Hi everyone! I just downloaded Gameex and I'm giving it a try, and it seems awesome. I went through the entire advanced setup process and got it running, but I have encountered a frustrating error. When I have games running on it, the sound plays fine, but every 4-5 seconds there is a skip in the audio. This results in the last half or quarter audio second repeating, before the audio track goes back to normal. This happens over and over again like clockwork, and I don't know what to do to fix it. I've tried running Mame32plus without the frontend to test the audio, and everything works fine, so I assume it's an issue with Gameex. If anyone has encountered this issue, or if you've got some advice on what to do about it, I'd love to hear. Thank you in advance guys, take it easy!
Try removing -tripplebuffer from the mame options in advanced mame settings.
Did I mention how awesome both of you guys both are :) :) :)
This fixed the problem completely, and I am extremely grateful! Thanks tons guys, and hopefully anyone else having this same problem will now find a solution.
Thanks again!
