Hi
I have just found what appears to be the best front end around, however I seem unable to get it to work on my PC running Vista 64. I have looked through the board and can't seem to find the same issue I have.
Here is the log file and any help would be greatly appreciated.
20:51:26.0 18/05/2008: GameEx: Version 9.29: Starting Log
20:51:26.0 18/05/2008: Operating System Platform: Win32NT
20:51:26.0 18/05/2008: Operating System Name: Windows Vista
20:51:26.0 18/05/2008: Operating System Version: 6.0.6001
20:51:26.0 18/05/2008: Vista Aero running
20:51:26.0 18/05/2008: Initializing Vista volume control
20:51:26.0 18/05/2008: Checking for versions of .net Framework installed
20:51:26.0 18/05/2008: .net Framework 1.1 Installed
20:51:26.0 18/05/2008: .net Framework 2.0 Installed
20:51:26.0 18/05/2008: AMD Athlon 64 X2 Dual Core Processor 4600+, 2047MB
20:51:26.0 18/05/2008: 2.4Ghz - 2 Cores or CPU's
20:51:26.1 18/05/2008: Running Randomize()
20:51:26.1 18/05/2008: Loading PlugIns
20:51:26.1 18/05/2008: Checking for applications to Launch On Startup
20:51:26.1 18/05/2008: Running Misc startup tasks
20:51:26.1 18/05/2008: Setting Menu types
20:51:26.1 18/05/2008: Opening Configuration File
20:51:26.2 18/05/2008: Getting Configuration Values
20:51:26.2 18/05/2008: Using Theme: Default - Galaxian
20:51:26.2 18/05/2008: Checking for alternate Image Directory for Theme: Default - Galaxian
20:51:26.2 18/05/2008: Initialising Video/MNG DLL's
20:51:26.2 18/05/2008: Is Media Center running?
20:51:26.2 18/05/2008: Checking/Creating LCD Registry values
20:51:26.2 18/05/2008: Check Media Center Exit/Start Mode
20:51:26.2 18/05/2008: Media Center Mode 2
20:51:26.2 18/05/2008: Video previews on. Warning: Only recommended on modern systems
20:51:26.2 18/05/2008: Snap Delay set to: 2
20:51:26.2 18/05/2008: Get other settings
20:51:26.2 18/05/2008: Reading MAME hall of fame
20:51:26.3 18/05/2008: Set: Find emulator artwork on best match basis
20:51:26.4 18/05/2008: Start work for Form
20:51:26.4 18/05/2008: Getting Original Screen Size
20:51:26.4 18/05/2008: Opening Database Connection
20:51:26.5 18/05/2008: Initializing Component
20:51:26.6 18/05/2008: Retrieving resolution setting
20:51:26.7 18/05/2008: Initialising Windows Media Player Component
20:51:26.7 18/05/2008: MAME Path is: E:\Games\Mame
20:51:26.8 18/05/2008: MAME EXE file is: MameUI64.exe
20:51:26.8 18/05/2008: ROM Path is: E:\Games\Mame\roms
20:51:26.8 18/05/2008: Catver.ini is located at: C:\Program Files (x86)\GameEx\DATA\catver.ini
20:51:26.8 18/05/2008: controls.ini is located at: C:\Program Files (x86)\GameEx\data\controls.ini
20:51:26.8 18/05/2008: History.dat is located at: C:\Program Files (x86)\GameEx\DATA\history.dat
20:51:26.8 18/05/2008: nplayers.ini is located at: C:\Program Files (x86)\GameEx\DATA\nplayers.ini
20:51:26.8 18/05/2008: MAMEinfo.dat is located at: C:\Program Files (x86)\GameEx\DATA\mameinfo.dat
20:51:26.8 18/05/2008: Loading Controls.ini map file
20:51:26.8 18/05/2008: Snap Path is: E:\Games\Mame\snap
20:51:26.8 18/05/2008: AVI Snap Path is: E:\Games\Mame\Video
20:51:26.8 18/05/2008: Flyer Path is: E:\Games\Mame\flyers
20:51:26.8 18/05/2008: Cabinet Path is: E:\Games\Mame\cabinets
20:51:26.8 18/05/2008: Title Path is: E:\Games\Mame\titles
20:51:26.8 18/05/2008: PCB Path is: E:\Games\Mame\pcb
20:51:26.8 18/05/2008: Artwork Preview Path: Not Found
20:51:26.8 18/05/2008: Panel Path is: E:\Games\Mame\cpanel
20:51:26.8 18/05/2008: Manual Path: Not Found
20:51:26.8 18/05/2008: Icon Path is: E:\Games\Mame\icons
20:51:26.8 18/05/2008: Marquee Path is: E:\Games\Mame\marquees
20:51:26.8 18/05/2008: Loading Custom Emulators
20:51:26.8 18/05/2008: Loading Emulator 2: Nintendo SNES games
20:51:26.9 18/05/2008: Error: Emulator_2: WorkingPath Does Not Exist
20:51:26.9 18/05/2008: --Please correct the error above for this emulator or disable the emulator.
20:51:26.9 18/05/2008: ---------------------------------
20:51:26.9 18/05/2008: Error: Procedure call or argument is not valid.
20:51:26.9 18/05/2008: at Microsoft.VisualBasic.ErrObject.Raise(Int32 Number, Object Source, Object Description, Object HelpFile, Object HelpContext)
20:51:26.9 18/05/2008: at k.a4()
20:51:26.9 18/05/2008: at k.a(Boolean A_0, String A_1, Boolean A_2)
20:51:26.9 18/05/2008: at k..ctor()
20:51:26.9 18/05/2008: Closing database connection
20:51:26.9 18/05/2008: GameEx is exiting with errors
20:51:27.0 18/05/2008: ERRORS DETECTED: EXITING
As the log says
Go into the Advanced Configuration or Setup Wizard and set the correct working path for Emulator 2 or disable it.
As the log says
Thanks for the quick reply . . . disabled all but mame and now seems to be working
thanks
again
