Hi,
I've not had any trouble with GameEx since getting everything setup the first time.
Not until now, that is. I'm using ZetaMame as my executable (because I think it simply looks even better than AdvanceMame) and since 4.90, I've not been able to start GameEx as usual.
Here's my log:
01:56:39.7  2005-08-30:  GameEx: Version 4.93: Starting Log
01:56:39.7  2005-08-30:  Operating System Platform: Win32NT
01:56:39.7  2005-08-30:  Operating System Name: Windows XP
01:56:39.7  2005-08-30:  Operating System Version: 5.1.2600
01:56:39.7  2005-08-30:  Checking Registration
01:56:39.7  2005-08-30:  Running Randomize()
01:56:39.7  2005-08-30:  Running Misc startup tasks
01:56:39.7  2005-08-30:  Setting Menu types
01:56:39.7  2005-08-30:  Opening Configuration File
01:56:39.7  2005-08-30:  Getting Configuration Values
01:56:39.7  2005-08-30:  Using Theme: Default - GameEx - Animated
01:56:39.7  2005-08-30:  Checking for alternate Image Directory for Theme: Default - GameEx - Animated
01:56:39.8  2005-08-30:  Using Images from theme: Default - GameEx\MEDIA\
01:56:39.8  2005-08-30:  Text/Language: Custom
01:56:39.8  2005-08-30:  Applying Language/Text
01:56:39.9  2005-08-30:  Custom Keyboard Input enabled: Getting custom codes
01:56:39.9  2005-08-30:  Creating Scancodes.txt (List of DirectInput scan codes)
01:56:39.9  2005-08-30:  Snap Delay set to: 2
01:56:39.9  2005-08-30:  Is Media Center running?
01:56:39.9  2005-08-30:  Check Media Center Exit/Start Mode
01:56:39.9  2005-08-30:  Media Center Mode 2
01:56:40.0  2005-08-30:  Checking for applications to Launch On Startup
01:56:40.0  2005-08-30:  Get other settings
01:56:40.0  2005-08-30:  Using 2D Animations
01:56:40.0  2005-08-30:  Using DirectInput for keyboard input
01:56:40.0  2005-08-30:  Launching HideOS.exe
01:56:40.6  2005-08-30:  Hiding Taskbar
01:56:40.7  2005-08-30:  Start work for Form
01:56:40.7  2005-08-30:  Getting Original Screen Size
01:56:40.7  2005-08-30:  Loading ICON
01:56:40.7  2005-08-30:  Initializing Component
01:56:42.6  2005-08-30:  Initialising Bass Audio Library
01:56:43.4  2005-08-30:  Loading default loading screen
01:56:43.5  2005-08-30:  Using General Font: HandelGothic BT
01:56:43.5  2005-08-30:  Using Title Font: HandelGothic BT
01:56:43.5  2005-08-30:  Initialising DirectDraw
01:56:43.6  2005-08-30:  Creating DirectDraw Device
01:56:43.6  2005-08-30:  Using Device: C.P. Technologies Inc. RADEON 9250 GameFX
01:56:43.7  2005-08-30:  Setting Resolution to 1024x768 32 bit color
01:56:44.4  2005-08-30:  Creating DirectDraw Surfaces
01:56:44.4  2005-08-30:  Creating Primary Surface - Full Screen Mode
01:56:44.5  2005-08-30:  Creating Back Buffer
01:56:44.5  2005-08-30:  Loading graphic surfaces
01:56:44.5  2005-08-30:  Creating Surfaces Misc and Dialogs
01:56:44.6  2005-08-30:  Creating Surface Volume
01:56:44.6  2005-08-30:  Creating Surfaces Arrows
01:56:44.6  2005-08-30:  Creating Surfaces GameEXlogo Text
01:56:44.6  2005-08-30:  Creating Surfaces Toolbar
01:56:44.6  2005-08-30:  Creating Surfaces Backgrounds
01:56:44.7  2005-08-30:  Creating Surfaces Toolbar Controls
01:56:44.7  2005-08-30:  Creating Surfaces GameEx Logo
01:56:44.8  2005-08-30:  Creating Surfaces Home & Exit
01:56:44.8  2005-08-30:  Creating Surfaces Snaps
01:56:44.8  2005-08-30:  Creating Surfaces Menu and List Bars
01:56:44.9  2005-08-30:  Creating Fonts
01:56:44.9  2005-08-30:  Creating Menu Font
01:56:45.6  2005-08-30:  Creating Game Font
01:56:46.2  2005-08-30:  Creating Game Font Standard Size
01:56:46.7  2005-08-30:  Creating Font Black
01:56:46.8  2005-08-30:  Creating Font Black Small
01:56:46.9  2005-08-30:  Creating Game Font Faded
01:56:47.4  2005-08-30:  Creating Title Font
01:57:04.3  2005-08-30:  MAME Path is: E:\Spel\mame32
01:57:04.3  2005-08-30:  MAME EXE file is: zetaMAME32en.exe
01:57:04.3  2005-08-30:  ROM Path is: E:\Spel\mame32\roms
01:57:04.3  2005-08-30:  Catver.ini is located at: C:\Program\GameEx\DATA\catver.ini
01:57:04.3  2005-08-30:  controls.ini is located at: C:\Program\GameEx\data\controls.ini
01:57:04.3  2005-08-30:  History.dat is located at: C:\Program\GameEx\DATA\history.dat
01:57:04.3  2005-08-30:  nplayers.ini is located at: C:\Program\GameEx\DATA\nplayers.ini
01:57:04.3  2005-08-30:  MAMEinfo.dat is located at: C:\Program\GameEx\DATA\mameinfo.dat
01:57:04.3  2005-08-30:  Loading Controls.ini map file
01:57:04.3  2005-08-30:  Loading Custom Emulators
01:57:04.8  2005-08-30:  Snap Path is: E:\Spel\mame32\snap
01:57:04.8  2005-08-30:  AVI Snap Path is: E:\DOWNLOADS\bit.torrent\MNG\ingame
01:57:04.8  2005-08-30:  Flyer Path is: E:\Spel\mame32\flyers
01:57:04.8  2005-08-30:  Cabinet Path is: E:\Spel\mame32\cabinets
01:57:04.8  2005-08-30:  Title Path is: E:\Spel\mame32\titles
01:57:04.8  2005-08-30:  Panel Path: Not Found
01:57:04.8  2005-08-30:  Icon Path: Not Found
01:57:04.8  2005-08-30:  Marquee Path is: E:\Spel\mame32\marquees
01:57:04.8  2005-08-30:  MAME CMD options: -skip_disclaimer -skip_gameinfo -triplebuffer -nowindow -joy -ftr 1
01:57:04.8  2005-08-30:  Attempting to load game list
01:57:05.7  2005-08-30:  Loading last used Game List
01:57:05.7  2005-08-30:  Cannot Load Play List. Check Path and filename
01:57:05.7  2005-08-30:  Creating DirectSound Device
01:57:05.7  2005-08-30:  Trying: Primär ljuddrivrutin
01:57:05.7  2005-08-30:  Loading Sound Files
01:57:05.8  2005-08-30:  DirectSound Device Created Successfully
01:57:05.8  2005-08-30:  Initialising DirectInput for Gamepad support
01:57:05.8  2005-08-30:  Unable to create a joystick device
01:57:05.8  2005-08-30:  Initialising DirectInput for Keyboard support
01:57:05.8  2005-08-30:  Initializing MCE Remote
01:57:05.8  2005-08-30:  Initialization OK! Starting GameEx!
01:57:05.8  2005-08-30:  Testing Main Loop Once: Processing Frame
01:57:06.0  2005-08-30:  ERRORS DETECTED: EXITING
01:57:06.1  2005-08-30:     at GameEx.Functions2.IsPlaying()
01:57:06.1  2005-08-30:     at GameEx.GameEx.mainform.DisplayFrame()
Emph
