gameex immediately closes the mame after I select a game. skip disclaimer is not on, neither is ftr 1.
here is my config:
MameOptions=-nowindow -joy
ARe my roms bad?
I was using mame on Gameex days ago and it worked.
I am using version 4.89.
here is my config:
ARe my roms bad?
Here is my log
02:47:02.1 8/29/2005: GameEx: Version 4.92: Starting Log
02:47:02.2 8/29/2005: Operating System Platform: Win32NT
02:47:02.2 8/29/2005: Operating System Name: Windows XP
02:47:02.2 8/29/2005: Operating System Version: 5.1.2600
02:47:02.2 8/29/2005: Checking Registration
02:47:02.2 8/29/2005: Running Randomize()
02:47:02.2 8/29/2005: Running Misc startup tasks
02:47:02.2 8/29/2005: Setting Menu types
02:47:02.2 8/29/2005: Opening Configuration File
02:47:02.2 8/29/2005: Getting Configuration Values
02:47:02.3 8/29/2005: Using Theme: Default - Default
02:47:02.3 8/29/2005: Checking for alternate Image Directory for Theme: Default - Default
02:47:02.3 8/29/2005: Text/Language: English
02:47:02.3 8/29/2005: Applying Language/Text
02:47:02.4 8/29/2005: Creating Scancodes.txt (List of DirectInput scan codes)
02:47:02.5 8/29/2005: Snap Delay set to: 6
02:47:02.5 8/29/2005: Is Media Center running?
02:47:02.5 8/29/2005: Check Media Center Exit/Start Mode
02:47:02.5 8/29/2005: Media Center Mode 2
02:47:02.5 8/29/2005: Checking for applications to Launch On Startup
02:47:02.5 8/29/2005: Get other settings
02:47:02.5 8/29/2005: Using 2D Animations
02:47:02.5 8/29/2005: Launching HideOS.exe
02:47:04.5 8/29/2005: Hiding Taskbar
02:47:04.5 8/29/2005: Start work for Form
02:47:04.5 8/29/2005: Getting Original Screen Size
02:47:04.5 8/29/2005: Loading ICON
02:47:04.6 8/29/2005: Initializing Component
02:47:04.7 8/29/2005: Initialising Bass Audio Library
02:47:05.0 8/29/2005: Loading default loading screen
02:47:05.0 8/29/2005: Using General Font: Segoe Media Center
02:47:05.0 8/29/2005: Using Title Font: HandelGothic BT
02:47:05.0 8/29/2005: Initialising DirectDraw
02:47:05.2 8/29/2005: Creating DirectDraw Device
02:47:05.2 8/29/2005: Using Device: RADEON 9800 SERIES
02:47:05.3 8/29/2005: Setting Resolution to 800x600 32 bit color
02:47:06.5 8/29/2005: Creating DirectDraw Surfaces
02:47:06.5 8/29/2005: Creating Primary Surface - Full Screen Mode
02:47:06.6 8/29/2005: Creating Back Buffer
02:47:06.6 8/29/2005: Loading graphic surfaces
02:47:06.7 8/29/2005: Creating Surfaces Misc and Dialogs
02:47:06.9 8/29/2005: Creating Surface Volume
02:47:06.9 8/29/2005: Creating Surfaces Arrows
02:47:06.9 8/29/2005: Creating Surfaces GameEXlogo Text
02:47:06.9 8/29/2005: Creating Surfaces Toolbar
02:47:07.0 8/29/2005: Creating Surfaces Backgrounds
02:47:08.9 8/29/2005: Creating Surfaces Toolbar Controls
02:47:08.9 8/29/2005: Creating Surfaces GameEx Logo
02:47:09.0 8/29/2005: Creating Surfaces Home & Exit
02:47:09.0 8/29/2005: Creating Surfaces Snaps
02:47:09.0 8/29/2005: Creating Surfaces Menu and List Bars
02:47:09.2 8/29/2005: Creating Fonts
02:47:09.2 8/29/2005: Creating Menu Font
02:47:09.4 8/29/2005: Creating Game Font
02:47:09.4 8/29/2005: Creating Game Font Standard Size
02:47:09.7 8/29/2005: Creating Font Black
02:47:09.7 8/29/2005: Creating Font Black Small
02:47:09.8 8/29/2005: Creating Game Font Faded
02:47:09.8 8/29/2005: Creating Title Font
02:47:25.1 8/29/2005: Initialising Windows Media Player Component
02:47:25.2 8/29/2005: MAME Path is: D:\Emulate\mame32
02:47:25.2 8/29/2005: ZiNc Path is: D:\Emulate\ZINC
02:47:25.2 8/29/2005: ZiNc EXE file is: zinc.exe
02:47:25.3 8/29/2005: Use ZiNc on. zinc.exe will launch PSX games
02:47:25.3 8/29/2005: MAME EXE file is: mame32.exe
02:47:25.3 8/29/2005: ROM Path is: R:\roms\Mame Roms
02:47:25.3 8/29/2005: Catver.ini is located at: D:\Emulate\Mame32\catver.ini
02:47:25.3 8/29/2005: controls.ini is located at: D:\emulate\mame32\controls.ini
02:47:25.4 8/29/2005: History.dat is located at: D:\Emulate\Mame32\history.dat
02:47:25.4 8/29/2005: nplayers.ini is located at: D:\Programs\GameEx\DATA\nplayers.ini
02:47:25.4 8/29/2005: MAMEinfo.dat is located at: D:\emulate\mame32\mameinfo.dat
02:47:25.4 8/29/2005: Loading Controls.ini map file
02:47:25.4 8/29/2005: Loading Custom Emulators
02:47:25.4 8/29/2005: Loading Emulator 1: Nintendo 64
02:47:25.5 8/29/2005: Loading Emulator 2: Super Nintendo
02:47:25.5 8/29/2005: Loading OfflineList Dat File for emulator: 2
02:47:25.8 8/29/2005: Loading Emulator 3: Nintendo Entertainment System
02:47:25.9 8/29/2005: Loading Emulator 4: Famicom Disk System
02:47:26.0 8/29/2005: Loading Emulator 5: Sega Master System
02:47:26.0 8/29/2005: Loading Emulator 6: Sega Genesis
02:47:26.0 8/29/2005: Loading OfflineList Dat File for emulator: 6
02:47:26.0 8/29/2005: Cannot Find Offline List Dat File
02:47:26.0 8/29/2005: Loading Emulator 7: SegaCD
02:47:26.1 8/29/2005: Loading Emulator 8: Sega Genesis 32x
02:47:26.1 8/29/2005: Loading Emulator 9: TurboGrafx 16
02:47:26.1 8/29/2005: Loading Emulator 10: PC Engine SuperCD
02:47:26.2 8/29/2005: Loading Emulator 11: Sony Playstation
02:47:26.2 8/29/2005: Loading Emulator 12: MSX
02:47:26.2 8/29/2005: Loading OfflineList Dat File for emulator: 12
02:47:26.6 8/29/2005: Snap Path is: D:\Emulate\Mame32\snap
02:47:26.7 8/29/2005: AVI Snap Path is: D:\Emulate\MNGvideos\ingame
02:47:26.7 8/29/2005: Flyer Path is: D:\Emulate\Mame32\flyers
02:47:26.7 8/29/2005: Cabinet Path is: D:\Emulate\Mame32\cabinets
02:47:26.7 8/29/2005: Title Path is: D:\Emulate\Mame32\titles
02:47:26.7 8/29/2005: Panel Path is: D:\Emulate\Mame32\cpanel
02:47:26.7 8/29/2005: Icon Path is: D:\Emulate\Mame32\icons
02:47:26.7 8/29/2005: Marquee Path is: D:\EMulate\Mame32\marquees
02:47:26.7 8/29/2005: MAME CMD options: -joy
02:47:26.7 8/29/2005: Attempting to load game list
02:47:26.9 8/29/2005: Loading last used Game List
02:47:26.9 8/29/2005: Loading music on thread
02:47:26.9 8/29/2005: Creating DirectSound Device
02:47:26.9 8/29/2005: Trying: Primary Sound Driver
02:47:26.9 8/29/2005: Loading Sound Files
02:47:27.0 8/29/2005: DirectSound Device Created Successfully
02:47:27.0 8/29/2005: Creating ICONS
02:47:27.1 8/29/2005: Restoring Cached ICONS from File
02:47:28.4 8/29/2005: Initialising DirectInput for Gamepad support
02:47:28.5 8/29/2005: Using Device Joypad to USB converter
02:47:28.5 8/29/2005: Playing intro sound file
02:47:28.5 8/29/2005: Initializing MCE Remote
02:47:28.5 8/29/2005: Initialization OK! Starting GameEx!
02:47:28.5 8/29/2005: Testing Main Loop Once: Processing Frame
02:47:28.8 8/29/2005: Testing Main Loop Once: Main Loop ran successfully
02:47:46.9 8/29/2005: Running: cmd.exe /c D: START /WAIT D:\Emulate\mame32\mame32.exe 64street -rompath R:\roms\Mame Roms -joy
02:48:11.5 8/29/2005: Running: cmd.exe /c D: START /WAIT D:\Emulate\mame32\mame32.exe 64street -rompath R:\roms\Mame Roms -joy
02:48:42.7 8/29/2005: Running: cmd.exe /c D: START /WAIT D:\Emulate\mame32\mame32.exe sonicwi3 -rompath R:\roms\Mame Roms -joy
02:48:54.8 8/29/2005: Running: cmd.exe /c D: START /WAIT D:\Emulate\mame32\mame32.exe sonicwi3 -rompath R:\roms\Mame Roms -joy
02:49:05.7 8/29/2005: Exiting GameEx!
02:49:05.7 8/29/2005: Saving Settings
02:49:05.9 8/29/2005: Writing Game List to disk
02:49:06.0 8/29/2005: Checking for applications to Launch On Exit
02:49:06.0 8/29/2005: Media Center was not open when starting GameEx, so not launching
Does anyone know which parameters that I should have for MAME to make it work?
It loads the game and goes back to GAMEEX.
You may have ftr and skip_disclaimer setup in your mame.ini file. That could be it.
Do games launch when you exit GameEx and select run last game from the program menu group?
no ftr or skip disclaimer in .ini.
I selected run last game and it loads the roms and then closes.
I ran mame32 99U3 by itself and i works normally.
Here is my ini.
Tom is asking for you to exit GameEx. Go to the Start Menu, All Programs, go to the GameEx group, and pick "Run last game". Let us know whether that works or not. It is just a shortcut to run Mame directly with the same options that GameEx uses. That will help identify whether the problem has something to do with GameEx or the MAME configuration.
No sir, it does not work.
thank you two for your knowledge and assistance, but I switched to MAME32FX 0.99u4 and it works perfectly.
Good Frontend, good effort, thanks for everything!
