Exception in GameEx.GameEx.mainform.DisplayFrame()
v4.95
I would love to get GameEx working. This is the first version that Ive tried installing. See the error at the bottom.
21:05:13.0 8/30/2005: GameEx: Version 4.95: Starting Log
21:05:13.0 8/30/2005: Operating System Platform: Win32NT
21:05:13.0 8/30/2005: Operating System Name: Windows XP
21:05:13.0 8/30/2005: Operating System Version: 5.1.2600
21:05:13.0 8/30/2005: Checking Registration
21:05:13.0 8/30/2005: Running Randomize()
21:05:13.0 8/30/2005: Running Misc startup tasks
21:05:13.0 8/30/2005: Setting Menu types
21:05:13.0 8/30/2005: Opening Configuration File
21:05:13.0 8/30/2005: Getting Configuration Values
21:05:13.0 8/30/2005: Using Theme: Default - Default
21:05:13.0 8/30/2005: Checking for alternate Image Directory for Theme: Default - Default
21:05:13.0 8/30/2005: Text/Language: English
21:05:13.0 8/30/2005: Applying Language/Text
21:05:13.0 8/30/2005: Creating Scancodes.txt (List of DirectInput scan codes)
21:05:13.0 8/30/2005: Snap Delay set to: 1
21:05:13.0 8/30/2005: Is Media Center running?
21:05:13.0 8/30/2005: Check Media Center Exit/Start Mode
21:05:13.0 8/30/2005: Media Center Mode 2
21:05:13.1 8/30/2005: Checking for applications to Launch On Startup
21:05:13.1 8/30/2005: Get other settings
21:05:13.1 8/30/2005: Using 2D Animations
21:05:13.1 8/30/2005: Launching HideOS.exe
21:05:14.0 8/30/2005: Hiding Taskbar
21:05:14.0 8/30/2005: Start work for Form
21:05:14.0 8/30/2005: Getting Original Screen Size
21:05:14.0 8/30/2005: Loading ICON
21:05:14.1 8/30/2005: Initializing Component
21:05:14.1 8/30/2005: Initialising Bass Audio Library
21:05:14.3 8/30/2005: Loading default loading screen
21:05:14.4 8/30/2005: Using General Font: Trebuchet MS
21:05:14.4 8/30/2005: Using Title Font: Trebuchet MS
21:05:14.4 8/30/2005: Initialising DirectDraw
21:05:14.4 8/30/2005: Creating DirectDraw Device
21:05:14.4 8/30/2005: Using Device: ALL-IN-WONDER 9800 SERIES
21:05:14.4 8/30/2005: Setting Resolution to 1600x1200 32 bit color
21:05:14.4 8/30/2005: Creating DirectDraw Surfaces
21:05:14.4 8/30/2005: Creating Primary Surface - Full Screen Mode
21:05:14.5 8/30/2005: Creating Back Buffer
21:05:14.5 8/30/2005: Loading graphic surfaces
21:05:14.5 8/30/2005: Creating Surfaces Misc and Dialogs
21:05:14.5 8/30/2005: Creating Surface Volume
21:05:14.5 8/30/2005: Creating Surfaces Arrows
21:05:14.5 8/30/2005: Creating Surfaces GameEXlogo Text
21:05:14.5 8/30/2005: Creating Surfaces Toolbar
21:05:14.5 8/30/2005: Creating Surfaces Backgrounds
21:05:15.9 8/30/2005: Creating Surfaces Toolbar Controls
21:05:15.9 8/30/2005: Creating Surfaces GameEx Logo
21:05:16.0 8/30/2005: Creating Surfaces Home & Exit
21:05:16.0 8/30/2005: Creating Surfaces Snaps
21:05:16.0 8/30/2005: Creating Surfaces Menu and List Bars
21:05:16.1 8/30/2005: Creating Fonts
21:05:16.1 8/30/2005: Creating Menu Font
21:05:16.2 8/30/2005: Creating Game Font
21:05:16.2 8/30/2005: Creating Game Font Standard Size
21:05:17.0 8/30/2005: Creating Font Black
21:05:17.0 8/30/2005: Creating Font Black Small
21:05:17.1 8/30/2005: Creating Game Font Faded
21:05:17.2 8/30/2005: Creating Title Font
21:05:32.7 8/30/2005: Initialising Windows Media Player Component
21:05:32.7 8/30/2005: MAME Path is: C:\downloads\roms\Mame32
21:05:32.7 8/30/2005: MAME EXE file is: Mame32.exe
21:05:32.7 8/30/2005: ROM Path is: C:\downloads\roms\mame
21:05:32.7 8/30/2005: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
21:05:32.7 8/30/2005: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
21:05:32.7 8/30/2005: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
21:05:32.7 8/30/2005: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
21:05:32.7 8/30/2005: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
21:05:32.7 8/30/2005: Loading Controls.ini map file
21:05:32.7 8/30/2005: Loading Custom Emulators
21:05:33.0 8/30/2005: Snap Path is: C:\downloads\roms\Mame32\snap
21:05:33.0 8/30/2005: AVI Snap Path: Not Found
21:05:33.0 8/30/2005: Flyer Path: Not Found
21:05:33.0 8/30/2005: Cabinet Path: Not Found
21:05:33.0 8/30/2005: Title Path: Not Found
21:05:33.0 8/30/2005: Panel Path: Not Found
21:05:33.0 8/30/2005: Icon Path: Not Found
21:05:33.1 8/30/2005: Marquee Path: Not Found
21:05:33.1 8/30/2005: MAME CMD options: -skip_disclaimer -skip_gameinfo -triplebuffer -nowindow -joy
21:05:33.1 8/30/2005: Attempting to load game list
21:05:33.1 8/30/2005: Loading last used Game List
21:05:33.4 8/30/2005: Sound Disabled
21:05:33.4 8/30/2005: Initialising DirectInput for Gamepad support
21:05:33.4 8/30/2005: Unable to create a joystick device
21:05:33.4 8/30/2005: Initializing MCE Remote
21:05:33.4 8/30/2005: Initialization OK! Starting GameEx!
21:05:33.4 8/30/2005: Testing Main Loop Once: Processing Frame
21:05:33.6 8/30/2005: ERRORS DETECTED: EXITING
21:05:33.6 8/30/2005: at GameEx.Functions2.IsPlaying()
21:05:33.6 8/30/2005: at GameEx.GameEx.mainform.DisplayFrame()
Thats strange I thought that was fixed in 4.95.
Can you unintstall, delete the program files\gameex directory.
And then go ahead and install 4.96, just uploaded.
Thanks.
Thanks.
I un-installed, deleted the gameex directory, downloaded 4.96, and installed it. I still get the same error.
My system: P4 2.4G Hz(Dell 400SC) 2x500 M RAM, ATI 9800 PRO AIW, Win XP Pro (not MCE), BTV is running, I have the ATI Remote installed.
The error occurs when the donate screen seems to be ending, I hear a few notes of the music (2-4 notes) and then I get the error. My audio is onboard audio.
I disabled audio in the Audio menu of the GameEx configuration and I still get the same exception.
Example log of when audio is disabled (last few items):
09:02:11.8 8/31/2005: Cannot Load Play List. Check Path and filename
09:02:11.8 8/31/2005: Sound Disabled
09:02:11.8 8/31/2005: Initialising DirectInput for Gamepad support
09:02:11.8 8/31/2005: Unable to create a joystick device
09:02:11.8 8/31/2005: Initializing MCE Remote
09:02:11.8 8/31/2005: Initialization OK! Starting GameEx!
09:02:11.8 8/31/2005: Testing Main Loop Once: Processing Frame
09:02:11.9 8/31/2005: ERRORS DETECTED: EXITING
09:02:11.9 8/31/2005: at GameEx.Functions2.IsPlaying()
09:02:11.9 8/31/2005: at GameEx.GameEx.mainform.DisplayFrame()
OK, to find this little bugger.
Do this:
Go into GameEx.ini in the config dir. Search for Windowed
Change Windowed=False to Windowed= True
Replace GameEx.exe with the one attached.
Run it
Let me know what happens, and post the error. If theres a detail button when the error shows, click it and tell me what the text says.
Thanks.
GameEx.zip
Do this:
Run it
Thanks.
I get a CLR Runtime Debugging Services Dialog:
Title: GameEx.exe - Common Language Runtime Debugging Services
Body of the dialog:
Application has generated an exception that could not be handled.
Process id =0xe68 (3688), Thread id=0xad4 (2772).
Click OK to terminate the application.
Click CANCEL to debug the application.
Two buttons: OK and Cancel
No details button. I do not have the CLR JIT installed so I could not debug the exception.
Body of the dialog:
Could you try replacing the file in the gameex directory with the ones in the attached zip.
bin.zip
In addition, are you using a non english version of Windows or similar?
The same error resulted from both sets of dlls.
I am running a legal copy of Microsoft Windows XP Professional (5.1, Build 2600) Language: English (Regional Setting: English). I have DirectX 9.0c 4.09.0000.0904. I am running an Intel Pentium 4 CPU at 2.40 G Hz (With HT turned on) with 1022 MB ram (as reported by DXDiag.exe, I really have 2x512 MB)
I am running my video settings at 1600x1200 32bit, 60Hz for a Dell LCD.
Looking at the Administrattive Tools for WinXP, I have two sets of .NET icons, one set for .NET Frameword 1.1 and one set for .NET Frameword 2.0. I dont recall installing .NET Framework 2.0.
OK, it could be the 2.0. Other thing is to try running at a lower resolution to see if that helps, at lest just for the moment.
Lowering the resolution didn't help. Regarding 2.0. All my .NET 1.1 applications still work, I am not 100% convinced it is that. I am not going to be able to test any more today so dont sweat it. I appreciate you working with me to get this working. I am really excited for what GameEx has to offer.
~Random
~Random
Good news. I got it to work. The offending setting was Display Settings -> Background Mode. It was set to "Display Background Images", when I changed it to "Display Black Background" the crash went away.
But...When I attempted to view a slideshow I get:
09:23:56.1 9/1/2005: Testing Main Loop Once: Main Loop ran successfully
09:24:28.2 9/1/2005: 20 Consecutive Exceptions Occured: Exiting
09:24:28.2 9/1/2005: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
09:24:28.2 9/1/2005: at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags, DrawEffects bltEffects)
09:24:28.2 9/1/2005: at GameEx.GameEx.mainform.DisplayFrame()
Which is odd because it is trying to display an image again, not dissimilar from the Background Mode setting. Any thoughts?
~Random
Hi random,
I had this error last time i configured gameEX. I think you should change in the configuration menu the resolution display. I could not explain or tell precisely how i fix it
i changed the skin resolution display AND set in the display settings : "Don't switch resolution : set resolution to below"
from my part it will crash if i set "don't change"
~Random
I think Im getting closer to the problem. Please replace GameEx.exe with the one attached, and post the log. It is a debug version with a lot of logging.
GameEx.zip
Also try this one, I think it might give us the exact error description at startup
Thanks. Please do let me know.
GameEx.zip
Good news. The last exe that you sent works! I can use GameEx now. Wow! What an amazing application! I am very impressed.
When I start GameEx.exe first an Alert-Dialog-like box appears with the text: 1 and an Ok button. When I click the Ok Button, another similar dialog appears with no text, and just an Ok Button. I click ok, and GameEx.exe launches and all the backgrounds show, and all the functionality seems to work.
A tiny bug: in my version, the capital "W" texture has too many pixels from the master texture so part of the X comes through. It looks like it is off by about 3-4 pixels.
What changed in this last exe?
~Random
When I start GameEx.exe first an alert-Dialog-like box appears with the text: 1 and an Ok button.  When I click the Ok Button, another similar dialog appears with no text, and just an Ok Button.  I click ok, and GameEx.exe launches and all the backgrounds show, and all the functionality seems to work.
~Random
Not really too sure what changed.
Here is version 5.00 of GameEx.exe without all the slow down caused by the debuging. Please try it, and if it's OK, ill upload a new install to the Web Site.
Thanks,
Tom
What screen are you in when when the W shows incorrectly? What's the full text?
GameEx.zip
Thanks,
Tom
The new exe has the same issues as the original exes. I have reverted back to the debug exe that works for me. I have been using GameEx a lot now that it works for me. I have tested MAME, Sega CD, SNes, pictures, jukebox, weather, and news. It all seems to work.
The W with the X in it was from the "update list" progress dialog.
I am currently having an issue where Project 64 wont update the screen with running fullscreen. I start Mario Kart 64, and I get the audio with a black screen. When I run windowed, Project 64 opens windowed, and seems to work great. Any ideas on how I can fix this?
~Random
~Random
Nevermind the Project 64 issue. I resolved that by following instructions that I found when using the Search feature of this forum. My bad.
Regardless, the only GameEx.exe that works for me is the debug version mentioned above. Any thoughts on why that is?
~Random
~Random
Sorry, I don't have a clue at the moment. I expect the debug version is pretty unusable though, due to being so slow.
