After upgrading to the newest version I can not get gameex to launch mame32. I have tried tons of different versions - I have Windows MCE - all updates - .net 1.1 with patch - 1 GB ram - AMD 3000+ any ideas?
07:58:20.0 9/4/2005: GameEx: Version 4.99: Starting Log
07:58:20.0 9/4/2005: Operating System Platform: Win32NT
07:58:20.0 9/4/2005: Operating System Name: Windows XP
07:58:20.0 9/4/2005: Operating System Version: 5.1.2600
07:58:20.0 9/4/2005: Checking Registration
07:58:20.0 9/4/2005: Running Randomize()
07:58:20.0 9/4/2005: Running Misc startup tasks
07:58:20.0 9/4/2005: Setting Menu types
07:58:20.0 9/4/2005: Opening Configuration File
07:58:20.0 9/4/2005: Getting Configuration Values
07:58:20.0 9/4/2005: Using Theme: Default - Default
07:58:20.0 9/4/2005: Checking for alternate Image Directory for Theme: Default - Default
07:58:20.0 9/4/2005: Text/Language: English
07:58:20.0 9/4/2005: Applying Language/Text
07:58:20.0 9/4/2005: Creating Scancodes.txt (List of DirectInput scan codes)
07:58:20.0 9/4/2005: Snap Delay set to: 1
07:58:20.0 9/4/2005: Is Media Center running?
07:58:20.0 9/4/2005: Check Media Center Exit/Start Mode
07:58:20.0 9/4/2005: Media Center Mode 2
07:58:20.0 9/4/2005: Checking for applications to Launch On Startup
07:58:20.0 9/4/2005: Get other settings
07:58:20.0 9/4/2005: Using 2D Animations
07:58:20.1 9/4/2005: Launching HideOS.exe
07:58:20.9 9/4/2005: Hiding Taskbar
07:58:20.9 9/4/2005: Start work for Form
07:58:20.9 9/4/2005: Getting Original Screen Size
07:58:20.9 9/4/2005: Loading ICON
07:58:20.9 9/4/2005: Initializing Component
07:58:20.9 9/4/2005: Initialising Bass Audio Library
07:58:21.1 9/4/2005: Loading default loading screen
07:58:21.1 9/4/2005: Using General Font: Trebuchet MS
07:58:21.1 9/4/2005: Using Title Font: Trebuchet MS
07:58:21.1 9/4/2005: Initialising DirectDraw
07:58:21.1 9/4/2005: Applying GameEx is Loading Image
07:58:21.2 9/4/2005: Creating DirectDraw Device
07:58:21.2 9/4/2005: Using Device: RADEON X600/X550 Series
07:58:21.3 9/4/2005: Setting Resolution to 800x600 32 bit color
07:58:21.3 9/4/2005: Creating DirectDraw Surfaces
07:58:21.3 9/4/2005: Creating Primary Surface - Full Screen Mode
07:58:21.3 9/4/2005: Creating Back Buffer
07:58:21.3 9/4/2005: Loading graphic surfaces
07:58:21.4 9/4/2005: Creating Surfaces Misc and Dialogs
07:58:21.4 9/4/2005: Creating Surface Volume
07:58:21.4 9/4/2005: Creating Surfaces Arrows
07:58:21.4 9/4/2005: Creating Surfaces GameEXlogo Text
07:58:21.4 9/4/2005: Creating Surfaces Toolbar
07:58:21.4 9/4/2005: Creating Surfaces Backgrounds
07:58:21.7 9/4/2005: Creating Surfaces Toolbar Controls
07:58:21.7 9/4/2005: Creating Surfaces GameEx Logo
07:58:21.7 9/4/2005: Creating Surfaces Home & Exit
07:58:21.7 9/4/2005: Creating Surfaces Snaps
07:58:21.7 9/4/2005: Creating Surfaces Menu and List Bars
07:58:21.7 9/4/2005: Creating Fonts
07:58:21.7 9/4/2005: Creating Menu Font
07:58:21.8 9/4/2005: Creating Game Font
07:58:21.8 9/4/2005: Creating Game Font Standard Size
07:58:22.1 9/4/2005: Creating Font Black
07:58:22.1 9/4/2005: Creating Font Black Small
07:58:22.2 9/4/2005: Creating Game Font Faded
07:58:22.2 9/4/2005: Creating Title Font
07:58:22.3 9/4/2005: Initialising Windows Media Player Component
07:58:22.4 9/4/2005: MAME Path is: C:\MAME\Mame32
07:58:22.4 9/4/2005: MAME EXE file is: Mame32
07:58:22.4 9/4/2005: Invalid MAME Executable
07:58:24.6 9/4/2005: ERRORS DETECTED: EXITING
Your mame executable looks like its missing the '.exe' on the end of it therefore GameEx is looking for MAME32 instead of MAME32.exe. Obviously MAME32 does not exist on your hard disk.
Edited by Draco1962
