i have done something wrong while trying to get GameEx to run Vic20 roms from zips (tosec & gamebasevic) (works though!)
What happened is that gameex was minimised on the taskbar and i right clicked and closed. Now when ever i run it in a window it minimises to taskbar again.
If i maximise it just goes back to full screen mode - help!
I bet jessica chris has an answer! :)
tried everything now!
how strange?
if no one knows the answer then feel free to leave a suggestion that does not help!
Though, i did try singing in the rain, and making a violin from matchsticks, and i am afraid that neither worked... It is stuck minimised forever!
What does atl+tab do for ya?
Brings up a the running programs, i move to gameex and select, and.... DA-Daaa it stays minimised :(
Not sure if this will work, but check out your GameEx.ini and change the following
windowx=427
windowy=181
windowwidth=640
windowheight=480
Maybe it's somehow saved positions that force the window to minimize. Worth a try anyway although the matchstick violin was probably a better idea :)
windowx=427
windowy=181
windowwidth=640
windowheight=480
Well done, both windowx and windowy were at -32000 ? Changed them back and then had to set to fullscreen mode and switch to window with alt-enter.
All works great again..
you are a star, a quite pointy one, slightly shiny.
