Hi Tom,
Is there a tool such as TS GameLauncher Tools which would help create MAP files for other emulator based on just the roms? I am trying to setup Project64 and have it running without a problem but creating the rom list MAP file is quite a lot of typing! Or did I miss something??
Thanks!
Toonces
Hi,
There should be no need to do a map file for N64 games, as you can use the GoodTools to rename the file names. MAP files are only needed for a very few emulators.
Google goodtools etc, and dont use a map file.
Tom
The roms I have are already renamed but nothing shows up in the gamelist. Maybe I am just missing something on how to get them to show up?
Thanks!
Toonces
  TSpeirs said:
Hi,
Tom
remove the MAP file, and check the FAQ
