How to create avisnaps with sound in GameEx
Hello:
I have a problem, when i create videosnaps from GameEx option, it records the video but not the sound, i have tried it with all the codec options in the list, also, with CamStudio and Fraps, and it's the same.
I wanted to create it from the GameEx option because it's faster and easier cause it's automatic.
If you can tell me how to do it please...
Thanks.
Hello:
Thanks.
I am sorry to say that your time with the codecs has been wasted. GameEx does not support the recording of sound.
Another option is to use software like hypercam, or fraps (make sure record sound is selected) to record the video with sound, or download the videos you require from Emumovies.
