Screen saver exits right away, I suspect this has something to do with the removal of the skip_disclaimer command.
Actually it was the verify sets.
Should be fixed in 0.27, but yourll probably need to update the list again.
installed 0.27...
created games list... same...
it quits directly after the MAME screen...
i tried to remove the -skip_disclaimer option that was in cmd line of screensaver options, and it launch mame as it should... but i have to press OK... so it quits ;)
any ideas...?
installed 0.27...
any ideas...?
Tom i'd like to have a answer by you... :)
is your screensaver definitely broken with new MAME versions since removal of the -skip options...? :(
i'm not that much for keeping older mame versions on my pc...
Only temporarily.
I already have GameEx skipping these screens. However, theres been an issue reported, so Im still working on it.
Probably wont be long when its implemented into the ScreenSaver too.
All you need is a little patience, its coming.
