I have GameEx running and I am very happy with it. I have also installed Zinc and have GameEx pointing to the executable file in the GameEx config but, I do not see a menu option for Zinc Games. Is there something I need to do to get it to show up or is my config wrong? My Zinc Roms are in my Mame ROM directory and I am pointing to that in GameEx. Any help would be appreciated. Thanks...
Paul
                  Paul
Did you do an update list after you added Zinc? Is Zinc set to enable?
If so the other to check is that Zinc is set to show up as a seperate list (under MAME). This is under Enable/Disable in the config app. Make sure HideZinc is no.
I will check these and get back with you. I know I did an update list but I need to check the other things. Thanks for the info.
Paul
