when you select a game it goes to the screen showing snap, title etc. It also show a choice for cpviewer. If I click it, I get a big snap of the the control setup. Is it possible to show a small screen next to the box when you hover over it like title, marquueen etc. That way you can get a quick look to refresh your memory right before you play the game, without having to click for a big image. Sometimes the big image is needed, but some games only require a quick fix.
Well, I can't answer this directly, because I don't use cpviewer, and the topic clearly says "a question for HK", but:
If you use the CPWizard, you can do this.
