Krakerman Posted September 25, 2008 Share Posted September 25, 2008 Am I missing something ... when I configure GameEx to use M.E.S.S for running Atari 5200 emulation the screen goes to desktop and in the DOSBOX it says PAUSE and hit any key to continue then it runs the emulator. How to you skip that?? So it doesn't ask you to press a key to continue?Thanks Quote Link to comment Share on other sites More sharing options...
fRequEnCy Posted September 25, 2008 Share Posted September 25, 2008 Am I missing something ... when I configure GameEx to use M.E.S.S for running Atari 5200 emulation the screen goes to desktop and in the DOSBOX it says PAUSE and hit any key to continue then it runs the emulator. How to you skip that?? So it doesn't ask you to press a key to continue?ThanksWhat's in your command-line? Should be as follows:mess.exe a5200 -cart "[ROMPath]\[RomFile]" -joy -now -nonewui Quote Link to comment Share on other sites More sharing options...
Krakerman Posted September 25, 2008 Author Share Posted September 25, 2008 Figured it out that I needed to turn debug mode off.Thanks Quote Link to comment Share on other sites More sharing options...
fRequEnCy Posted September 25, 2008 Share Posted September 25, 2008 Figured it out that I needed to turn debug mode off.Thanks Ahhh was GameEx that was messing you up. Yeah, debug mode is useful to see the command-line settings being used before it's actually ran to find where the problems lie. In your case your problem was the debug feature. Quote Link to comment Share on other sites More sharing options...
