Big kisses.....And a big frown from the GF
Still a few things I would like but Cheers...at least I can see em now....
Oh and CT...that is a crap Scramble .mng.........Dropping 2 bombs at the start for nothing......
Sheesh....the first two should knockout the first two.....then drop down hugging the ground and blast away.......
Hi Tom
Well I'll just think out loud...I don't know if it would be possible.
Adding an .ini so you could map the mng dir path and not have to enter it in the commandline.
The choice in the .ini to loop the mng if just playing one
The fullscreen choice in the .ini not in the commandline
The choice to play through the mngs in the dir....not just one
The choice to set it to random so it picks the mngs at random.
As I said before just so I can launch your player and have it play the mngs as a sort of never ending attract mode in a cabinet.....which I could watch instead of TV.. :D
Hmmm.....Do the names of the game appear in the mngs ??...
Just thought if someone see's a game they like the look of they would be able to know what it's called.....
No prob if none of this is possible.....as I said just thinking out loud
And thanks for the player anyway...
Anyway I'm just gonna get some beer and fart around with 1.30....
