Hi,
For some reason my LEDWiz buttons no longer change color when I scroll through my mame list or enter a game. The correct buttons light up and change, but they are always white. It was working a around GameEX 9.1x last I noticed, I have since re-installed pluginLCD, GameEX and copied a new colors.ini into gameex\plugins\pluginLCD, but no joy yet. I have also moved from Vista back to XP with no luck in fixing this. Any tips on how to fix this appreciated. I have attached my pluginLCD ini and log file here - but there are no obvious errors.
Vista = pig with lipstick.
Thanks,
Dwight.
PluginLCD.zip
Your absolutely right, some bug must have crept in when I updated the mapping code. I'll release a new version as soon as I figure out what I screwed up.
EDIT: Yep last update when I was moving code from CPWizard into the plugin I accidently overwrote a line of code that was needed for Colors.ini. Check Version 2.72 hopefully it should work again. Sorry about that! lol
