As of MAME 99u3 the -ftr 1 option that would allow you to bypass bad dump and other warning screens no longer works. The MAME devs fixed this and it now runs the games and quits them after running 1 frame. Check your commandline options in gameex and remove -ftr 1 and things should return to normal. If you are using .97 to .99u2 this option still works.
Hope that helps people with the sudden quit of games after upgrading.
[Edit] As of .99u4 -skip_disclaimer was also removed. From What's New:
Removed -skip_disclaimer since it automatically goes away after the first
time execution. [Aaron Giles]
So you'll want to remove that as well if you are using .99u4 and above.
