I am having problems running my DVD Player on the menu.
(Also is there anyway to remove it from the main menu but still keep it on the MULTIMEDIA menu)
When I run from either menu the screen goes blank and then goes back to GameEx... Have I got to set something else up to get the DVD Player to work?
Theres no way to remove it currently.
You need a DVD player installed such as WinDVD or PowerDVD.
Note: Nvidia and ATI players dont work at the moment.
i've got powerdvd installed.
i have selected cyber someting for the dvd decoder but i still get a blank screen?
can you help pls
can you help pls
Have you got FFDSHOW turned off? Does the DVD Play in PowerDVD OK?
