10/9/2008: Use daphne on. Daphne.exe will launch games
11:22:33.0 10/9/2008: Model 2 Path Path is: C:\Emulators\Model2
11:22:33.0 10/9/2008: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
11:22:33.1 10/9/2008: Not Found. Looking for emulator.exe
11:22:33.1 10/9/2008: Model 2 EXE file is: emulator.exe
11:22:33.1 10/9/2008: Model 2 emulator with command line support detected
11:22:33.1 10/9/2008: Use Model 2 on. emulator.exe will launch Sega Model 2 games
11:22:33.1 10/9/2008: ZiNc Path is: C:\Emulators\ZiNc
11:22:33.1 10/9/2008: ZiNc EXE file is: zinc.exe
11:22:33.1 10/9/2008: Use ZiNc on. zinc.exe will launch PSX games
11:22:33.1 10/9/2008: MAME EXE file is: mame.exe
11:22:33.2 10/9/2008: ROM Paths are: D:\Romsets\Arcade\MAME\MAME ROMs;D:\Romsets\Arcade\MAME\MAME CHDs
11:22:33.2 10/9/2008: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
11:22:33.2 10/9/2008: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
11:22:33.2 10/9/2008: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
11:22:33.2 10/9/2008: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
11:22:33.2 10/9/2008: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
11:22:33.3 10/9/2008: Loading Controls.ini map file
11:22:33.4 10/9/2008: Snap Path is: D:\Romsets\Art & Sound\MAME - Extras (Core)\snap
11:22:33.4 10/9/2008: AVI Snap Path: Not Found
11:22:33.4 10/9/2008: Flyer Path is: D:\Romsets\Art & Sound\MAME - Extras (Core)\flyers
11:22:33.4 10/9/2008: Cabinet Path is: D:\Romsets\Art & Sound\MAME - Extras (Core)\cabinets
11:22:33.4 10/9/2008: Title Path is: D:\Romsets\Art & Sound\MAME - Extras (Core)\titles
11:22:33.4 10/9/2008: PCB Path is: D:\Romsets\Art & Sound\MAME - Extras (Core)\pcb
11:22:33.4 10/9/2008: Artwork Preview Path: Not Found
11:22:33.4 10/9/2008: Panel Path is: D:\Romsets\Art & Sound\MAME - Extras (Core)\cpanel
11:22:33.5 10/9/2008: Manual Path: Not Found
11:22:33.5 10/9/2008: Icon Path is: C:\Emulators\MAME\icons
11:22:33.5 10/9/2008: Marquee Path is: D:\Romsets\Art & Sound\MAME - Extras (Core)\marquees
11:22:33.5 10/9/2008: Loading Custom Emulators
11:22:33.5 10/9/2008: Loading Emulator 1: [Arcade] AAE
11:22:33.7 10/9/2008: Loading Emulator 2: [Arcade] Final Burn Alpha
11:22:33.9 10/9/2008: Loading Emulator 3: [Arcade] Final Burn Evolution
11:22:34.0 10/9/2008: Loading Emulator 4: [Arcade] Nebula
11:22:34.1 10/9/2008: Loading Emulator 5: [Arcade] Raine
11:22:34.3 10/9/2008: Loading Emulator 6: [Arcade] Sega Naomi
11:22:34.4 10/9/2008: Loading Emulator 7: [Arcade] Vivanonno
11:22:34.6 10/9/2008: Loading Emulator 8: [Arcade] WinKawaks
11:22:34.7 10/9/2008: Loading Emulator 9: [Arcade] ZiNc
11:22:34.9 10/9/2008: Loading Emulator 10: [Console] Atari 2600 (Stella)
11:22:35.0 10/9/2008: Loading Emulator 11: [Console] Atari 5200 (MESS)
11:22:35.2 10/9/2008: Loading Emulator 12: [Console] Atari 7800 (MESS)
11:22:35.3 10/9/2008: Loading Emulator 13: [Console] Atari Jaguar (Virtual Jaguar)
11:22:35.4 10/9/2008: Loading Emulator 14: [Console] Bally Astrocade (MESS)
11:22:35.5 10/9/2008: Loading Emulator 15: [Console] Coleco Vision (blueMSX)
11:22:35.7 10/9/2008: Loading Emulator 17: [Console] Fairchild Channel F (MESS)
11:22:35.8 10/9/2008: Loading Emulator 18: [Console] GCE Vectrex (MESS)
11:22:35.9 10/9/2008: Loading Emulator 19: [Console] Magnavox Odyssey 2 (O2EM)
11:22:36.1 10/9/2008: Loading Emulator 21: [Console] NEC SuperGrafx (Mednafen)
11:22:36.2 10/9/2008: Loading Emulator 22: [Console] NEC TurboGrafx 16 (MagicEngine)
11:22:36.3 10/9/2008: Loading Emulator 23: [Console] Nintendo N64 (Project64)
11:22:36.5 10/9/2008: Loading Emulator 24: [Console] Nintendo NES (NEStopia)
11:22:36.6 10/9/2008: Loading Emulator 25: [Console] Nintendo SNES (ZSNES)
11:22:36.8 10/9/2008: Loading Emulator 26: [Console] Philips Videopac+
11:22:36.9 10/9/2008: Loading Emulator 27: [Console] Sega 32x (Fusion)
11:22:37.1 10/9/2008: Loading Emulator 29: [Console] Sega Genesis (Fusion)
11:22:37.2 10/9/2008: Loading Emulator 30: [Console] Sega Master System (Fusion)
11:22:37.3 10/9/2008: Loading Emulator 32: [Console] SNK Neo-Geo (Nebula)
11:22:37.5 10/9/2008: Loading Emulator 33: [Console] Sony PlayStation (ePSXe)
11:22:37.6 10/9/2008: Loading Emulator 34: [Console] Vtech Creativision (MESS)
11:22:37.8 10/9/2008: Loading Emulator 35: [HandHeld] Atari Lynx (Mednafen)
11:22:37.9 10/9/2008: Loading Emulator 36: [HandHeld] Bandai Wonderswan (Mednafen)
11:22:38.1 10/9/2008: Loading Emulator 37: [HandHeld] Bandai Wonderswan Color (Mednafen)
11:22:38.2 10/9/2008: Loading Emulator 38: [HandHeld] Nintendo DS (No$GBA)
11:22:38.4 10/9/2008: Loading Emulator 39: [HandHeld] Nintendo GameBoy (VBA)
11:22:38.5 10/9/2008: Loading Emulator 40: [HandHeld] Nintendo GameBoy Advance (VBA)
11:22:38.7 10/9/2008: Loading Emulator 41: [HandHeld] Nintendo GameBoy Color (VBA)
11:22:38.8 10/9/2008: Loading Emulator 42: [HandHeld] Nintendo Virtual Boy (Reality Boy)
11:22:39.0 10/9/2008: Loading Emulator 43: [HandHeld] Sega Game Gear (Fusion)
11:22:39.1 10/9/2008: Loading Emulator 44: [HandHeld] SNK Neo Geo Pocket (Mednafen)
11:22:39.2 10/9/2008: Loading Emulator 45: [HandHeld] SNK Neo Geo Pocket Color (Mednafen)
11:22:39.4 10/9/2008: Loading Emulator 46: [Handheld] Watara Supervision (MESS)
11:22:39.5 10/9/2008: Loading Emulator 47: [PC] Apple IIc (MESS)
11:22:39.7 10/9/2008: Loading Emulator 49: [PC] Microsoft MSX (blueMSX)
11:22:39.8 10/9/2008: Loading Emulator 50: [PC] Microsoft MSX2 (blueMSX)
11:22:39.9 10/9/2008: Loading Emulator 52: [Pinball] Future Pinball
11:22:40.5 10/9/2008: Using Version 3 Themes Animations
11:22:40.5 10/9/2008: Using General Font: Trebuchet MS
11:22:40.5 10/9/2008: Using Title Font: Trebuchet MS
11:22:40.5 10/9/2008: Attempting to load game list
11:22:42.1 10/9/2008: Initialising DirectDraw
11:22:42.3 10/9/2008: Applying GameEx is Loading Image
11:22:42.5 10/9/2008: Creating DirectDraw Device
11:22:42.5 10/9/2008: Using Device: RADEON X300 Series
11:22:42.8 10/9/2008: 630mb video memory available
11:22:43.0 10/9/2008: Setting Resolution to 1024x768 32 bit color
11:22:43.0 10/9/2008: Creating DirectDraw Surfaces
11:22:43.0 10/9/2008: Creating Primary Surface - Full Screen Mode
11:22:43.1 10/9/2008: Creating Back Buffer
11:22:43.2 10/9/2008: Loading graphic Surfaces
11:22:43.2 10/9/2008: Display is running at: 1024x768 32bit color, 75hz
11:22:43.3 10/9/2008: Creating Surfaces Flags
11:22:43.5 10/9/2008: Creating Surfaces Misc and Dialogs
11:22:43.7 10/9/2008: Creating Surfaces Volume
11:22:43.7 10/9/2008: Creating Surfaces Arrows
11:22:43.8 10/9/2008: Creating Surfaces GameEXlogo Text
11:22:43.8 10/9/2008: Creating Surfaces Toolbar
11:22:43.9 10/9/2008: Creating Surfaces Backgrounds
11:22:47.9 10/9/2008: Creating Surfaces Toolbar Controls
11:22:47.9 10/9/2008: Creating Surfaces GameEx Logo
11:22:48.0 10/9/2008: Creating Surface Unselected
11:22:48.0 10/9/2008: Creating Surfaces Home & Exit
11:22:48.1 10/9/2008: Creating Surfaces Snaps
11:22:48.1 10/9/2008: Creating Surfaces Menu and List Bars
11:22:48.4 10/9/2008: Creating Fonts
11:22:48.4 10/9/2008: Creating Game Font
11:22:49.0 10/9/2008: Creating Game Font Faded
11:22:49.2 10/9/2008: Creating Title Font
11:22:49.4 10/9/2008: Restoring Title Font From Cache
11:22:51.2 10/9/2008: Creating Font Black
11:22:51.5 10/9/2008: Creating Font Black Small
11:22:51.7 10/9/2008: Fonts Created Succesfully
11:22:51.7 10/9/2008: 569mb video memory left available
11:22:51.7 10/9/2008: Creating instance of global keyboard hook
11:22:52.0 10/9/2008: Text/Language: English
11:22:52.0 10/9/2008: Applying Language/Text
11:22:52.2 10/9/2008: Initialising Bass Audio Library
11:22:53.7 10/9/2008: MAME CMD options:
11:22:53.8 10/9/2008: Loading last used Game List
11:22:54.1 10/9/2008: Loading Start Page
11:22:54.2 10/9/2008: Setting Music Volume
11:22:54.3 10/9/2008: Creating DirectSound Device
11:22:54.3 10/9/2008: Trying: Primary Sound Driver
11:22:54.3 10/9/2008: Loading Sound Files
11:22:54.5 10/9/2008: DirectSound Device Created Successfully
11:22:54.5 10/9/2008: Creating ICONS
11:22:54.5 10/9/2008: Restoring Cached ICONS from File
11:22:55.3 10/9/2008: Initialising DirectInput for Gamepad support
11:22:55.4 10/9/2008: Looking for Device: Logitech Dual Action USB
11:22:55.5 10/9/2008: Device Created
11:22:55.6 10/9/2008: Initializing MCE Remote
11:22:55.7 10/9/2008: Playing intro sound file
11:22:55.7 10/9/2008: Initialization OK! Starting GameEx!
11:22:55.7 10/9/2008: Testing Main Loop Once: Processing Frame
11:22:56.7 10/9/2008: Testing Main Loop Once: Main Loop ran successfully
[color="red"][b]11:23:12.2 10/9/2008: Loading Karaoke Cache
11:23:16.5 10/9/2008: Exception from HRESULT: 0x80040216
11:23:16.7 10/9/2008: at DvdCore.GeneralEngineClass.Open(String file)
at q.a(Boolean A_0, Boolean A_1, String A_2, String A_3, Boolean A_4)[/b][/color]
11:23:24.3 10/9/2008: Exiting GameEx!
11:23:24.3 10/9/2008: Saving Settings
11:23:26.4 10/9/2008: Disposing Plugins
11:23:26.5 10/9/2008: Closing database connection
11:23:26.5 10/9/2008: Checking for applications to Launch On Exit
  fRequEnCy said:
Here's my log Tom! I bolded the section where it seems to be happening for easy reference. ;)
This looks to me that the Karoake plugin is not installed. You have to select it when installing GameEx. Did you do that?
Who do ya think you're talking to Tom? LOL. :P;)
Or course it's installed! It works using WMP.
  TSpeirs said:
Sorry :) Not sure whats going on then.
Me neither. Maybe chriss has a different problem as we haven't seen his log yet. But obviously something wrong. LOL. We'll figure it out!
Can you please try the attached GameEx.exe and post the log again?
Thanks for your help.
GameEx.zip
Here ya go!
12:51:17.1 10/9/2008: GameEx: Version 9.58: Starting Log
12:51:17.1 10/9/2008: Operating System Platform: Win32NT
12:51:17.1 10/9/2008: Operating System Name: Windows XP
12:51:17.1 10/9/2008: Operating System Version: 5.1.2600
12:51:17.1 10/9/2008: Checking for versions of .net Framework installed
12:51:17.1 10/9/2008: .net Framework 1.1 Installed
12:51:17.1 10/9/2008: .net Framework 2.0 Installed
12:51:17.1 10/9/2008: Intel® Pentium® 4 CPU 3.00GHz, 3070MB
12:51:17.1 10/9/2008: 2.99Ghz - 2 Cores or CPU's
12:51:17.1 10/9/2008: Running Randomize()
12:51:17.1 10/9/2008: Loading PlugIns
12:51:17.5 10/9/2008: Checking for applications to Launch On Startup
12:51:17.5 10/9/2008: Running Misc startup tasks
12:51:17.5 10/9/2008: Setting Menu types
12:51:17.5 10/9/2008: Opening Configuration File
12:51:17.5 10/9/2008: Getting Configuration Values
12:51:17.6 10/9/2008: Using Theme: Default - MCE Glossy V3
12:51:17.6 10/9/2008: Checking for alternate Image Directory for Theme: Default - MCE Glossy V3
12:51:17.6 10/9/2008: Using Images from theme: Default - MCE Glossy\MEDIA\
12:51:17.7 10/9/2008: Initialising Video/MNG DLL's
12:51:17.8 10/9/2008: GameEx will check for media insertion (may affect performance)
12:51:17.9 10/9/2008: Is Media Center running?
12:51:17.9 10/9/2008: Checking/Creating LCD Registry values
12:51:17.9 10/9/2008: Check Media Center Exit/Start Mode
12:51:17.9 10/9/2008: Media Center Mode 2
12:51:18.0 10/9/2008: Video previews on. Warning: Only recommended on modern systems
12:51:18.2 10/9/2008: Snap Delay set to: 2
12:51:18.2 10/9/2008: Get other settings
12:51:19.2 10/9/2008: Start work for Form
12:51:19.2 10/9/2008: Getting Original Screen Size
12:51:19.2 10/9/2008: Compacting Database
12:51:19.5 10/9/2008: Opening Database Connection
12:51:19.6 10/9/2008: Initializing Component
12:51:19.7 10/9/2008: Retrieving resolution setting
12:51:19.8 10/9/2008: Initialising Windows Media Player Component
12:51:19.8 10/9/2008: MAME Path is: C:\Emulators\MAME
12:51:19.9 10/9/2008: daphne Path is: C:\Emulators\Daphne
12:51:19.9 10/9/2008: daphne EXE file is: Daphne.exe
12:51:19.9 10/9/2008: Use daphne on. Daphne.exe will launch games
12:51:20.0 10/9/2008: Model 2 Path Path is: C:\Emulators\Model2
12:51:20.0 10/9/2008: Multi Core/Hyper Threading detected. Looking for emulator_multicpu.exe
12:51:20.0 10/9/2008: Not Found. Looking for emulator.exe
12:51:20.0 10/9/2008: Model 2 EXE file is: emulator.exe
12:51:20.0 10/9/2008: Model 2 emulator with command line support detected
12:51:20.0 10/9/2008: Use Model 2 on. emulator.exe will launch Sega Model 2 games
12:51:20.1 10/9/2008: ZiNc Path is: C:\Emulators\ZiNc
12:51:20.1 10/9/2008: ZiNc EXE file is: zinc.exe
12:51:20.1 10/9/2008: Use ZiNc on. zinc.exe will launch PSX games
12:51:20.1 10/9/2008: MAME EXE file is: mame.exe
12:51:20.1 10/9/2008: ROM Paths are: D:\Romsets\Arcade\MAME\MAME ROMs;D:\Romsets\Arcade\MAME\MAME CHDs
12:51:20.1 10/9/2008: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
12:51:20.2 10/9/2008: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
12:51:20.2 10/9/2008: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
12:51:20.2 10/9/2008: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
12:51:20.2 10/9/2008: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
12:51:20.5 10/9/2008: Loading Controls.ini map file
12:51:20.6 10/9/2008: Snap Path is: D:\Romsets\Art & Sound\MAME - Extras (Core)\snap
12:51:20.6 10/9/2008: AVI Snap Path: Not Found
12:51:20.6 10/9/2008: Flyer Path is: D:\Romsets\Art & Sound\MAME - Extras (Core)\flyers
12:51:20.6 10/9/2008: Cabinet Path is: D:\Romsets\Art & Sound\MAME - Extras (Core)\cabinets
12:51:20.6 10/9/2008: Title Path is: D:\Romsets\Art & Sound\MAME - Extras (Core)\titles
12:51:20.6 10/9/2008: PCB Path is: D:\Romsets\Art & Sound\MAME - Extras (Core)\pcb
12:51:20.6 10/9/2008: Artwork Preview Path: Not Found
12:51:20.6 10/9/2008: Panel Path is: D:\Romsets\Art & Sound\MAME - Extras (Core)\cpanel
12:51:20.6 10/9/2008: Manual Path: Not Found
12:51:20.6 10/9/2008: Icon Path is: C:\Emulators\MAME\icons
12:51:20.6 10/9/2008: Marquee Path is: D:\Romsets\Art & Sound\MAME - Extras (Core)\marquees
12:51:20.7 10/9/2008: Loading Custom Emulators
12:51:20.7 10/9/2008: Loading Emulator 1: [Arcade] AAE
12:51:21.5 10/9/2008: Loading Emulator 2: [Arcade] Final Burn Alpha
12:51:21.5 10/9/2008: Loading Emulator 3: [Arcade] Final Burn Evolution
12:51:21.6 10/9/2008: Loading Emulator 4: [Arcade] Nebula
12:51:21.7 10/9/2008: Loading Emulator 5: [Arcade] Raine
12:51:21.8 10/9/2008: Loading Emulator 6: [Arcade] Sega Naomi
12:51:21.8 10/9/2008: Loading Emulator 7: [Arcade] Vivanonno
12:51:21.9 10/9/2008: Loading Emulator 8: [Arcade] WinKawaks
12:51:22.0 10/9/2008: Loading Emulator 9: [Arcade] ZiNc
12:51:22.1 10/9/2008: Loading Emulator 10: [Console] Atari 2600 (Stella)
12:51:22.1 10/9/2008: Loading Emulator 11: [Console] Atari 5200 (MESS)
12:51:22.2 10/9/2008: Loading Emulator 12: [Console] Atari 7800 (MESS)
12:51:22.3 10/9/2008: Loading Emulator 13: [Console] Atari Jaguar (Virtual Jaguar)
12:51:22.3 10/9/2008: Loading Emulator 14: [Console] Bally Astrocade (MESS)
12:51:22.4 10/9/2008: Loading Emulator 15: [Console] Coleco Vision (blueMSX)
12:51:22.5 10/9/2008: Loading Emulator 17: [Console] Fairchild Channel F (MESS)
12:51:22.6 10/9/2008: Loading Emulator 18: [Console] GCE Vectrex (MESS)
12:51:22.6 10/9/2008: Loading Emulator 19: [Console] Magnavox Odyssey 2 (O2EM)
12:51:22.7 10/9/2008: Loading Emulator 21: [Console] NEC SuperGrafx (Mednafen)
12:51:22.8 10/9/2008: Loading Emulator 22: [Console] NEC TurboGrafx 16 (MagicEngine)
12:51:22.9 10/9/2008: Loading Emulator 23: [Console] Nintendo N64 (Project64)
12:51:22.9 10/9/2008: Loading Emulator 24: [Console] Nintendo NES (NEStopia)
12:51:23.0 10/9/2008: Loading Emulator 25: [Console] Nintendo SNES (ZSNES)
12:51:23.1 10/9/2008: Loading Emulator 26: [Console] Philips Videopac+
12:51:23.2 10/9/2008: Loading Emulator 27: [Console] Sega 32x (Fusion)
12:51:23.2 10/9/2008: Loading Emulator 29: [Console] Sega Genesis (Fusion)
12:51:23.3 10/9/2008: Loading Emulator 30: [Console] Sega Master System (Fusion)
12:51:23.4 10/9/2008: Loading Emulator 32: [Console] SNK Neo-Geo (Nebula)
12:51:23.5 10/9/2008: Loading Emulator 33: [Console] Sony PlayStation (ePSXe)
12:51:23.7 10/9/2008: Loading Emulator 34: [Console] Vtech Creativision (MESS)
12:51:23.8 10/9/2008: Loading Emulator 35: [HandHeld] Atari Lynx (Mednafen)
12:51:24.0 10/9/2008: Loading Emulator 36: [HandHeld] Bandai Wonderswan (Mednafen)
12:51:24.1 10/9/2008: Loading Emulator 37: [HandHeld] Bandai Wonderswan Color (Mednafen)
12:51:24.1 10/9/2008: Loading Emulator 38: [HandHeld] Nintendo DS (No$GBA)
12:51:24.2 10/9/2008: Loading Emulator 39: [HandHeld] Nintendo GameBoy (VBA)
12:51:24.3 10/9/2008: Loading Emulator 40: [HandHeld] Nintendo GameBoy Advance (VBA)
12:51:24.4 10/9/2008: Loading Emulator 41: [HandHeld] Nintendo GameBoy Color (VBA)
12:51:24.5 10/9/2008: Loading Emulator 42: [HandHeld] Nintendo Virtual Boy (Reality Boy)
12:51:24.6 10/9/2008: Loading Emulator 43: [HandHeld] Sega Game Gear (Fusion)
12:51:24.6 10/9/2008: Loading Emulator 44: [HandHeld] SNK Neo Geo Pocket (Mednafen)
12:51:24.7 10/9/2008: Loading Emulator 45: [HandHeld] SNK Neo Geo Pocket Color (Mednafen)
12:51:24.8 10/9/2008: Loading Emulator 46: [Handheld] Watara Supervision (MESS)
12:51:24.9 10/9/2008: Loading Emulator 47: [PC] Apple IIc (MESS)
12:51:25.0 10/9/2008: Loading Emulator 49: [PC] Microsoft MSX (blueMSX)
12:51:25.0 10/9/2008: Loading Emulator 50: [PC] Microsoft MSX2 (blueMSX)
12:51:25.1 10/9/2008: Loading Emulator 52: [Pinball] Future Pinball
12:51:25.6 10/9/2008: Using Version 3 Themes Animations
12:51:25.6 10/9/2008: Using General Font: Trebuchet MS
12:51:25.6 10/9/2008: Using Title Font: Trebuchet MS
12:51:25.6 10/9/2008: Attempting to load game list
12:51:26.2 10/9/2008: Initialising DirectDraw
12:51:26.2 10/9/2008: Applying GameEx is Loading Image
12:51:26.3 10/9/2008: Creating DirectDraw Device
12:51:26.3 10/9/2008: Using Device: RADEON X300 Series
12:51:26.5 10/9/2008: 630mb video memory available
12:51:26.5 10/9/2008: Creating DirectDraw Surfaces
12:51:26.5 10/9/2008: Creating Primary Surface - Windowed Mode
12:51:26.6 10/9/2008: Creating Back Buffer
12:51:26.6 10/9/2008: Loading graphic Surfaces
12:51:26.6 10/9/2008: Display is running at: 1024x768 32bit color, 75hz
12:51:26.7 10/9/2008: Creating Surfaces Flags
12:51:26.7 10/9/2008: Creating Surfaces Misc and Dialogs
12:51:26.8 10/9/2008: Creating Surfaces Volume
12:51:26.9 10/9/2008: Creating Surfaces Arrows
12:51:26.9 10/9/2008: Creating Surfaces GameEXlogo Text
12:51:26.9 10/9/2008: Creating Surfaces Toolbar
12:51:26.9 10/9/2008: Creating Surfaces Backgrounds
12:51:27.0 10/9/2008: Creating Surfaces Toolbar Controls
12:51:27.0 10/9/2008: Creating Surfaces GameEx Logo
12:51:27.0 10/9/2008: Creating Surface Unselected
12:51:27.1 10/9/2008: Creating Surfaces Home & Exit
12:51:27.1 10/9/2008: Creating Surfaces Snaps
12:51:27.1 10/9/2008: Creating Surfaces Menu and List Bars
12:51:27.1 10/9/2008: Creating Fonts
12:51:27.1 10/9/2008: Creating Game Font
12:51:27.4 10/9/2008: Creating Game Font Faded
12:51:27.5 10/9/2008: Creating Title Font
12:51:27.7 10/9/2008: Restoring Title Font From Cache
12:51:27.8 10/9/2008: Creating Font Black
12:51:28.0 10/9/2008: Creating Font Black Small
12:51:28.2 10/9/2008: Fonts Created Succesfully
12:51:28.2 10/9/2008: 595mb video memory left available
12:51:28.3 10/9/2008: Creating instance of global keyboard hook
12:51:28.6 10/9/2008: Text/Language: English
12:51:28.6 10/9/2008: Applying Language/Text
12:51:28.7 10/9/2008: Initialising Bass Audio Library
12:51:29.8 10/9/2008: MAME CMD options:
12:51:29.8 10/9/2008: Loading last used Game List
12:51:30.0 10/9/2008: Loading Start Page
12:51:30.2 10/9/2008: Setting Music Volume
12:51:30.2 10/9/2008: Creating DirectSound Device
12:51:30.2 10/9/2008: Trying: Primary Sound Driver
12:51:30.2 10/9/2008: Loading Sound Files
12:51:30.2 10/9/2008: DirectSound Device Created Successfully
12:51:30.2 10/9/2008: Creating ICONS
12:51:30.3 10/9/2008: Restoring Cached ICONS from File
12:51:30.5 10/9/2008: Initialising DirectInput for Gamepad support
12:51:30.5 10/9/2008: Looking for Device: Logitech Dual Action USB
12:51:30.5 10/9/2008: Device Created
12:51:30.6 10/9/2008: Initializing MCE Remote
12:51:30.7 10/9/2008: Playing intro sound file
12:51:30.7 10/9/2008: Initialization OK! Starting GameEx!
12:51:30.7 10/9/2008: Testing Main Loop Once: Processing Frame
12:51:31.5 10/9/2008: Testing Main Loop Once: Main Loop ran successfully
12:52:07.0 10/9/2008: Loading Karaoke Cache
12:52:08.6 10/9/2008: Open Karaoke: C:\Documents and Settings\Jeremy\Desktop\test karaoke\DKG001-01 Like A Virgin - Madonna.cdg
12:52:08.7 10/9/2008: Exception from HRESULT: 0x80040216
12:52:08.8 10/9/2008: at DvdCore.GeneralEngineClass.Open(String file)
12:52:11.3 10/9/2008: Open Karaoke: C:\Documents and Settings\Jeremy\Desktop\test karaoke\DKG001-02 I Want To Know What Love Is - Foreigner.cdg
12:52:11.5 10/9/2008: Exception from HRESULT: 0x80040216
12:52:11.5 10/9/2008: at DvdCore.GeneralEngineClass.Open(String file)
12:52:13.6 10/9/2008: Exiting GameEx!
12:52:13.6 10/9/2008: Saving Settings
12:52:14.0 10/9/2008: Disposing Plugins
12:52:14.0 10/9/2008: Closing database connection
12:52:14.1 10/9/2008: Checking for applications to Launch On Exit
i got a similar error!
while fooling around with settings and changing the karaoke dir gameex crashed and it said something with karaoke cache problem (sorry i don't remember the exact text)
i submitted the error though! Karaoke plugin is installed of course and it worked before....
Hey chriss! Can we see your log so we can see if it's the same issue?
22:00:40.5  09.10.2008:  GameEx: Version 9.58: Starting Log
22:00:40.5 09.10.2008: Operating System Platform: Win32NT
22:00:40.5 09.10.2008: Operating System Name: Windows XP
22:00:40.5 09.10.2008: Operating System Version: 5.1.2600
22:00:40.7 09.10.2008: Checking for versions of .net Framework installed
22:00:40.7 09.10.2008: .net Framework 2.0 Installed
22:00:40.7 09.10.2008: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+, 1023MB
22:00:40.7 09.10.2008: 2,21Ghz - 2 Cores or CPU's
22:00:40.7 09.10.2008: Running Randomize()
22:00:40.7 09.10.2008: Loading PlugIns
22:00:40.8 09.10.2008: Checking for applications to Launch On Startup
22:00:40.8 09.10.2008: Running Misc startup tasks
22:00:40.8 09.10.2008: Setting Menu types
22:00:40.8 09.10.2008: Opening Configuration File
22:00:40.8 09.10.2008: Getting Configuration Values
22:00:40.9 09.10.2008: Using Theme: Default - Media Center
22:00:40.9 09.10.2008: Checking for alternate Image Directory for Theme: Default - Media Center
22:00:40.9 09.10.2008: Using Images from theme: Default - Media Center V1\MEDIA\
22:00:41.1 09.10.2008: Launching HideOS.exe
22:00:41.1 09.10.2008: Initialising Video/MNG DLL's
22:00:41.6 09.10.2008: Arcade Mode is on
22:00:41.6 09.10.2008: GameEx will check for media insertion (may affect performance)
22:00:41.6 09.10.2008: Hiding Taskbar
22:00:41.6 09.10.2008: Using Cabinet Friendly Control System
22:00:41.6 09.10.2008: Is Media Center running?
22:00:41.6 09.10.2008: Checking/Creating LCD Registry values
22:00:41.8 09.10.2008: Check Media Center Exit/Start Mode
22:00:41.8 09.10.2008: Media Center Mode 2
22:00:41.9 09.10.2008: Video previews on. Warning: Only recommended on modern systems
22:00:42.5 09.10.2008: Custom Keyboard Input enabled: Getting custom codes
22:00:42.5 09.10.2008: Snap Delay set to: 6
22:00:42.5 09.10.2008: Get other settings
22:00:42.5 09.10.2008: Mouse Input is disabled
22:00:42.7 09.10.2008: Set: Find emulator artwork on best match basis
22:00:42.7 09.10.2008: Using DirectInput for keyboard input
22:00:42.7 09.10.2008: Start work for Form
22:00:42.7 09.10.2008: Getting Original Screen Size
22:00:42.7 09.10.2008: Opening Database Connection
22:00:45.4 09.10.2008: Initializing Component
22:00:45.7 09.10.2008: Retrieving resolution setting
22:00:45.8 09.10.2008: Initialising Windows Media Player Component
22:00:46.2 09.10.2008: MAME Path is: D:\Games\mame
22:00:46.2 09.10.2008: daphne Path is: D:\Games\DaphneLD
22:00:46.2 09.10.2008: daphne EXE file is: daphne.exe
22:00:46.3 09.10.2008: Use daphne on. daphne.exe will launch games
22:00:46.3 09.10.2008: ZiNc Path is: D:\Games\mame
22:00:46.3 09.10.2008: ZiNc EXE file is: zinc.exe
22:00:46.3 09.10.2008: Use ZiNc on. zinc.exe will launch PSX games
22:00:46.3 09.10.2008: MAME EXE file is: mamep.exe
22:00:46.4 09.10.2008: ROM Path is: D:\Games\mame\roms
22:00:46.4 09.10.2008: Catver.ini is located at: C:\Programme\GameEx\DATA\catver.ini
22:00:46.4 09.10.2008: controls.ini is located at: C:\Programme\GameEx\data\controls.ini
22:00:46.4 09.10.2008: History.dat is located at: C:\Programme\GameEx\DATA\history.dat
22:00:46.4 09.10.2008: nplayers.ini is located at: C:\Programme\GameEx\DATA\nplayers.ini
22:00:46.4 09.10.2008: MAMEinfo.dat is located at: C:\Programme\GameEx\DATA\mameinfo.dat
22:00:46.5 09.10.2008: Loading Controls.ini map file
22:00:46.5 09.10.2008: Snap Path is: D:\Games\mame\snap
22:00:46.5 09.10.2008: AVI Snap Path is: D:\Games\mame\avisnap
22:00:46.6 09.10.2008: Flyer Path is: D:\Games\mame\flyers
22:00:46.6 09.10.2008: Cabinet Path is: D:\Games\mame\cabinets
22:00:46.6 09.10.2008: Title Path is: D:\Games\mame\titles
22:00:46.7 09.10.2008: PCB Path is: D:\Games\mame\pcb
22:00:46.7 09.10.2008: Artwork Preview Path is: D:\Games\mame\artwork
22:00:46.7 09.10.2008: Panel Path is: D:\Games\mame\cpanel
22:00:46.7 09.10.2008: Manual Path: Not Found
22:00:46.8 09.10.2008: Icon Path is: D:\Games\mame\icons
22:00:46.8 09.10.2008: Marquee Path is: D:\Games\mame\marquees
22:00:46.8 09.10.2008: Loading Custom Emulators
22:00:46.8 09.10.2008: Loading Emulator 1: Nintendo SNES
22:00:47.0 09.10.2008: Loading Emulator 3: Nintendo NES
22:00:47.1 09.10.2008: Loading Emulator 4: Nintendo N64
22:00:47.2 09.10.2008: Loading Emulator 5: Sega Dreamcast
22:00:47.3 09.10.2008: Loading Emulator 6: Sega Naomi
22:00:47.5 09.10.2008: Loading Emulator 7: Sega Mega Drive
22:00:47.6 09.10.2008: Loading Emulator 8: Sega Master System
22:00:47.7 09.10.2008: Loading Emulator 9: Sony PlayStation
22:00:47.7 09.10.2008: Loading Emulator 10: Sony PlayStation Better 3D
22:00:47.8 09.10.2008: Loading Emulator 11: Commodore Amiga
22:00:47.9 09.10.2008: Loading Emulator 12: Commodore 64
22:00:48.1 09.10.2008: Loading Emulator 14: Atari ST
22:00:48.2 09.10.2008: Loading Emulator 15: Pinball
22:00:48.2 09.10.2008: Loading Emulator 16: PC Games
22:00:48.5 09.10.2008: Using Version 3 Themes Animations
22:00:48.5 09.10.2008: Using General Font: Verdana
22:00:48.5 09.10.2008: Using Title Font: Verdana
22:00:48.5 09.10.2008: Attempting to load game list
22:00:49.3 09.10.2008: Initialising DirectDraw
22:00:49.4 09.10.2008: Applying GameEx is Loading Image
22:00:49.6 09.10.2008: Creating DirectDraw Device
22:00:49.6 09.10.2008: Using Device: ATI Radeon 9600/9550/X1050 Series
22:00:50.2 09.10.2008: 120mb video memory available
22:00:50.3 09.10.2008: Setting Resolution to 1024x768 32 bit color
22:00:50.3 09.10.2008: Creating DirectDraw Surfaces
22:00:50.3 09.10.2008: Creating Primary Surface - Full Screen Mode
22:00:50.4 09.10.2008: Creating Back Buffer
22:00:50.5 09.10.2008: Loading graphic Surfaces
22:00:50.5 09.10.2008: Display is running at: 1024x768 32bit color, 85hz
22:00:50.6 09.10.2008: Creating Surfaces Flags
22:00:50.7 09.10.2008: Creating Surfaces Misc and Dialogs
22:00:50.7 09.10.2008: Creating Surfaces Volume
22:00:50.7 09.10.2008: Creating Surfaces Arrows
22:00:50.7 09.10.2008: Creating Surfaces GameEXlogo Text
22:00:50.7 09.10.2008: Creating Surfaces Toolbar
22:00:50.7 09.10.2008: Creating Surfaces Backgrounds
22:00:57.6 09.10.2008: Creating Surfaces Toolbar Controls
22:00:57.7 09.10.2008: Creating Surfaces GameEx Logo
22:00:57.7 09.10.2008: Creating Surface Unselected
22:00:57.7 09.10.2008: Creating Surfaces Home & Exit
22:00:57.7 09.10.2008: Creating Surfaces Snaps
22:00:57.7 09.10.2008: Creating Surfaces Menu and List Bars
22:00:57.8 09.10.2008: Creating Fonts
22:00:57.8 09.10.2008: Creating Game Font
22:00:58.3 09.10.2008: Creating Game Font Faded
22:00:58.9 09.10.2008: Creating Title Font
22:00:58.9 09.10.2008: Restoring Title Font From Cache
22:01:01.1 09.10.2008: Creating Font Black
22:01:01.2 09.10.2008: Creating Font Black Small
22:01:01.4 09.10.2008: Fonts Created Succesfully
22:01:01.4 09.10.2008: 62mb video memory left available
22:01:01.4 09.10.2008: Creating instance of global keyboard hook
22:01:01.5 09.10.2008: Playing Startup Video on thread
22:01:01.5 09.10.2008: Text/Language: Custom
22:01:01.5 09.10.2008: Applying Language/Text
22:01:01.7 09.10.2008: Initialising Bass Audio Library
22:01:01.8 09.10.2008: MAME CMD options:
22:01:01.8 09.10.2008: Loading last used Game List
22:01:02.0 09.10.2008: Loading Start Page
22:01:02.1 09.10.2008: Setting Music Volume
22:01:02.1 09.10.2008: Loading music
22:01:05.1 09.10.2008: Sound Disabled
22:01:05.1 09.10.2008: Creating ICONS
22:01:05.2 09.10.2008: Restoring Cached ICONS from File
22:01:06.1 09.10.2008: Gamepad/Joystick disabled
22:01:06.1 09.10.2008: Initialising DirectInput for Keyboard support
22:01:06.5 09.10.2008: Initializing MCE Remote
22:01:06.6 09.10.2008: Initialization OK! Starting GameEx!
22:01:06.6 09.10.2008: Testing Main Loop Once: Processing Frame
22:01:07.4 09.10.2008: Testing Main Loop Once: Main Loop ran successfully
22:04:06.8 09.10.2008: Starting Attract Mode
22:04:06.8 09.10.2008: Reading MAME hall of fame
22:04:07.5 09.10.2008: Running: cmd.exe /c D: D:\Games\mame\mamep.exe ccastles -rompath D:\Games\mame\roms -volume -32
22:07:12.7 09.10.2008: Running: cmd.exe /c D: D:\Games\mame\mamep.exe timber -rompath D:\Games\mame\roms -volume -32
22:07:45.0 09.10.2008: Key/Joy press detected: Exiting Attract mode, closing MAME
22:07:48.2 09.10.2008: Returning From Attract Mode
22:07:51.8 09.10.2008: Loading Karaoke Cache
thats all it says
Is it crashing there? Cuz mine doesn't crash. It just tries to load the file and then goes back to GameEx. Don't see how that log is complete since it stops right there and doesn't show GameEx exiting. When posting long codes instead of using the code tag use the codebox. So [ codebox ] ..... [ /codebox ]. No spaces between the brackets. Just had to type that way so it wouldn't actually create a code box.
ok thanks for the hint... i was asking myself how you put it in the box :)
anyway for me gameex doesn't do anything. i click on a file and nothing happens...
LOL. No prob. Well don't get why Tom's works and ours don't! LOL. Maybe Tom has a better version that he doesn't release to us. ;) But he did post an executable to try so he's looking into it.
this is just great service!
i don't know a lot of software where you work with the developer so closely!
now let's hope he comes up with a solution :)
If not then no karaoke party for you! LOL. :P .
yeah... :(
i can still try to install an older version...
and i still got a day to figure it out! I'm sure I'll get it working :)
uh oh tomorrow is our karaoke party and i still haven't fixed it.... anything new on this topic?
I haven't heard anything chriss! You might wanna start thinking of another approach temporarily till it gets fixed. I'm still able to play using WMP so you might wanna give it a try. If not, then there's plenty of decent freeware apps out there. Not sure of any of them as I use a commercial one.
true... i thought about using other software.... but i gotta control karaoke with the arcade sticks (especially the page function i need)... so i think of installing an old gameex version!
