Whenever I start up GameEX I get this error.
01:53:19.5 9/2/2005: GameEx: Version 4.97: Starting Log
01:53:19.5 9/2/2005: Operating System Platform: Win32NT
01:53:19.5 9/2/2005: Operating System Name: Windows XP
01:53:19.5 9/2/2005: Operating System Version: 5.1.2600
01:53:19.5 9/2/2005: ERROR: An error occured while checking for previous instance of GameEx
01:53:19.5 9/2/2005: This can be caused by a bad windows or .net framework install.
01:53:19.5 9/2/2005: GameEx will likely function incorrectly as it cannot check for running processes
01:53:19.5 9/2/2005: GameEx will now exit with errors
01:53:19.6 9/2/2005: ERRORS DETECTED: EXITING
I have 2.0 .net framework installed.
That's your problem, and thank you so much for tellling me that, I never knew what caused this problem, and now i do.
Time to make GameEx not install if 2.0 is installed.
Thanks again, but as for your problem, i would uninstall 2.0 install 1.1 SP1, until 2.0 comes out of Beta, and all the bugs are fixed, such as this one.
Just for newbies: Beta does not mean cool, exciting and new. It means buggy, 'i'm releasing this to save paying for people to test it, but you cant complain because its Beta and not officially supported'.
Er, I have had 2.0 beta (2.0.40607) installed from the get-go of using Gameex, and there's never been a problem on my machine.
2.0, 1.1 and 1.0 all coexst on the same machine and are supposed to be available to apps that are built for a certain version. See the folder:
C:\WINDOWS\Microsoft.NET\Framework
Please undo that change. You can't use Micrososft's free developer tools without 2.0 beta.
-- Rob
-- Rob
Ok, i think its users who just have 2.0 installed. Would a check for version 2 only suffice? IE if they have 1.1 and 2 then that is fine? Or does 2.0 automatically install 1.1 also?
I don't think 2.0 installs 1.1. For me they're all independent entries. I can uninstall either 1.1, 1.1 hotfix, and 2.0 from add/remove programs.
If the issue is that he has 2.0 and not 1.1, you should just require 1.1. I'll try removing 1.1 to find out if that causes that behavior.
