30th August 2005 V 1.30
Now shows last frame when stopping the video or when its reached the end.
Faster screen refresh (a bit smoother).
Previously when stopping the MNG, it would still be playing on a thread in the background. Did no harm but would be taking up a bit more memory.
Oke Dokie....
Now if anyone else uses 98se please test...
I can't try this on my dedicated box coz it blew up...
I can only try it on this one, which is my main box and has all manner of protection on it..eg Firewall, AV and anti spyware programs running....
Now the prob....
Can fire it up fine....plays fine....can close it and continue posting drivel in the forums fine.....can launch any other proggy fine...
Prob is on shutdown it hangs at the "Windows is shutting down" screen and I have to power off......
10 min scandisk later all is well again....
I have tried it as the first thing I've run and the prob is the same so it's deffo teh minger...
Waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
I'm sure you're in gates's back pocket......trying to make me upgrade to XP....
I shall resist.......I shall resist.......I shall resist.......
No Doz in XP........No Doz in XP.........No Doz in XP....
  Orclord said:
Oke Dokie....
Now the prob....
Are you absolutely sure its Mnger doing that?
Try replacing these files in the MNGER directory, see if it helps. (You dont need PlayVideoBak.ddl)
bindx9.zip
Nah still locks on shutdown....
Don't worry about it at the moment Tom...
Especially if no one else using 98se has the problem..
I'll test again when I have my dedicated box up and running with a clean install...
Then if it still knacks up I'll pester you...
