Hi Tom,
Would it be possible to add in next MNGer if planned a checkbox, or a right click menu option, to ask MNGer to stretch (as it actually does by default), or NOT stretch but rather use real 1:1 size, the mngs...?
Thx for considering, Regards, MAMu_
Also ^^
could it be possible to save these options in a ini file...?
ie: if you check loop, close MNGer
and relaunch it, loop is not checked anymore...
I'll repeat it here.....Just in case you forget ;)
Hi Tom
Well I'll just think out loud...I don't know if it would be possible.
Adding an .ini so you could map the mng dir path and not have to enter it in the commandline.
The choice in the .ini to loop the mng if just playing one
The fullscreen choice in the .ini not in the commandline
The choice to play through the mngs in the dir....not just one
The choice to set it to random so it picks the mngs at random.
As I said before just so I can launch your player and have it play the mngs as a sort of never ending attract mode in a cabinet.....which I could watch instead of TV..
Hmmm.....Do the names of the game appear in the mngs ??...
Just thought if someone like me or a mate see's a game they like the look of they would be able to know what it's called.....
No prob if none of this is possible.....as I said just thinking out loud
:wub:
  • 2 years later...
Would you consider implementing a screensaver version of MNGer? I'm hoping to be able to play MNG's as a screensaver but I'm having no luck finding one.
