Just a quick (not 100% gameex question)
Using Daemon Tools to mount Saturn images for Yabuse (SSF seems to fail in full-screen on Vista). When I run an image from Gameex, nothing happens; I alt-tab to find that Daemon Tools has a input box open asking 'secure mode confirmation for command line: -mount 0,"D:<romfile>". I then have to select yes to continue.
If I switch off secure mode in Daemon Tools, It is turned on again after a reboot.
How do I get it to stay OFF, has anyone had this problem?
I know I can use Send Keys, but it would be cleaner just to have the option off!
oh, it also asks for confirmation to unmout when exiting the game.
This will not help you at all.. But for me deamon tools DOES remember the securemode option.
I also started to use magic iso as its free and there is no spyware/adware included.
anyways my vista box does go full screen with SSF.
Id check your drivers :)
If goes full screen and works fine. If I then exit using Alt-f4, the next time I try it pops to full screen for a few seconds and then reverts to a window frame on the screen and that it that. have to use task manager to kill it. then it will not run at all. If i delete the ini, it runs in a window without starting a game. If i then select Options - it freezes, task manager time again. Then, a few days later i will try again and it will work fine untill i exit and then the cycle begins again. It is a REAL shame as SSF is WAY better than Yabuse. And it renders Radiant Silvergun perfectly, unlike Yabuses messed up back grounds.. Bugger.
Is there any chance you could post your config and SSF ini's?? pretty please.. I have recently learnt how to ass kiss from Tempest :)
I don't believe it is a driver issue. I am using the latest nvidia non-beta drivers and all works a treat. Something goes wrong when I force an exit. Bugger, billhooks, and tons of other swearwords.
Ass kissing Huh? What goes around comes around....
I'll upload this, because you asked Brian so nicely, but if you are using the standard import GX config, you need to add a space after mount0, in the launch before line. I use daemon tools lite, and my version rembers my settings as well...
I hope the vic20 answer you gave me works, Or I'm going to delete this reply! ;)
SSF.zip
SSF.zip
You've just gotta love this forum :)
Cheers mate
