How do i play a movie i burned onto my hard drive using gameex?
DO I NEED:
1:A SPECIFIC WINDOWS OPERATING SYSTEM
2:A SPECIFIC GAMEEX VERSION
3:A SPECIFIC MEDIA PLAYER
4:ANYTHING NOT STATED
Im running win98se, gameex latest version. windows media player9.
ps:thank you tspeirs, this looks much better.
i cant seemed to load my dvd rip{movie} into full screen. it loads but all i hear is sound with a big black screen. ilook at window media player sight and found nothing on loading directly into fullscreen. please help. thank you
So its working in Windows Media Player you mean? Did you try that? Can you please post your log. Are you using Windows 2000 or XP. I think theres issues in 98/ME
Im running win98se. Ive tried all gameex versions.Yes it does work in media player but i have to manually put it into full screen.
07:06:06.6 9/3/2005: GameEx: Version 4.63: Starting Log
07:06:06.7 9/3/2005: Operating System Platform: Win32Windows
07:06:06.7 9/3/2005: Operating System Name: Unknown
07:06:06.7 9/3/2005: Operating System Version: 4.10.67766446
07:06:06.7 9/3/2005: Running Randomize()
07:06:06.7 9/3/2005: Running Misc startup tasks
07:06:06.7 9/3/2005: Hiding Cursor
07:06:06.8 9/3/2005: Setting Menu types
07:06:06.8 9/3/2005: Opening Configuration File
07:06:06.8 9/3/2005: Getting Configuration Values
07:06:06.8 9/3/2005: Using Theme: Default - BlueEx - Arcade800x600
07:06:06.8 9/3/2005: Checking for alternate Image Directory for Theme: Default - BlueEx - Arcade800x600
07:06:06.8 9/3/2005: Text/Language: English
07:06:06.9 9/3/2005: Applying Language/Text
07:06:07.0 9/3/2005: Creating Scancodes.txt (List of DirectInput scan codes)
07:06:07.1 9/3/2005: Snap Delay set to: 1
07:06:07.1 9/3/2005: Is Media Center running?
07:06:07.1 9/3/2005: Check Media Center Exit/Start Mode
07:06:07.1 9/3/2005: Media Center Mode 0
07:06:07.1 9/3/2005: Checking for applications to Launch On Startup
07:06:07.1 9/3/2005: Get other settings
07:06:07.1 9/3/2005: Launching HideOS.exe
07:06:07.5 9/3/2005: Hiding Taskbar
07:06:07.6 9/3/2005: Start work for Form
07:06:07.7 9/3/2005: Getting Original Screen Size
07:06:07.9 9/3/2005: Loading ICON
07:06:08.2 9/3/2005: Initializing Component
07:06:08.9 9/3/2005: Arcade Mode is on
07:06:08.9 9/3/2005: Using General Font: Arial
07:06:08.9 9/3/2005: Using Title Font: Joystix
07:06:08.9 9/3/2005: Initialising DirectDraw
07:06:09.0 9/3/2005: Applying GameEx is Loading Image
07:06:09.4 9/3/2005: Creating DirectDraw Device
07:06:09.6 9/3/2005: Setting Resolution to 800x600 32 bit color
07:06:10.1 9/3/2005: Creating DirectDraw Surfaces
07:06:10.1 9/3/2005: Creating Primary Surface - Full Screen Mode
07:06:10.1 9/3/2005: Creating Back Buffer
07:06:10.1 9/3/2005: Loading graphic surfaces
07:06:11.3 9/3/2005: Creating Fonts
07:06:11.3 9/3/2005: Creating Menu Font
07:06:11.7 9/3/2005: Creating Game Font
07:06:11.8 9/3/2005: Creating Menu Font Standard Size
07:06:12.2 9/3/2005: Creating Font Black
07:06:12.3 9/3/2005: Creating Font Black Small
07:06:12.3 9/3/2005: Creating Game Font Faded
07:06:12.4 9/3/2005: Creating Title Font
07:06:12.7 9/3/2005: Initialising Windows Media Player Component
07:06:13.0 9/3/2005: Loading Controls.ini map file
07:06:13.1 9/3/2005: Loading Custom Emulators
07:06:13.8 9/3/2005: MAME CMD options: -skip_disclaimer -skip_gameinfo -triplebuffer -nowindow -joy
07:06:13.8 9/3/2005: Attempting to load game list
07:06:13.9 9/3/2005: Loading last used Game List
07:06:14.9 9/3/2005: Initialising Bass Audio Library
07:06:15.9 9/3/2005: Creating DirectSound Device
07:06:15.9 9/3/2005: Trying: Primary Sound Driver
07:06:15.9 9/3/2005: Loading Sound Files
07:06:16.0 9/3/2005: DirectSound Device Created Successfully
07:06:16.0 9/3/2005: Initialising DirectInput for Gamepad support
07:06:16.1 9/3/2005: Unable to create a joystick device
07:06:16.2 9/3/2005: Playing Startup Video
07:06:16.2 9/3/2005: Playing intro sound file
07:06:16.2 9/3/2005: Initialization OK! Starting GameEx!
07:06:16.2 9/3/2005: Testing Main Loop Once: Processing Frame
07:06:16.6 9/3/2005: Testing Main Loop Once: Main Loop ran successfully
07:06:42.2 9/3/2005: Playing Video: E:\MOVIES\bourne supremacy dvd rip.avi
07:07:18.4 9/3/2005: Exiting GameEx!
07:07:18.4 9/3/2005: Saving Settings
07:07:19.8 9/3/2005: Checking for applications to Launch On Exit
There are some issue with Windows 98/Me for playing videos and DVD's I think. Sorry.
Although are you running Windows media Player 9?
I tried it as well in winxp. I didn't get picture or sound. i would have to say the problem is that media player is not loading into fullscreen.this happend to me when running a emulator- i heard sound but with no picture. fgot it to load fullscreen and all worked.
Please help me into launching windows media player9 into fullscreen
Are you talking about playing videos in gameEx (which uses components of media Player and not Media Player itself) or actually Playing in Windows Media Player itself? In which case your asking the question in completly the wrong place, and I cant really help.
If certain videos are not playing in Windows XP, you probably need the Codecs. Go ahead and download FFDSHOW from http://ffdshow.sf.net
Also, if your talking openly about playing copyrighted movies you downloaded from the internet, your also breaking the forum rules, so please go elsewhere if that is the case.
im not tring to be mean to anyone. but are u reading the whole post? the player works fine {wich ive mentioned already} or am i doing something wrong in these post??
i think the biggest problem is how to get windows media player9 in win98se to launch in fullscreen mode. then i beleive gammex will work
or just plainly put-how do you playripped movies in gameex???? :(
why r assuming im breaking the law when just about every new pc has a dvd burner installed.im sorry but that is not going to solve my issue.thanks anyway
its only a crime when u dont own the movie.i own the movies!!!!!!!!!!!u cant rent a movie without the movie police telling u its a crime!!!!!!!!!
OK, what Im trying to say is Windows media Player itself playing full screen has nothing to do with GameEx. If your watching a movie in GameEx (which is not Windows Media Player), you can change the aspect by pressing Enter.
You actually said the player did not work fine, you said you had no picture, which I said is because you are running on Windows 98.
You really need to take a lot more time to do your posts, they are very hard to read and understand, with very bad English, and we are talking about technical information. This is not a board for Text/SMS messages. If you dont read or speak English well you should say so in your post, if not please think about what your writing, read over it, think about it and try to explain intelligently in an adult fashion. I am actually trying to help you here, please help me to help you. If you post again in the same manner, I'm going to ignore you, but I really mean no offence I just dont have the time.
[/quHow do i play a movie i burned onto my hard drive using gameex?
DO I NEED:
ote]
DO I NEED:
1. Windows 2000,XP, MCE, 2003 (it should work on Windows 98SE/ME but I dont think it does)
2. The latest version (Although Video Playback was properly implemented in Version 4). I can only offer you support for the latest version.
3. Yes, you need Windows Media Player installed. The latest version is recommended, although I've had it working on the version that ships with Windows 2000 which I think is 6.
4. Yes you need Codecs to play AVI files. Install FFDSHOW here: http://ffdswhow.sf.net
Thank you, I will try that
