I dunno wtf i did i cant find my mame now.. i tweaked some settings now I cant get mame to come up no mater what i change please help!
aka: it is not showing a list of games in gameex no mame listed at all
Maybe you said "yes" to "use advanced mame"?
I don't know if that disables mame or not...it seems like it would.
Otherwise, check your paths in "Mame options" (Especially the location of your mame.exe)
You could have moved it off the start page and have it under emulated games.
Post your Gameex.ini
Grandstander. :lol:
i am reloading gameex i dunno wtf i did.. i was using flat menu's i was jsut trying to get rid of all the mame sub menus lol
Still broke lol
[General]
# The Resolution to display GameEx in. Most resolutions are supported.
# If a Y resolution of 479 or below GameEx automaticaly goes into
# ArcadeMode and displays smaller text,and is less graphical.
# For ArcadeVGA set this to 640 X 288
XResolution=1024
YResolution=768
# If you have a dual display setup, the next option allows you to run
# GameEx on the Secondary Display. Default is false.
DisplayOnSecondary=False
# The path where Mame is located
MAMEPath=C:\Emulation\Arcade\Mame32
# The Mame.exe executable file
# Both Windows and DOS versions are supported (DOS only on Windows 98/ME)
MAMEEXE=Mame32.exe
# The path to your MAME roms
# Multiple ROM paths can be entered, seperate with semicolons.
ROMPATH=C:\Emulation\Arcade\Mame32\roms
# Put 'START /WAIT ' before the MAME executable in the command line.
# This is required if running MAME32 On Windows 98/ME only.
# Otherwise set to False.
StartWait=False
# Whether to use AdvanceMame for launching ROMS. You will still need
# a valid version of Windows MAME or MAME32 and specify it above.
# This is required for generating the game list. However if you set
# UseAdvanceMAME to true The EXE and path below will be used for launching
# games. Be sure to setup Your advmame.rc file, or use the
# AdvanceMAMEOptions
# Both Windows and DOS version are supported. DOS only on Win 98/ME
# NOTE: Dont use the -sound_volume option in AdvanceMAMEOptions
# as attract mode uses it.
# Note: AdvanceMAMEPath should not include the EXE,
# just the full path to where AdvanceMAME is located. Specify the EXE
# in AdvanceMAMEExe
UseAdvanceMAME=False
AdvanceMAMEExe=advmame.exe
AdvanceMAMEPAth=C:\Emulators\AdvanceMAME
AdvanceMameOptions=-device_video_output fullscreen -quiet -dir_rom "C:\Emulators\Mame32\roms"
# The following settings are used if you wish to use the Zinc Emulator
# (http://www.emuhype.com/)
# for launching games based on the 3D SONY Playstation
# hardware instead of MAME.
# The Zinc Emulator runs these games much better than MAME, and most
# will run full speed with full sound on modern hardware.
# Zinc use should appear seemless in GameEx
# and the games will appear as normal in the lists. The game has to be at
# least partially supported by MAME, to appear in the list, and the ROMS
# must be in the MAME ROM Directory specified above.
# Therefore don't specify the --roms-directory option in ZincOptions.
# Note: ZincPath should not include the EXE, just the full path to where
# Zinc is located. Specify the EXE in ZincEXE.
UseZinc=False
ZincEXE=zinc.exe
ZincPath=C:\Emulators\ZiNc
ZincOptions=--renderer=.\renderer.znc
# The font to use
# Verdana is recommended for Arcade Cab setups. Trebuchet MS is recommended
# for Media Center setup - and set DisplayBackgroundImage to true,
# Outline Fonts False
FONT=Trebuchet MS
# The text that displays at the top of the screen when not in arcademode
TitleText=MAME Games
# Only list MAME games where the driver is known to be fully working.
# In addition AllowImperfect allows a driver status of "IMPERFECT" to
# pass as working. In newer versions of MAME, games such as Galaga have
# a Driver Status as IMPERFECT although run very well. Set AllowImperfect
# to True to allow these games not to be filtered when OnlyWorking is set
# to True. Default for AllowImperfect is True
OnlyWorking=True
AllowImperfect=True
# Verify your MAME roms, and don't include if bad. This makes updating the
# game list slow.
VerifyRoms=True
# Only list MAME games that you have on your hard disk rom directory.
OnlyRoms=False
# Dont Display game Version (Bracketed) info in the game list.
# For example if set to true '720 Degrees (rev 1)' Will appear in the
# list as '720 Degrees'. This is useful if running at a low resolution,
# as text won't get truncated. Use in conjuction with NoClones=True, to
# create a very clean looking list.
NoGameInfo=False
# Apply a filter to the MAME game list. Seperate words to filter on with
# a semi colan. Any game name descriptions that contain these words will
# not be shown in the game list if the GameFilterOn setting is enabled.
GameFilter=Japan;Korea;Asia;Hispanic;Bootleg;French;German;Hack;Prototype;H
rdware
GameFilterOn=True
# The following option when set to True will NOT add Adult Games to the
# list, and these games will not be available from the front end after
# doing an update list. Default is false
NoAdult=False
# Don't add clones to the list if True. Default is false.
# Use in conjuction with NoGameInfo=True to
NoClones=1
# Command Line options for when launching MAME.
# Tip if running on Media Center and on a widescreen TV,
# set '-resolution widthXheight' to your preffered widescreen resolution.
# It's also a good idea to set '-effect sharp' especially if
# using ArcadeVGA
MameOptions=-triplebuffer -nowindow -joy -skip_gameinfo
# Turn ArcadeMode on even if displaying at a suitable resolution
ArcadeMode=False
# Use Large Fonts in Arcade Mode. Don't use a lower size font,
# and use standard font sizes. This is recommended if
# using ArcadeMode at a resolution above 640 x 288. Default is false.
UseLargeFonts=True
# Location to your snapshots for MAME. JPG and PNG are supported
# You can also specify a ZIP file containing the images
snappath=C:\Emulation\Arcade\Mame32\snap
# AVISnapPath. The folowing settings allow you to play videos in place of
# snapshots. Specify the path of the AVI files. If an avi file is found
# for a ROM it will be played instead of showing the snap.
# Go to http://tomspeirs.com/gameex for information on
# where to get game videos for MAME
AVISnapPath=C:\Emulation\Arcade\Mame32\avisnap
# AVI's are a little slow if played every frame. Set the following to
# only update the video every n screen updates. Default is 5.
AVIFrameSkip=0
# Location of Flyer Images. JPG and PNG are supported
flyerpath=C:\Emulation\Arcade\Mame32\flyers
# Location of Cabinet Images. JPG and PNG are supported.
cabinetpath=C:\Emulation\Arcade\Mame32\cabinets
# Location of Catver.ini (www.catver.com & www.mameworld.com/catlist)
# Which provides game category information for your MAME games
CatverLocation=\DATA\catver.ini
# Location of nplayers.ini (http://nplayers.arcadebelgium.be)
# Which provides GameEx with a list of MAME multiplayer Simultaneous games.
# A list that only contains MAME multiplayer Simultaneous games is only
# available if EnableStartPage is set to True. Default is data\nplayers.ini
nplayerslocation=\DATA\nplayers.ini
# Location of History.dat (www.arcade-history.com)
# Which provides game description information (where available)
# for your MAME games. Default is DATA\history.dat
HistoryLocation=\DATA\history.dat
# Location of MameInfo.dat (www.mameworld.net/mameinfo)
# Which provides game recommended games information (where available)
# for your MAME games. Default is DATA\mameinfo.dat
InfoLocation=\DATA\mameinfo.dat
# Show Game Information Page after selecting a game. True or False.
# If not set to true, game will launch straight away, otherwise game
# information and recommended games will display. Recommended Games
# are selectable, and playable. The Game info page will also allow you to
# view a games flyer and cabinet image.
# If set to true, GameEx will use MAMEInfo.dat and History.dat when updating
# The game list. The default is True
ShowGameInfoPage=True
# Enable Start Page. Setting the following setting to True will enable the
# Start page. If configured you can select other
# Emulators and game lists from this start page. There are also options
# To restart and shutdown the PC (If DisableExit is not on).
# If set to false, GameEx will resort back to being MAME only, and display
# the last used list. Default is True
EnableStartPage=True
# If EnableStartPage is set to True, the following setting determines if the
# Start Page is shown first after launching GameEx, or whether the last used
# list is shown. Set ShowStartPageFirst to True to always show the Start
# Page first if the Start Page is enabled. Set the setting to False, to
# show the last used list after launching GameEx. The default is True
ShowStartPageFirst=True
# Skip the Intro animation. True or false
skipintro=False
# AntiAlias Fonts. Looks nice at higher resolutions
# This is automatically set to false if ArcadeMode is on, or resolution is
# less than 640 x 480
AntiAliasFonts=True
# Outline fonts. Puts a black edge around the fonts used. Deffinitly
# recommended for an Arcade Monitor.
OutlineFonts=False
# Display Background image. If set to True displays a Blue gradiented image
# in the background. Looks nice, on a PC or TV,
# This also makes GameEx look similar to Windows Media Center.
# set this to DisplayBackgroundImage=snap, to make Snap images the
# background and make the backgrounds of the menus transparent.
# Set to false to display a Black background.
DisplayBackgroundImage=True
# Snap/Image Brightness. If DisplayBackground is set to snap, then
# this next value controls the screen brightness of the images displayed.
# Enter a value 0 - 255
SnapBrightness=140
# Music Playlist file. MP3 and OGG files are supported.
# The file should be a simple list of file locations to audio files.
# Do not surround the paths in the file with quotes.
# You can also specify a directory here, and on startup GameEx will scan
# this directory and all sub directories for compatible audio files.
# If you choose a directory, GameEx will generate a playlist file for you
# and you can then use this to save future startup time once it is created.
# It is created in the GameEx\Data directory and called playlist.txt.
# MusicPlayList=L:\-DATA-\-MP3-\
MusicPlayList=C:\Music
# Volume Level of music playback 0 - 100
MusicVolume=63
# Media Center Exit & Start Mode. If running on Windows XP Media Center
# Handles how Media Center is exited from and restarted. Media Center will
# not launch on exit if not open when GameEx is launched.
# Values supported are:
# 0:
# No Media Center use or interaction. In other words
# Your not using Windows XP Media Center
# 1:
# Send Pause Command to Media Center when Launching GameEx, and send
# Play Command when exiting GameEx. this will Pause Live TV, or pause any
# Radio or Music Playing. This also Takes Media Center back to the start
# page. If using 1 then set the -noswitchbpp in the MAME options, as
# Media Center does not like running below 32 bit colour. There are a few
# Issues with this mode. If you have problems, use mode 2.
# 2:
# Close Windows Media Center completely before running GameEx. Then launch
# Again when exiting GameEx
MediaCenterMode=2
# Plays Intro Sound on Startup
PlayIntroSound=True
# Attract Mode ScreenSaver. Timer to wait for Attract Mode screensaver in
# minutes if no interface input. If the timer is reached, attract mode
# starts and runs a random game every couple of minutes.
# set to 0 to disable. Default is 4 minutes
AttractModeTimer=4
# Attract Mode Audio. Controls what audio is heard when Attract Mode
# is running. Default is 2.
# 0:
# Play GameEx playlist audio and run MAME with sound
# 1:
# Pause playlist audio and run MAME with sound
# 2:
# Play GameEx Playlist audio and run MAME with no sound
# 3:
# Pause GameEx Playlist audio and run MAME with no sound
AttractModeAudio =2
# ArcadeVGA Resolution Settings. If using an ArcadeVGA card from Ultimarc,
# The following settings can be used to automatically run games at the
# best resolutions. Set UsingArcadeVGA to true if using an ArcadeVGA card.
# Set StrechResToX and StretchResToY to the resolution to
# stretch games to if a game runs at a height above 288, or would display
# interlaced. Set TryToStretchTo256 to try and find a
# resolution with a height of 256 first before
# using the StretchResToX/Y resolution, and stretch to
# ResToX/Y only if a resolution above 256 is found.
# If your Arcade Monitor rolls, or significantly stretches with a resoluton
# height of 288, set TryToStretchto256 True. If your Monitor
# supports a resolution of 288 then set StretchResTox/Y
# to 640 x 288 and TryToStretchto256 off, ortherwise use 632 x 264 or a 256
# Y Resolution and turn TryToStretchto256 on.
UsingArcadeVGA=False
StretchResToX=640
StretchResToY=288
TryToStretchto256=True
# Normally GameEx waits for a vertical Sync of the display before drawing
# to the screen. This should offer smooth animation on fast PC's, and is
# normally recommended. Although Waiting for a VSync takes up CPU cycles.
# It may also be a little pointless to wait for a Vsync on older PC's where
# GameEx runs slowly anyway. Setting NoWaitVSync to true will make GameEx
# Update the screen whenever it can, and may make GameEx run a little
# faster. Also if used in conjuction with Sleep, you can claim back more
# CPU cycles from GameEx.
NoWaitVSync=False
# If you have critical processes running at the same time as GameEx, such
# as TV/Video Capture/Encoding, you can specify a value for Sleep in
# Milliseconds, and GameEx will give this time back to the CPU just before
# updating the screen. A value of 0 disables this setting and is the default.
# If you feel you must use this setting, a value no higher than 20 is
# recommended, otherwise you will really start to see a slow down of GameEx.
# Default is 0.
Sleep=0
# The following three options are mainly for Arcade Cabinets running in
# Public
# or Commercial places, or where children have access. When set to true
# HideUpdateList hides and disables the Update List button in GameEx, and
# DisableExit disables exiting from GameEx, and hides the shutdown button
# on the Start Page. If this last option is set
# to True the only way to exit GameEx will be to use CTRL-ALT-DELETE, or
# Shut down/Restart the PC. If you wish to be able to exit from GameEx,
# But not allow shutting down of the PC from the Start Page, then set
# HideShutDown to True
# Default for all three is False.
HideUpdateList=True
DisableExit=False
HideShutDown=True
# Specify a Video to play at Startup. AVI, MPG:
StartupVideo=C:\Video
LaunchOnStart=
LaunchOnStartNoWait=
LaunchOnExit=
LaunchOnExitNoWait=
FontSize=0
VectorResX=632
VectorResY=264
AlwaysStretch=410x256
DisableEscape=False
DisableRemoveGame=False
Theme=Default - MameEx 1024x768
Language=English
FlatStartPage=True
DontSwitchRes=False
SnapDelay=2
AllowWindowResize=True
ShowLoadingScreen=True
Use16BitColour=False
Widescreen=False
DisableMAME=False
ShellBeforeLaunch=
ShellOnExit=
EnableJukeBox=True
JukeBoxPlaylist=Every Breath You Take (The Singles)
EnableMediaControls=True
ShufflePlayLists=True
LoadPlayListAtStartup=False
LoadPlayListThread=False
DownloadArt=True
TitleFont=Trebuchet MS
DialogTextWhite=False
TimeFormat=True
HideToolBar=3
DoNotFilterROMS=pacman;splatter
MAMEAudioMode=1
DisplayTitle=True
AVIAudio=False
Marqueepath=C:\Emulation\Arcade\Mame32\marquees
Panelpath=C:\Emulation\Arcade\Mame32\cpanel
Titlepath=C:\Emulation\Arcade\Mame32\titles
ICONpath=C:\Emulation\Arcade\Mame32\icons
CPEnabled=True
CPPath=\data\controls.ini
ShowVector=False
ShowNeoGeo=False
ShowOriginal=False
ShowAdult=False
ShowCPS=False
ShowVertical=False
ShowHorizontal=False
EnableFavorites=False
ShowMulti=False
ShowAllMAME=False
ShowLastGame=False
ShowRandomGame=False
ShowListNumbers=True
AlphaBlendVideos=True
EnableSound=False
MediaCenterOpenCheck=true
UseSharp=True
CreateImageOnThread=False
HideCreateSnaps=False
HideLogoff=True
HideStandBy=True
DisableMouse=True
ShowVideos=False
VideoPath=C:\Video
EnableAlphaPage=True
EnableJoystick=True
EnableSlikStik=False
KeyboardDirectInput=False
NoMahjong=True
VIDEOFFDSHOW=0
JoystickDevice=
EnableCustomInput=True
EnableCustomJoyInput=False
AttractVideosEnabled=True
AttractVideosRatio=1
AttractVideosPath=C:\Video
AtractModeNewGameTimer=2
AdvancedGFX=True
HideZinc=False
TransitionType=1
Bypass=True
DontBlitWait=False
ShowMostPlayed=False
ExcludedMAMERoms=
DeadZoneX=0
DeadZoneY=0
JukeBoxMode=2
AmbienceFile=L:\-DATA-\-MP3-\4 Non Blondes\4 Non Blondes - What's Up.mp3
AmbianceFile=C:\arcade.mp3
EnableAmbiance=False
HIDEDESKTOP=False
UseSnapBestMatch=true
IngameVK=45
EnableThemePicker=False
DisablePleaseWaitAnimation=False
EnableRipCD=False
DumbyValue=
DVDPath=G:\
AttractOnlyFavs=False
RotatePlus90=False
ShowButtons=False
DisplayTitleText=True
PlayExitSaverSound=False
ShowAtari=False
ShowGolden=False
ShowHorizVert=0
UseModel2=False
Model2PATH=C:\Emulators\Model2
ShowModel2=False
ShowLightGun=False
EnableBezel=True
AutoUpdate=True
NoMAMEOnStartPage=True
HideRestart=True
EnableStartScreenSaver=False
SortMAMEThE=True
SortEmuThE=True
ShowMCEEXport=False
NoRotationRestrictions=False
MakeToolbarTextWhite=False
ExitGameAfter=0
ShowTrackball=False
ShowSpinner=False
LoadEmusOnThread=True
LoadRadioOnThread=False
StartPageAni=True
EmusAttractMode=False
MuteEmuAttractMode=False
Show4Player=False
CabControlFriendly=False
ManualPath=C:\Emulation\Arcade\Mame32\manuals
HideShowTaskbar=True
CustomMAMEFolderPath=C:\Emulation\Arcade\Mame32\CustomFolders
MAMEFavoritesini=C:\Emulation\Arcade\Mame32\Folders\Favorites.ini
MenuFontSameSize=False
SetPalRes=False
PalRes=800x600x32x60
SetNTCSRes=True
NTSCRes=800x600x32x60
SetNTSCRes=False
SetTwoThreeRes=False
PreviewVideos=True
ShowStatistics=False
DisableMouseWheel=False
ErrorReporting=0
ReduceCPU=True
ShowNotPlayed=False
ShowOnlineLists=False
ScreensaverMode=0
glaunchenabled=False
PCBPath=C:\Emulation\Arcade\Mame32\pcb
artworkpath=C:\Emulation\Arcade\Mame32\avisnap
LoadJukeTracksOnStartup=True
EnableLetterSelect=True
JukeQueueMode=0
EnableBezelAttract=True
ForceDailyReboot=-1
EnableSearch=False
FixToEmuList=0
ShowLastPlayed=False
[Daphne]
# (http://www.daphne-emu.com/)
# Daphne is a an arcade Laserdisc emulator, that allows playing of
# games such as Dragon's Lair and Space Ace.
# The following options enable GameEx to act as a Daphne front end
# and presents a list of Daphne games that can be selected from the Start
# Page. DaphnePath, and DapnheSnaps should contain the full path to where
# the Daphne ExE is located (path only), and the path to snaps to use.
# Daphne EXE is the daphne executable file (without the path).
# DaphneSnap is the location of Snap Images
# DapnheOptions are the global command line options applicable to all games.
# Set UseDapnhe to true to enable Daphne support in GameEx
UseDaphne=False
DaphnePath=C:\Emulators\Daphne
DaphneExe=Daphne.exe
DaphneSnap=C:\Emulators\Daphne\images
DaphneOptions=vldp -fullscreen -x 640 -y 480 -nohwaccel
# Set up the following options for each Daphne Game. Suffix the end of the
# option with an underscore and a number between one and 30. With Each
# game having a seperate number.
# ROMName is the ROM filename
# GameName is the friendly name shown in the GameEx list
# GameOptions are the specific command line options for each game
# Enabled is true or false and whether the game will appear in the list.
Enabled_1 =True
ROMName_1 =lair
GameName_1 =Dragon's Lair
GameOptions_1 =-framefile j:\daphne\mpeg\dl_framefile.txt
Enabled_2=True
ROMName_2 =sae
GameName_2 =Space Ace
GameOptions_2 =-framefile j:\daphne\mpeg\ace_framefile.txt
Enabled_3=True
ROMName_3 =astron
GameName_3 =Astron Belt
GameOptions_3 =-framefile j:\daphne\mpeg\abelt_framefile.txt
Enabled_4=True
ROMName_4 =cliff
GameName_4 =Cliff Hanger
GameOptions_4 =-framefile j:\daphne\mpeg\cliff_framefile.txt
Enabled_5=True
ROMName_5 =cobraab
GameName_5 =Cobra Command
GameOptions_5 =-framefile j:\daphne\mpeg\cc_framefile.txt
Enabled_6=False
ROMName_6=cobraab
GameName_6=Cobra Command
GameOptions_6=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_7=False
ROMName_7=cobraab
GameName_7=Cobra Command
GameOptions_7=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_8=False
ROMName_8=cobraab
GameName_8=Cobra Command
GameOptions_8=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_9=False
ROMName_9=cobraab
GameName_9=Cobra Command
GameOptions_9=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_10=False
ROMName_10=cobraab
GameName_10=Cobra Command
GameOptions_10=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_11=False
ROMName_11=cobraab
GameName_11=Cobra Command
GameOptions_11=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_12=False
ROMName_12=cobraab
GameName_12=Cobra Command
GameOptions_12=-framefile h:\daphne\mpeg\cc_framefile.txt
GameName_23=
Enabled_13=False
ROMName_13=
GameName_13=
GameOptions_13=
Enabled_14=False
ROMName_14=
GameName_14=
GameOptions_14=
Enabled_15=False
ROMName_15=
GameName_15=
GameOptions_15=
Enabled_16=False
ROMName_16=
GameName_16=
GameOptions_16=
Enabled_17=False
ROMName_17=
GameName_17=
GameOptions_17=
Enabled_18=False
ROMName_18=
GameName_18=
GameOptions_18=
Enabled_19=False
ROMName_19=
GameName_19=
GameOptions_19=
Enabled_20=False
ROMName_20=
GameName_20=
GameOptions_20=
Enabled_21=False
ROMName_21=
GameName_21=
GameOptions_21=
Enabled_22=False
ROMName_22=
GameName_22=
GameOptions_22=
Enabled_23=False
ROMName_23=
GameOptions_23=
DaphneFlyer=C:\Emulators\Daphne\flyers
DaphneCabinet=C:\Emulators\Daphne\cabinets
DaphneTitle=C:\Emulators\Daphne\titles
DaphneMarquee=C:\Emulators\Daphne\marquees
DaphnePanel=C:\Emulators\Daphne\cpanel
UseGamepad=False
[Internal]
# These settings are used internally by GameEx
# They are used to do things such as remember where you were upto in lists
# and the Current Playlist position.
# It is recommended you do not change anything here.
PlayListPosition=2
SelectedGame=1
GameListTop=1
GameListType=0
YearListTop=1
CatListTop=1
ManuListTop=1
YearSelectedGame=1
CatSelectedGame=1
ManuSelectedGame=1
NameListTop=1
NameSelectedGame=2
Emulator=2
VideoAspect=0
csv=C:\Program Files\GameEx\config\config.csv
ini=C:\Program Files\GameEx\config\gameex.ini
ControlHeight=34
ControlSpacing=8
FontSize=17
CSVType=comma
nextaction=onepage
Windowed=False
windowx=408
windowy=203
windowwidth=640
windowheight=480
CurrentStation=
CurrentStationURL=
MAMEEXE=
MAMEPATH=C:\Emulation\Arcade\Mame32
ExtenderCapable=0.1
ViewAlbumType=1
JukeBoxDirModifiedDate=21/08/2006 12:49:07
EMU_4LastFolderWrite=15/02/2007 22:39:33
EMU_4_DBCACHEModified=16/07/2007 03:48:26
EMU_3LastFolderWrite=21/09/2006 05:19:50
EMU_5LastFolderWrite=20/12/2007 12:34:15
MAMEFileModified=4/27/2008 10:27:47 AM
MAMEFileSize=38964736
MAMEPromptUpdate=True
BezelVersion=2
EMU_3LastRomFilter=*.vpt
EMU_3_DBCACHEModified=06/10/2006 12:51:48
EMU_3_LastNumGames=214
EMU_5LastRomFilter=*.bin
EMU_2LastFolderWrite=22/04/2008 22:03:30
EMU_2LastRomFilter=*.*
EMU_2_DBCACHEModified=12/11/2007 01:55:04
EMU_2_LastNumGames=462
EMU_2_Enabled=True
EMU_2_StartPageName=Nintendo SNES games
EMU_2_TitleText=SNES
EMU_2_StartPageLogo=snes
EMU_2_RomFilter=*.*
EMU_2_RomsInFolders=False
EMU_2_ROMPath=G:\-DATA-\-DESKTOP-\- 2006 -\Desktop Upto 2nd September 2006\SNESMerge
EMU_2_SnapPath=G:\zsnes\titles
EMU_2_WorkingPath=G:\ZSNES
EMU_2_MapKeys=True
EMU_2_ReplaceDash=False
EMU_2_ReplaceUnder=True
EMU_2_Capitals=True
EMU_2_RemoveBrackets=True
EMU_2_ShowDesktop=True
EMU_2_Debug=False
EMU_2_OLDatZip=C:\Program Files\OfflineList0.7\datas\snes_OL.zip
EMU_2_Command=Zsnesw.exe [QUOTE][ROMPath]\[RomFile][QUOTE]
EMU_2_TitlePath=G:\zsnes\titles
EMU_2_BoxPath=G:\zsnes\Boxscans_SNES_(USA)_28May04
EMU_2_CartPath=G:\zsnes\CartScans SNES USA
EMU_2_configFile=ZSNES V2
EMU_2_PCGame=False
EMU_2_GamesIn7Zips=True
EMU_2_LastGame=False|2|Donkey Kong Country|Donkey Kong Country.7z|Donkey Kong Country|Action/Adventure|3
EMU_2_PlayInScreenSaver=True
EMU_5_RomFilter=*.bin
EMU_5_RomsInFolders=False
EMU_5_ROMPath=E:\stella\roms
EMU_5_WorkingPath=e:\Stella
EMU_5_MapKeys=True
EMU_5_ReplaceDash=True
EMU_5_ReplaceUnder=True
EMU_5_Capitals=True
EMU_5_RemoveBrackets=True
EMU_5_ShowDesktop=True
EMU_5_Debug=False
EMU_5_Command=stella.exe -fullscreen 1 [QUOTE][ROMPath]\[RomFile][QUOTE]
EMU_5_PlayInScreenSaver=True
EMU_5_ManualPath=e:\stella\manuals
ListType=8
EMU_1LastFolderWrite=15/02/2007 22:37:05
EMU_1LastRomFilter=*.zip
EMU_1_DBCACHEModified=11/11/2007 04:14:42
EMU_1_LastNumGames=1013
EMU_1_RomFilter=*.zip
EMU_1_RomsInFolders=False
EMU_1_ROMPath=G:\-DATA-\-ROMS-\N64GOOD
EMU_1_WorkingPath=G:\project64
EMU_1_MapKeys=True
EMU_1_ReplaceDash=True
EMU_1_ReplaceUnder=False
EMU_1_Capitals=True
EMU_1_RemoveBrackets=True
EMU_1_ShowDesktop=True
EMU_1_Debug=False
EMU_1_OLDatZip=C:\Program Files\OfflineList0.7\datas\n64_OL.zip
EMU_1_Command=Project64.exe [ROMPath]\[RomFile]
EMU_1_configFile=Project 64 V2
EMU_1_DATABASE=[Console] Nintendo N64
EMU_1_PlayInScreenSaver=True
EMU_5_DontShowInfo=False
VGenre=---
EMU_4LastRomFilter=*.zip
EMU_4_LastNumGames=10132
EMU_5_CDCheck=False
EMU_4_RomFilter=*.zip
EMU_4_RomsInFolders=False
EMU_4_ROMPath=G:\-DATA-\-ROMS-\NES ROMS
EMU_4_WorkingPath=G:\
EMU_4_MapKeys=True
EMU_4_ReplaceDash=True
EMU_4_ReplaceUnder=True
EMU_4_Capitals=True
EMU_4_RemoveBrackets=True
EMU_4_ShowDesktop=True
EMU_4_Debug=False
EMU_4_Command=nesemu2.exe [ROMPath]\[RomFile]
EMU_4_DATABASE=NES
EMU_4_GamesIn7Zips=False
EMU_4_PlayInScreenSaver=True
TimesRunCount=0
EMU_9LastFolderWrite=18/03/2007 21:07:22
EMU_9LastRomFilter=*.*
EMU_9_ROMFilter=*.*
EMU_9_RomsInFolders=True
EMU_9_RomPath=C:\
EMU_9_WorkingPath=c:
EMU_9_MapKeys=True
EMU_9_ReplaceDash=True
EMU_9_ReplaceUnder=True
EMU_9_Capitals=True
EMU_9_RemoveBrackets=True
EMU_9_ShowDesktop=True
EMU_9_Debug=True
EMU_9_Command=notepad.exe
EMU_9_configFile=Test
EMU_9_PlayInScreenSaver=True
Version=9.25
EMU_1_PlaySelectionMusic=True
EMU_1_SelectionMusicFolder=G:\-DATA-\-MP3-\ACDC
EMU_2_PlaySelectionMusic=True
EMU_2_SelectionMusicFolder=C:\tmp
LastGlaunchList=0
GLaunchListSelected_17=5
GLaunchListTop_17=1
GLaunchListSelected_16=15
GLaunchListTop_16=1
GLaunchListSelected_15=2
GLaunchListTop_15=1
GLaunchListSelected_0=1
GLaunchListTop_0=1
GLaunchListSelected_1=97
GLaunchListTop_1=81
GLaunchListSelected_2=4
GLaunchListTop_2=1
GLaunchListSelected_14=75
GLaunchListTop_14=59
GLaunchListSelected_13=11
GLaunchListTop_13=1
GLaunchListSelected_12=7
GLaunchListTop_12=1
GLaunchListSelected_11=2
GLaunchListTop_11=1
GLaunchListSelected_10=2
GLaunchListTop_10=1
GLaunchListSelected_9=1
GLaunchListTop_9=1
GLaunchListSelected_8=1
GLaunchListTop_8=1
GLaunchListSelected_7=1
GLaunchListTop_7=1
GLaunchListSelected_6=13
GLaunchListTop_6=1
GLaunchListSelected_5=21
GLaunchListTop_5=5
GLaunchListSelected_4=12
GLaunchListTop_4=1
GLaunchListSelected_3=29
GLaunchListTop_3=13
GLaunchListSelected_18=1
GLaunchListTop_18=1
GLaunchListSelected_40=1
GLaunchListTop_40=1
GLaunchListSelected_39=1
GLaunchListTop_39=1
EMU_5_DATABASE=[Console] Atari 2600
EMU_5_DBCACHEModified=09/10/2007 00:38:42
EMU_5_LastNumGames=2687
EMU_2_DBCACHELastName=[Console] Nintendo SNES
EMU_1_DBCACHELastName=[Console] Nintendo N64
EMU_5_DBCACHELastName=[Console] Atari 2600
EMU_5_ControlPanelPath=E:\stella\snaps
EMU_5_InstructionsPath=E:\stella\snaps
EMU_2_DATABASE=[Console] Nintendo SNES
CatFilter=
ManuFilter=
YearFilter=
ROMName=canyon
ROMName2=joustwr
SpecialFilter=
OPTIMIZED=0
[DVD]
EnableDVD=False
Codec=0
DVDFFDSHOW=0
EnableDVDDisk=False
DVDPath=C:\DVD
UseVMR9=False
[Pictures]
PicturesEnabled=False
Paths=C:\Pictures
UseAlphaBlend=True
SlideDuration=12
[News]
URL_1=http://rss.news.yahoo.com/rss/topstories
URL_2=http://www.mameworld.net/mt/index.xml
URL_3=http://rss.news.yahoo.com/rss/tech
URL_4=http://slashdot.org/index.rss
URL_5=http://www.penny-arcade.com/RSS.xml
URL_6=http://www.emulator-zone.com/rss_news.php
URL_7=http://blog.seanalexander.com/SyndicationService.asmx/GetRssCategory?categoryName=XP%20Media%20Center
URL_8=http://www.mediacenterpcworld.com/news_rss.xml
URL_9=http://msdn.microsoft.com/rss.xml
URL_10=http://www.mameworld.net/maws/mawshof.xml
URL_11=
URL_12=
URL_13=
URL_14=
URL_15=
URL_16=
URL_17=
URL_18=
URL_19=
URL_20=
URL_21=
URL_22=
URL_23=
URL_24=
URL_25=
URL_26=
URL_27=
URL_28=
URL_29=http://tomspeirs.com/gameex/gameexnews.xml
URL_30=http://www.gameex.info/forums/index.php?act=rssout&id=1
Enabled=False
[Radio]
RadioEnabled=False
Enabled_5=True
Name_5=Kohina - old school game & demo
URL_5=http://acamar.org:8000/listen.pls
Enabled_6=True
Name_6=Bangkok Radio
URL_6=http://64.62.253.55/bangkok64
Enabled_7=True
Name_7=Kohina - Fresh Tracks
URL_7=http://anka.org:8080/fresh.ogg.m3u
Enabled_4=True
Name_4=Delta Uno
URL_4=http://www.deltauno.it/home/delta1.asx
Enabled_1=
Name_1=
URL_1=
Enabled_2=
Name_2=
URL_2=
Enabled_3=
Name_3=
URL_3=
Enabled_8=
Name_8=
URL_8=
Enabled_9=
Name_9=
URL_9=
Enabled_10=
Name_10=
URL_10=
Enabled_11=
Name_11=
URL_11=
Enabled_12=
Name_12=
URL_12=
Enabled_13=
Name_13=
URL_13=
Enabled_14=
Name_14=
URL_14=
Enabled_15=
Name_15=
URL_15=
Enabled_16=
Name_16=
URL_16=
Enabled_17=
Name_17=
URL_17=
Enabled_18=
Name_18=
URL_18=
Enabled_19=
Name_19=
URL_19=
Enabled_20=
Name_20=
URL_20=
Enabled_21=True
Name_21=Capital Gold
URL_21=mms://ms1.capitalinteractive.co.uk/gold_high
Enabled_22=True
Name_22=Slay Radio
URL_22=http://relay.slayradio.org:8000/listen.pls
Name_23=XFM
URL_23=http://rope.icgo.fimc.net/staticweb/onair_players/onair_xfm_abacast/player/onair_xfm.asx
Enabled_23=True
Name_24=Radio Woodstock
URL_24=http://nick8.surfernetwork.com/Media/RWST.asx
Enabled_25=True
Name_25=Club 977 Alternative
URL_25=http://www.977alt.com/977alt.asx
Enabled_26=True
Name_26=Radio Paradise
URL_26=http://www.changeip.com/radio/rp_128.asx
Enabled_27=True
Name_27=Hitz Radio
URL_27=http://www.hitzradio.com/hitzradio.asx
Enabled_28=True
Name_28=Club 977
URL_28=http://www.club977.com/club977.asx
Enabled_29=True
Name_29=9412 Rock Station
URL_29=http://www.9412.com/9412.asx
Enabled_30=True
Name_30=Power Hitz
URL_30=http://www.powerhitz.com/powerhitz.asx
Enabled_31=True
Name_31=Radio Wazee
URL_31=http://www.wazee.org/128.asx
Enabled_32=True
Name_32=The Edge Radio
URL_32=http://mfkrboard.com/edgeradio/edge.m3u
Enabled_33=True
Name_33=WFUV 90.7 FM Public Radio
URL_33=http://www.wfuv.org/wfuvlive.asx
Enabled_34=False
Name_34=Pirate Radio
URL_34=http://www.loudcity.net/Portals/0/LCPlayLists/90/123.asx
Enabled_35=True
Name_35=EYE 97
URL_35=http://www.loudcity.net/Portals/0/LCPlayLists/157/eye97.asx
Enabled_36=True
Name_36=Hit Music Station
URL_36=http://www.hitmusicstation.net/ecoute_haut_debit.m3u
Name_37=Radio IO 80's
URL_37=http://radioio.sc.llnwd.net:8240
Enabled_24=
Enabled_37=True
Enabled_80=True
Url_80=FAVREMOVE
Enabled_81=True
Url_81=FAVREMOVE
Enabled_82=True
Url_82=FAVREMOVE
Enabled_83=True
Url_83=FAVREMOVE
Enabled_84=
Name_84=
Url_84=
Enabled_85=
Name_85=
Url_85=
[HTMLApplications]
Enabled_1=False
URL_1=http://10foot.cbuenger.com/mceWeather/index.php?start=1〈=2
Name_1=Weather
Logo_1=Weather
MouseEmu_1=False
Enabled_2=False
URL_2=http://gameex.net
Name_2=GameEx homepage
Logo_2=
MouseEmu_2=False
Enabled_3=False
URL_3=http://10foot.cbuenger.com/mceWeather/index.php?start=1〈=2
Name_3=Weather
Logo_3=Weather
MouseEmu_3=False
Enabled_4=False
URL_4=
Name_4=
Logo_4=
MouseEmu_4=False
Enabled_5=False
URL_5=
Name_5=
Logo_5=
MouseEmu_5=False
Enabled_6=False
URL_6=
Name_6=
Logo_6=
MouseEmu_6=False
UseHTMLApps=
[ExternalApplications]
Enabled_99=False
Name_99=Configuration
Path_99=[apppath]
CMD_99=GameExConfig.exe
Snap_99=GameExText
ShowDesktop_99=True
MapKeys_99=False
WaitBeforeKeys_99=
SendKeys_99=
Enabled_2=False
Name_2=Notepad
Path_2=c:\windows
CMD_2=notepad.exe
Snap_2=GameExText
ShowDesktop_2=False
MapKeys_2=False
WaitBeforeKeys_2=
SendKeys_2=
Enabled_3=False
Name_3=Mad Dog McCree
Path_3=G:\Mad_Dog_mcCree
CMD_3=G:\Mad_Dog_mcCree\mdm.exe
Snap_3=GameExText
ShowDesktop_3=False
MapKeys_3=True
WaitBeforeKeys_3=4000
SendKeys_3=F
Enabled_1=False
name_1=Close And Restart GameEx
path_1=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
cmd_1=CloseAndRestartGameEx.bat
snap_1=
showdesktop_1=False
mapkeys_1=False
WaitBeforeKeys_1=
SendKeys_1=
Enabled_4=False
name_4=
path_4=
cmd_4=
snap_4=
showdesktop_4=False
mapkeys_4=False
WaitBeforeKeys_4=
SendKeys_4=
Enabled_5=False
name_5=
path_5=
cmd_5=
snap_5=
showdesktop_5=False
mapkeys_5=False
WaitBeforeKeys_5=
SendKeys_5=
Enabled_6=False
name_6=
path_6=
cmd_6=
snap_6=
showdesktop_6=False
mapkeys_6=False
WaitBeforeKeys_6=
SendKeys_6=
Enabled_7=False
name_7=
path_7=
cmd_7=
snap_7=
showdesktop_7=False
mapkeys_7=False
WaitBeforeKeys_7=
SendKeys_7=
Enabled_8=False
name_8=
path_8=
cmd_8=
snap_8=
showdesktop_8=True
mapkeys_8=True
WaitBeforeKeys_8=
SendKeys_8=
Enabled_9=False
name_9=
path_9=
cmd_9=
snap_9=
showdesktop_9=True
mapkeys_9=True
WaitBeforeKeys_9=
SendKeys_9=
Enabled_10=False
name_10=
path_10=
cmd_10=
snap_10=
showdesktop_10=True
mapkeys_10=True
WaitBeforeKeys_10=
SendKeys_10=
Enabled_11=False
name_11=
path_11=
cmd_11=
snap_11=
showdesktop_11=True
mapkeys_11=True
WaitBeforeKeys_11=
SendKeys_11=
Enabled_12=False
name_12=
path_12=
cmd_12=
snap_12=
showdesktop_12=True
mapkeys_12=True
WaitBeforeKeys_12=
SendKeys_12=
Enabled_13=False
name_13=
path_13=
cmd_13=
snap_13=
showdesktop_13=True
mapkeys_13=True
WaitBeforeKeys_13=
SendKeys_13=
Enabled_14=False
name_14=
path_14=
cmd_14=
snap_14=
showdesktop_14=True
mapkeys_14=True
WaitBeforeKeys_14=
SendKeys_14=
Enabled_15=False
name_15=
path_15=
cmd_15=
snap_15=
showdesktop_15=True
mapkeys_15=True
WaitBeforeKeys_15=
SendKeys_15=
Enabled_16=False
name_16=
path_16=
cmd_16=
snap_16=
showdesktop_16=True
mapkeys_16=True
WaitBeforeKeys_16=
SendKeys_16=
Enabled_17=
name_17=
path_17=
cmd_17=
snap_17=
showdesktop_17=
mapkeys_17=
WaitBeforeKeys_17=
SendKeys_17=
Enabled_18=
name_18=
path_18=
cmd_18=
snap_18=
showdesktop_18=
mapkeys_18=
WaitBeforeKeys_18=
SendKeys_18=
Enabled_19=
name_19=
path_19=
cmd_19=
snap_19=
showdesktop_19=
mapkeys_19=
WaitBeforeKeys_19=
SendKeys_19=
Enabled_20=
name_20=
path_20=
cmd_20=
snap_20=
showdesktop_20=
mapkeys_20=
WaitBeforeKeys_20=
SendKeys_20=
Enabled_21=
name_21=
path_21=
cmd_21=
snap_21=
showdesktop_21=
mapkeys_21=
WaitBeforeKeys_21=
SendKeys_21=
Enabled_22=
name_22=
path_22=
cmd_22=
snap_22=
showdesktop_22=
mapkeys_22=
WaitBeforeKeys_22=
SendKeys_22=
Enabled_24=
name_24=
path_24=
cmd_24=
snap_24=
showdesktop_24=
mapkeys_24=
WaitBeforeKeys_24=
SendKeys_24=
Enabled_25=
name_25=
path_25=
cmd_25=
snap_25=
showdesktop_25=
mapkeys_25=
WaitBeforeKeys_25=
SendKeys_25=
EmulateMouse_1=-1
EmulateMouse_2=-1
EmulateMouse_3=3
EmulateMouse_4=
EmulateMouse_5=
EmulateMouse_6=
EmulateMouse_7=
EmulateMouse_8=
EmulateMouse_9=
EmulateMouse_10=
EmulateMouse_11=
EmulateMouse_12=
EmulateMouse_13=
EmulateMouse_14=
EmulateMouse_15=
EmulateMouse_16=
EmulateMouse_17=
EmulateMouse_18=
EmulateMouse_19=
EmulateMouse_20=
EmulateMouse_21=
EmulateMouse_22=
EmulateMouse_24=
EmulateMouse_25=-1
LaunchBefore_1=
LaunchAfter_1=
AlsoLaunch_1=
LaunchBefore_2=
LaunchAfter_2=
AlsoLaunch_2=
LaunchBefore_3=
LaunchAfter_3=
AlsoLaunch_3=
LaunchBefore_4=
LaunchAfter_4=
AlsoLaunch_4=
LaunchBefore_5=
LaunchAfter_5=
AlsoLaunch_5=
LaunchBefore_6=
LaunchAfter_6=
AlsoLaunch_6=
LaunchBefore_7=
LaunchAfter_7=
AlsoLaunch_7=
[Emulator_1]
StartPageName=[Arcade] Final Burn Alpha
TitleText=Final Burn Alpha
StartPageLogo=[Arcade] Final Burn Alpha
RomFilter=
RomsInFolders=False
ROMPath=C:\Emulation\Arcade\FinalBurnAlpha\ROMs
SnapPath=C:\Emulation\Arcade\FinalBurnAlpha\screenshots
WorkingPath=C:\Emulation\Arcade\FinalBurnAlpha
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
AlsoLaunch=
ShowDesktop=True
Debug=False
MapFile=[APP]\Map Files\[Arcade] FB Alpha.map
OLDatZip=
Command=fba.exe "[Rom]"
TitlePath=C:\Emulation\Arcade\FinalBurnAlpha\titles
BoxPath=C:\Emulation\Arcade\FinalBurnAlpha\flyers
LaunchBefore=
LaunchAfter=
CartPath=C:\Emulation\Arcade\FinalBurnAlpha\previews
ExcludedFiles=
CustomBackground=
PlayMusic=False
PCGame=False
DATABASE=[Arcade] Final Burn Alpha
DumbyValue=
GamesIn7Zips=False
LastGame=
PlayInScreenSaver=False
DontShowInfo=
RandomMostPlayed=False
CDCheck=False
CDCheckFile=
PlaySelectionMusic=False
ManualPath=C:\Emulation\Arcade\Final Burn Alpha\Manuals\
ControlPanelPath=C:\Emulation\Arcade\Final BurnAlpha\Controls\
InstructionsPath=
[Emulator_2]
STARTPAGENAME=[Arcade] Kawaks
TITLETEXT=Kawaks
StartPageLogo=[Arcade] Kawaks
ROMFilter=
RomsInFolders=False
RomPath=C:\Emulation\Arcade\Kawaks\roms
SnapPath=C:\Emulation\Arcade\Kawaks\sshots
WorkingPath=C:\Emulation\Arcade\Kawaks
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=True
Debug=False
MAPFile=[APP]\Map Files\[Arcade] WinKawaks.map
AlsoLaunch=
Command="WinKawaks.exe" [Rom] -fullscreen
OLDatZip=
TitlePath=C:\Emulation\Arcade\Kawaks\
BoxPath=C:\Emulation\Arcade\Kawaks\
LaunchBefore=
LaunchAfter=
CartPath=C:\Emulation\Arcade\Kawaks\
configFile=[Mapping Off] Exit (ENTER, ALT+F4)
ExcludedFiles=
CustomBackground=
PlayMusic=False
PCGame=False
DATABASE=[Arcade] WinKawaks
DumbyValue=
GamesIn7Zips=False
ManualPath=C:\Emulation\Arcade\Kawaks\
ControlPanelPath=C:\Emulation\Arcade\Kawaks\Controls\
DontShowInfo=
CDCheck=False
CDCheckFile=
[Emulator_3]
StartPageName=[Arcade] Nebula
TitleText=Nebula
StartPageLogo=[Arcade] Nebula
RomFilter=
RomsInFolders=False
ROMPath=C:\Emulation\Arcade\Kawaks\roms
SnapPath=C:\Emulation\Arcade\Nebula\SHOTS
WorkingPath=C:\Emulation\Arcade\Nebula\
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
AlsoLaunch=
ShowDesktop=True
Debug=False
MapFile=[APP]\Map Files\[Arcade] Nebula.map
OLDatZip=
Command=Nebula.exe [Rom]
TitlePath=C:\Emulation\Assets\Arcade\Nebula\Titles\
BoxPath=C:\Emulation\Assets\Arcade\Nebula\Boxes\
LaunchBefore=
LaunchAfter=
CartPath=C:\Emulation\Assets\Arcade\Nebula\Cartridges\
ExcludedFiles=
CustomBackground=
Import=
Export=
DumbyValue=
PlayMusic=False
PCGame=False
DATABASE=[Arcade] Nebula
GamesIn7Zips=False
LastGame=
ManualPath=C:\Emulation\Assets\Arcade\Nebula\Manuals\
ControlPanelPath=C:\Emulation\Assets\Arcade\Nebula\Controls\
DontShowInfo=
CDCheck=False
CDCheckFile=
[Emulator_4]
StartPageName=[Arcade] Raine
TitleText=Raine
StartPageLogo=[Arcade] Raine
RomFilter=
RomsInFolders=False
ROMPath=C:\Emulation\Arcade\Raine\roms
SnapPath=C:\Emulation\Arcade\Raine\screens
WorkingPath=C:\Emulation\Arcade\Raine
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
AlsoLaunch=
ShowDesktop=True
Debug=False
MapFile=[APP]\Map Files\[Arcade] Raine.map
OLDatZip=
Command=raine32.exe -n -game [ROM]
TitlePath=C:\Emulation\Assets\Arcade\Raine\Titles\
BoxPath=C:\Emulation\Assets\Arcade\Raine\Boxes\
LaunchBefore=
LaunchAfter=
CartPath=C:\Emulation\Assets\Arcade\Raine\Cartridges\
DumbyValue=
ExcludedFiles=
CustomBackground=
PlayMusic=False
PCGame=False
DATABASE=[Arcade] Raine
GamesIn7Zips=False
LastGame=
ManualPath=C:\Emulation\Assets\Arcade\Raine\Manuals\
DontShowInfo=
CDCheck=False
CDCheckFile=
ControlPanelPath=C:\Emulation\Assets\Arcade\Raine\Controls\
[Emulator_5]
STARTPAGENAME=[Arcade] Zinc
TITLETEXT=Zinc
StartPageLogo=
ROMFilter=*.bat
RomPath=C:\Emulation\Arcade\ZiNc
SnapPath=C:\Emulation\Arcade\ZiNc\shots
TitlePath=
BoxPath=
CartPath=
ManualPath=
ControlPanelPath=
InstructionsPath=
WorkingPath=C:\Emulation\Arcade\ZiNc
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=
Command=""[rompath]/[romfile]""
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
DontShowInfo=
PlaySelectionMusic=
PCGame=
DATABASE=
GamesIn7Zips=
PlayInScreenSaver=
CDCheck=
CDCheckFile=
[Emulator_9]
[Emulator_10]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
GamesIn7Zips=
[Emulator_11]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
GamesIn7Zips=
[Emulator_12]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
GamesIn7Zips=
[Emulator_13]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
GamesIn7Zips=
[Emulator_14]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
GamesIn7Zips=
[Emulator_15]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
GamesIn7Zips=
[Emulator_16]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
GamesIn7Zips=
[Emulator_17]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
GamesIn7Zips=
[Emulator_18]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
GamesIn7Zips=
[Emulator_19]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
GamesIn7Zips=
[Emulator_20]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=True
RomPath=
SnapPath=
WorkingPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=True
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
GamesIn7Zips=
[TEXT]
LastPlayedList=Last Played
LastPlayedStart=Last Played
SearchTitle=Enter criteria then select menu
SearchTitle2=Press select to release cursor
SearchList=Search
SearchStart=Search
SearchMedia=Search Media
SearchJukebox=Search Jukebox
Items=Items
MediaPlayerStart=Library
MediaPlayerList=Library
NoMediaFound=- NO MEDIA FOUND -
eBookViewerStart=eBooks
eBookViewerList=eBooks
Artwork=Artwork
PCB=PCB
Statistics=Statistics
InsertCD=Insert CD:
SearchGames=Search Games
GameManual=Manual
PlayStation=Playstation
mame2simlist=2 Players
mame2simstart=2 Player Simultaneous
mame4simlist=4 Players
mame4simstart=4 Player Simultaneous
MCEEXPORT=Export To MCE
StartScreenSaver=Start Screensaver
Visualize=Visualize
About1=Windows Emulator Front End and HTPC
About2=Written By:
About3=For Latest Version, please visit:
byalbum=By Album
byartistalbum=By Artist/Album
byartist=By Artist
bycat=By Category
bygenre=By Genre
bymanu=By Manufacturer
bysys=By System
byname=By Name
bytitle=By Title
byyear=By Year
Selectplaylist=Play list / More
createsnaps=Create Snaps
CreateSnaps1A=You are about to create snap shots or videos for every game in the [EMULATOR] Games List. This option can be removed from GameEx, by enabling the Hide Create Snaps option in the configuration.
CreateSnaps2=You should be aware this is a lengthy process
CreateSnaps3=With your current settings it is estimated that it will take at least:
CreateSnaps4=[MINUTES] Minutes to complete this process if you use a 20 second pause between snaps.
CreateSnaps5=You should also be warned that the SNAP shots will be saved in the SNAP Path defined for this emulator
CreateSnaps6=This process is not recommended on Windows 98
CreateSnaps7=To exit this process once run HOLD down ESCAPE.
CreateSnaps8=Do you want to proceed?
Exit=Exit GameEx
HTMLPleaseWait=Please Wait
IsUpdatingList=GameEx is updating the MAME game list:
jukelist=Jukebox
jukestart=Jukebox
Karaokelist=Karaoke
Karaokestart=Karaoke
StartKaraoke=Start Karaoke Player
LaaunchingGame=Launching:
laserlist=Laserdisc
laserstart=Laserdisc Games
logoff=Log Off
favlist=Favorites
favstart=Favorites
mamealllist=MAME Games
mameallstart=All MAME Games
mamecpslist=CPS Games
mamecpsstart=CPS Games
mameAtarilist=Atari Games
mameAtaristart=Atari Games
mameGunlist=Lightgun
mameGunstart=Lightgun Games
mameTrackballlist=Trackball
mameTrackballstart=Trackball Games
mameSpinnerlist=Spinner
mameSpinnerstart=Spinner Games
mameModel2list=Model 2
mameModel2start=Sega Model 2 Games
mameGoldenlist=Golden Era
mameGoldenstart=Golden Era Of Arcade
mameneolist=Neo-Geo
mameNEostart=Neo-Geo Games
mamemultilist=MAME Multiplay
mamemultistart=MAME Multiplayer Games
mamevectorlist=MAME Vector
mamevectorstart=MAME Vector Games
Of=of
playstation=Playstation
shutdown=Turn Off System
standby=Stand By System
Restart=Restart System
Start=Start..
updatelist=Update List
UpdatingList=Updating Game List:
UpdatingPleaseWait=Please Wait......
videoslist=Videos
videostart=Videos
LaunchingGame=Launching Game:
PlayThisGame=Play This Game
Recommended=Recommended Games:
Series=Games in Series:
Title=Title
Flyer=Flyer
Cabinet=Cabinet
Panel=Panel
Box=Box
Cartridge=Cartridge
Marquee=Marquee
FavoritesAdd=Add To Favorites
FavoritesRemove=Remove From Favorites
NoVideosFound=- NO VIDEOS FOUND -
NoPicturesFound=- NO PICTURES FOUND -
NoMusicFound=- NO MUSIC FOUND -
NoArtistsFound=- NO ARTISTS FOUND -
NoAlbumsFound=- NO ALBUMS FOUND -
NoGenresFound=- NO GENRES FOUND -
NoGamesFound=- NO GAMES FOUND -
NoStationsFound=- NO STATIONS FOUND -
NoNewsFound=- NO NEWS FOUND -
CannotCreateSnaps1=Cannot Create Snaps
CannotCreateSnaps2=Emulator '[EMULATOR]' Does not have a valid Snap path, so Snaps cannot be created. Setup a valid snap path in the configuration and try again.
ViewControls=View Controls
Instructions=Instructions
ViewControlsKey=Press '[KEY]' to view in game.
AllMusic=All Music
ClearCurrentPlaylist=Clear Current Playlist
ShufflePlaylist=Shuffle Current Playlist
PlayLastGame=Last MAME Game
ViewSlideShow=View Slide Show
Pictures=Pictures
Radio=Radio
PlayDVD=Play DVD
DVDonDiskStart=DVD's
DVDonDiskList=DVD's
Demo=Demo:
Playing=Playing:
MAMEOriginal=MAME Original Games
MAMEOriginallist=Originals
MAMEAdult=MAME Adult Games
MAMEAdultlist=Adult
ClearAndQueueAll=Clear and Queue All
AddAndQueueAll=Add all to Queue
RandomGame=Play Random Game
StartMAME=MAME
StartApps=More Games & Programs
StartEMU=Emulated Games
StartControl=Exit/Shutdown
StartMedia=Multimedia
ListMAME=[Arcade] MAME
ListApps=Games & Apps
ListEMU=Games
ListControl=Exit
ListMedia=Media
TimesPlayed=Times Played
LastPlayed=Last Played
DeleteFavs=Delete Favorites
DeleteMost=Delete Most Played
Chapter=Chapter
Aspect=Aspect
Aspect0=Original Aspect - Not Zoomed
Aspect4=Widescreen on 4:3 - Stretched
Aspect5=Fill Screen
Aspect3a=Widescreen to 4:3 - Zoomed
Aspect3b=Letterbox to Widescreen - Zoomed
Aspect2=Original Aspect - Zoomed
Aspect1a=Widescreen to 4:3 - Shrunk
Aspect1b=4:3 to Widescreen - Stretched
Paused=Paused
PlayVideo=Play Video
ResumeVideo=Resume Video
RestartVideo=Restart Video
VideoQueue=Play All
QueueAllRandom=Play Randomly
News=News
More=More..
MostPlayed=Most Played
MostPlayedList=Most Played
VariousArtists=Various Artists
ConfirmDialog1=Select to Confim.
ConfirmDialog2=Back To Cancel.
RemoveGame=Remove Game?
LocalDisk=Local Disk
SystemDisk=System Disk
CDDVD=CD/DVD Drive
NetworkDrive=Network Drive
RamDisk=Ram Disk
FloppyDisk=Floppy Disk
RemovableDisk=Removable Disk
UpdateGameList=Update List?
VideoQueueAll=
playstationstart=Playstation
themepickerlist=Theme Picker
themepickerstart=Theme Picker
playstationlist=Playstation
mameVertList=Vertical
mameVertStart=MAME Vertical Games
mameHorizlist=Horizontal
mameHorizstart=MAME Horizontal Games
mamenotplayedlist=Not Played
mamenotplayedstart=MAME Not Played
mamemawslist=Live - MAWS
mameMAWSstart=Live - MAWS Hall Of Fame
mameGameExlist=Live - GameEx
mameGamEexstart=Live - GameEx Favorites
ripcd=Rip CD
ripthiscd=Rip This CD Now
cantrip=- No CD, Invalid CD, or no CDDB data -
ViewPlaylist=View Playlist
KaraokAllSongs=All Songs
KaraokaMode1Click=Instant Play Mode
KaraokaModeQueue=Queue Mode
KaraokePlaylist=View/Edit Playlist
KaraokeStartMenu=Start Karaoke
mammodel2list=
CreateSnaps1=
[Emulator_21]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=
RomPath=
SnapPath=
WorkingPath=
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
GamesIn7Zips=
[Emulator_22]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=
RomPath=
SnapPath=
WorkingPath=
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
GamesIn7Zips=
[Emulator_23]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=
RomPath=
SnapPath=
WorkingPath=
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
CartPath=
LaunchBefore=
LaunchAfter=
configFile=Visual Pinball V2
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
GamesIn7Zips=
[Emulator_24]
Enabled=False
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=
RomPath=
SnapPath=
WorkingPath=
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
TitlePath=
BoxPath=
CartPath=
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
DumbyValue=
GamesIn7Zips=
[Emulator_25]
Enabled=False
STARTPAGENAME=Nintendo 64 Games
TITLETEXT=N64
StartPageLogo=n64
ROMFilter=*.zip
RomsInFolders=False
RomPath=G:\-DATA-\-ROMS-\N64GOOD
SnapPath=D:\BitTorrent-Downloads\EmuMovies N64 AVI Game Previews for Mamewah
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=False
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=False
MAPFile=
AlsoLaunch=
TitlePath=
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=N64
Import=
Export=
DumbyValue=
GamesIn7Zips=
[Favorites]
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
[DVRMS]
DVRFFDSHOW=0
CODEC=
[AtractModeNewGameTimer]
When in attract mode start a new random game or video each time this value is reached.=2
[AttractVideosPath]
The folder your videos are located.=L:\GameAds
[GameExTender]
RemoteGameExLocation=\\workstation1\g$\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
ENABLED=False
Windowed=False
RemoteExtenderLocation=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
IPADDRESS=127.0.0.1
PORT=8383
RefreshRate=20
SysUserName=b00sted
UserName=User27206
ComputerName=A1440N
Publish=False
UserInfo=
[GameExtenderViewer]
Server=90.0.0.13
PORT=8383
RefreshRate=7
StartWithGameEx=False
ExitWithGameEx=False
[Karaoke]
Enabled=False
Path=C:\Karaoke
Mode=False
[Emulator_7]
[Emulator_8]
[Emulator_26]
Enabled=False
DumbyValue=
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=
RomPath=
SnapPath=
TitlePath=
BoxPath=
CartPath=
WorkingPath=
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
GamesIn7Zips=
[Emulator_27]
Enabled=False
DumbyValue=
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=
RomPath=
SnapPath=
TitlePath=
BoxPath=
CartPath=
WorkingPath=
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
GamesIn7Zips=
[Emulator_28]
Enabled=False
DumbyValue=
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=
RomPath=
SnapPath=
TitlePath=
BoxPath=
CartPath=
WorkingPath=
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
GamesIn7Zips=
[CachedImages]
bak=59694
Res=786432
videobak=59694
jukeboxbak=59694
radiobak=59694
picturesbak=59694
emubak=59694
startbak=89898
daphnebak=59694
mamebak=100652
ThemeDir=\themes\Default - MameEx 1024x768\MEDIA\
TitleFontSize=36
OutLineFonts=True
AntiAliasFonts=True
Windowed=False
GradientTitleFont=False
LowerCaseTitleFont=False
Font=Trebuchet MS
FontSize=0
TitleFontRes=786432
bakRes=786432
theme=Default - MameEx 1024x768
[Emulator_29]
Enabled=
DumbyValue=
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=
RomPath=
SnapPath=
TitlePath=
BoxPath=
CartPath=
WorkingPath=
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
GamesIn7Zips=
[Emulator_30]
Enabled=
DumbyValue=
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=
RomPath=
SnapPath=
TitlePath=
BoxPath=
CartPath=
WorkingPath=
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
GamesIn7Zips=
[Emulator_31]
Enabled=
DumbyValue=
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=
RomPath=
SnapPath=
TitlePath=
BoxPath=
CartPath=
WorkingPath=
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
GamesIn7Zips=
[Emulator_32]
Enabled=
DumbyValue=
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=
RomPath=
SnapPath=
TitlePath=
BoxPath=
CartPath=
WorkingPath=
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
GamesIn7Zips=
[Emulator_33]
Enabled=
DumbyValue=
STARTPAGENAME=
TITLETEXT=
StartPageLogo=
ROMFilter=
RomsInFolders=
RomPath=
SnapPath=
TitlePath=
BoxPath=
CartPath=
WorkingPath=
MapKeys=
WaitBeforeKeys=
SendKeys=
ReplaceDash=
ReplaceUnder=
Capitals=
RemoveBrackets=
ShowDesktop=
Debug=
MAPFile=
AlsoLaunch=
Command=
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
GamesIn7Zips=
[Plugin_1]
Enabled=False
Name=PlugInCallerID.dll
[Plugin_2]
Enabled=False
Name=PlugInDigDug.dll
[Plugin_3]
Enabled=False
Name=PlugInExit.dll
[Plugin_4]
Enabled=False
Name=PlugInLCD.dll
[Plugin_5]
Enabled=False
Name=PlugInSpeech.dll
[ArcadeSoundPlugin]
Volume=8
[Plugin_6]
Enabled=False
Name=PlugInUltraStik.dll
[CachedImagesMenuFont]
Res=786432
Font=Trebuchet MS
FontSize=1
OutLineFonts=True
AntiAliasFonts=True
Windowed=False
[CachedImagesBak]
bak=214295
videobak=214295
jukeboxbak=214295
radiobak=214295
picturesbak=214295
emubak=214295
startbak=214295
daphnebak=214295
[EmulatorGroup_1]
Enabled=False
STARTPAGENAME=Games
TITLETEXT=Games
StartPageLogo=MAMEAll
Emulators=1;2;5;4
ShowUnderEmulators=False
[Emulator_]
SelectionMusicFolder=C:\Music
[eBook]
Enabled=False
Paths=C:\eBooks
[Plugin_7]
Enabled=False
Name=RandomArcadeSound.dll
[MediaPlayer]
Enabled=False
AudioMode=0
[CachedImagesGameFont]
Res=786432
[CachedImagesGameFontFaded]
Res=786432
[CachedImagesFontBlack]
Res=786432
done did that and still no luck.. i even reloaded and jsut setup mame and still no luck.. it worked til i decided to disable the sub listings for mame and use flat menu
Do a compare of the GameEx.ini that you posted earlier with your current one. The difference will tell you what you did to fix it. Might be good to know for other people.
  b00sted said:
if i didnt redo so much that would be a great idea but i changed the entire setup this time
Make a back-up! ;)
