9.56 loaded - songs keep restarting when I re-enter
Every time I come out of a game, the song starts back at the beginning.
I have music set to 'pause' playlist and play whatever. It worked fine until I upgraded today. :(
Other than that, all else is working great.
IMBerzerk
IMBerzerk
I have noticed this before as well, prior to even the current update. Sometimes it seems like it would depend on how far I was into the song on whether or not it would start again from the beginningâ?¦
It goes back to version 9.52 when I updated the audio libraries.
It should be fixed in the attached replacement gameex.exe. Can you try for me?
I will when I get home tonight and report back.
Thanks.
Seems to have fixed it for me, thanks.
I'd say add it to the next update, whatever that change is cause it works for me. ;)
Same here... good to go! Thanks for the quick fix.
IMBerzerk
