Brand new install of MCE 2005 everything else works perfect! I can run gameex fine if the media center is not loaded but if its loaded (weather i launch from mce or not) gameex loads the nag then the screen goes black, then i see my desk top then black again, then finally it brings me to the MCE screen even if it was minimized at the time I ran GameEX....
This really sucks! I want to use this extension!
I just got 4.95 (i believe) and the same behavior is occuring...
I uninstalled the old version first and rebooted before re-installing the new version...
If I can get this working i will definately be donating cause I plan on using this a lot.
Can you post your log please.
Thanks.
Thanks.
where do i find my log file? I wont be home until like 6 CST but if i know where it is ahead of time i can just grab it and post it right away when I get home.
PS. You are great man - there are so many homebrew's out there that have message boards and it takes weeks to to get a response - your two for two in two days - keep up the good work!
In: C:/Program files/GameEx/log
22:55:36.3 8/30/2005: GameEx: Version 4.95: Starting Log
22:55:36.3 8/30/2005: Operating System Platform: Win32NT
22:55:36.3 8/30/2005: Operating System Name: Windows XP
22:55:36.3 8/30/2005: Operating System Version: 5.1.2600
22:55:36.3 8/30/2005: Checking Registration
22:55:36.3 8/30/2005: Running Randomize()
22:55:36.3 8/30/2005: Running Misc startup tasks
22:55:36.3 8/30/2005: Setting Menu types
22:55:36.3 8/30/2005: Opening Configuration File
22:55:36.3 8/30/2005: Getting Configuration Values
22:55:36.3 8/30/2005: Using Theme: Default - BlueEx - MCE1024x768
22:55:36.3 8/30/2005: Checking for alternate Image Directory for Theme: Default - BlueEx - MCE1024x768
22:55:36.4 8/30/2005: Text/Language: English
22:55:36.4 8/30/2005: Applying Language/Text
22:55:36.5 8/30/2005: Creating Scancodes.txt (List of DirectInput scan codes)
22:55:36.5 8/30/2005: Snap Delay set to: 1
22:55:36.5 8/30/2005: Is Media Center running?
22:55:36.5 8/30/2005: Check Media Center Exit/Start Mode
22:55:36.5 8/30/2005: Media Center Mode 0
22:55:36.5 8/30/2005: Checking for applications to Launch On Startup
22:55:36.5 8/30/2005: Get other settings
22:55:36.6 8/30/2005: Using 2D Animations
22:55:36.6 8/30/2005: Launching HideOS.exe
22:55:37.6 8/30/2005: Hiding Taskbar
22:55:37.6 8/30/2005: Start work for Form
22:55:37.6 8/30/2005: Getting Original Screen Size
22:55:37.7 8/30/2005: Loading ICON
22:55:37.7 8/30/2005: Initializing Component
22:55:37.7 8/30/2005: Initialising Bass Audio Library
22:55:38.1 8/30/2005: Loading default loading screen
22:55:38.1 8/30/2005: Using General Font: Trebuchet MS
22:55:38.1 8/30/2005: Using Title Font: Joystix
22:55:38.1 8/30/2005: Initialising DirectDraw
22:55:38.1 8/30/2005: Creating DirectDraw Device
22:55:38.1 8/30/2005: Using Device: NVIDIA GeForce FX 5200
22:55:38.2 8/30/2005: Setting Resolution to 1024x768 32 bit color
22:55:38.2 8/30/2005: Creating DirectDraw Surfaces
22:55:38.2 8/30/2005: Creating Primary Surface - Full Screen Mode
22:55:38.2 8/30/2005: Creating Back Buffer
22:55:38.2 8/30/2005: Loading graphic surfaces
22:55:38.3 8/30/2005: Creating Surfaces Misc and Dialogs
22:55:38.4 8/30/2005: Creating Surface Volume
22:55:38.4 8/30/2005: Creating Surfaces Arrows
22:55:38.4 8/30/2005: Creating Surfaces GameEXlogo Text
22:55:38.4 8/30/2005: Creating Surfaces Toolbar
22:55:38.5 8/30/2005: Creating Surfaces Backgrounds
22:55:39.1 8/30/2005: Creating Surfaces Toolbar Controls
22:55:39.1 8/30/2005: Creating Surfaces GameEx Logo
22:55:39.2 8/30/2005: Creating Surfaces Home & Exit
22:55:39.2 8/30/2005: Creating Surfaces Snaps
22:55:39.2 8/30/2005: Creating Surfaces Menu and List Bars
22:55:39.4 8/30/2005: Creating Fonts
22:55:39.4 8/30/2005: Creating Menu Font
22:55:39.5 8/30/2005: Creating Game Font
22:55:39.6 8/30/2005: Creating Game Font Standard Size
22:55:40.2 8/30/2005: Creating Font Black
22:55:40.3 8/30/2005: Creating Font Black Small
22:55:40.4 8/30/2005: Creating Game Font Faded
22:55:40.5 8/30/2005: Creating Title Font
22:55:55.9 8/30/2005: Initialising Windows Media Player Component
22:55:55.9 8/30/2005: MAME Path is: E:\roms and emulators\emu\mame32
22:55:55.9 8/30/2005: MAME EXE file is: mame.exe
22:55:55.9 8/30/2005: ROM Path is: E:\roms and emulators\emu\mame32\roms
22:55:55.9 8/30/2005: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
22:55:55.9 8/30/2005: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
22:55:55.9 8/30/2005: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
22:55:56.0 8/30/2005: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
22:55:56.0 8/30/2005: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
22:55:56.0 8/30/2005: Loading Controls.ini map file
22:55:56.0 8/30/2005: Loading Custom Emulators
22:55:56.4 8/30/2005: Snap Path is: E:\roms and emulators\emu\mame32\snap
22:55:56.4 8/30/2005: AVI Snap Path: Not Found
22:55:56.4 8/30/2005: Flyer Path is: E:\roms and emulators\emu\mame32\flyers
22:55:56.4 8/30/2005: Cabinet Path is: E:\roms and emulators\emu\mame32\cabinets
22:55:56.4 8/30/2005: Title Path: Not Found
22:55:56.4 8/30/2005: Panel Path: Not Found
22:55:56.4 8/30/2005: Icon Path is: E:\roms and emulators\emu\mame32\icons
22:55:56.4 8/30/2005: Marquee Path is: E:\roms and emulators\emu\mame32\marquees
22:55:56.4 8/30/2005: MAME CMD options: -skip_disclaimer -skip_gameinfo -triplebuffer -nowindow -joy
22:55:56.4 8/30/2005: Attempting to load game list
22:55:56.5 8/30/2005: Loading last used Game List
22:55:56.9 8/30/2005: Creating DirectSound Device
22:55:56.9 8/30/2005: Trying: Primary Sound Driver
22:55:56.9 8/30/2005: Loading Sound Files
22:55:57.0 8/30/2005: DirectSound Device Created Successfully
22:55:57.0 8/30/2005: Creating ICONS
22:55:57.3 8/30/2005: Initialising DirectInput for Gamepad support
22:55:57.3 8/30/2005: Looking for Device: 4Axes 12Keys GamePad
22:55:57.3 8/30/2005: 4Axes 12Keys GamePad Not attached. Trying First Device
22:55:57.3 8/30/2005: Using Device 4Axes 12Keys GamePad
22:55:57.4 8/30/2005: Playing intro sound file
22:55:57.4 8/30/2005: Initializing MCE Remote
22:55:57.4 8/30/2005: Initialization OK! Starting GameEx!
22:55:57.4 8/30/2005: Testing Main Loop Once: Processing Frame
22:55:57.5 8/30/2005: Detected Media Center launched
22:55:57.5 8/30/2005: Killing Media Center
22:56:01.1 8/30/2005: Exiting GameEx!
22:56:01.1 8/30/2005: Saving Settings
22:56:01.2 8/30/2005: Writing Game List to disk
22:56:10.0 8/30/2005: Checking for applications to Launch On Exit
22:56:10.0 8/30/2005: Launching Media Center
:o
Run the Config app. Go to Tweaks/Performance. Check that
"Media Center Exit/Start" mode is set to "Close and Restart (Recommended)"
Right now it looks like it thinks Media Center has been invoked, so it is killing GameEx and restarting Media Center. I'm assuming you're running GameEx from within Media Center.
All else fails you can change the second option
"Exit GameEx if MCE loaded" to No. That will prevent it from shutting down due to the presence of MCE. I'd recommend not changing this though, as your system will get in a really fouled up state when you press the green button while gameex is running.
-- Rob
hmm checked it out. I do have it set on close and restart and id rather not do the 2nd option... hmm what if i put the first option to puase and resume?
How are you launching GameEx? If it's set to "Close and Restart", Media Center (ehshell.exe) should not be running when GameEx is running. Somehow it's still running, which is what we need to figure out.
I am trying to launch from MCE but even if i just minimize MCE and run it, it bails... if media center is closed and i do it from the start menu, it works perfectly...
Please overwriste GameEx.exe (c:/program files/gameex/gameex.exe) with the one in the attached zip file.
See if thats any better. Make sure you do overwrite the file though, and dont extract it somewhere else.
Thanks,
Tom
GameEx.zip
Ok I tried that and still crashes... the fact that I am using dual displays... does that have anything to do with it?
In your original log you have MediaCenter mode as 0. Change this to the recommended option. This problem is purely your configuration.
The setting is under Tweaks/Performance. Sorry I did not spot that earlier.
You should be laughing now.
He says he's tried two different options (1 and 2) and still has the problem.
You might try editing GameEx.ini directly and looking for the MediaCenterMode line and making sure it's set to 2.
MediaCenterMode=2
MediaCenterMode=2
I think he deffinitly needs to double check Rob, if I set it to 0 it does exactly what he is describing.
