Daphne Roms Names / Space Ace and Dragon's Lair 2
I searched all over the forums for an answer but couldnt find one... (BTW im running the latest version of Daphne)
i set up daphne successfully by using some tutorial on the site that shows how to set up Dragon's Lair
in his instructions he said
14. Under Game 1 Rom type: dle21 which i believe plays all new scenes.
tutorial works fine....dragon's lair is all good.
i tried to apply the same logic he gives for my other 2 daphne games, Daragon's lair 2 and Space Ace.
I'm not sure what to type in "Game Rom" for Dragon's Lair 2 and Space Ace.....i tried a few different ones that i saw in my daphne rom folder like lair2 and ace91 but neither of those worked.
They run fine outside of GameEx.
Can someone tell what i use for those 2 rom names pls?
thanks!
thanks!
Ahh... Well Do Dragons Lair II Timewarp, and Space Ace work using daphne loader? Daphne loader will tell you the command line its using when launching the game. Use that info to configure gameex.
Also you will notice using daphne loader some games have a few revisions... Its thos revisions that are tied to the seprate roms. Perhaps your missing the parent roms. Im not sure. But if it works in daphne loader again you can take the command and get it going in gamex.
Im glad you liked my tutorial
Brian Hoffman
well i got space ace to work....
but no luck with Dragons Lair 2.
Dragons Lair 2 has a bunch of different roms.....it works fine outside of game ex though....i woulda thought lair2 would work for sure but it doesnt
Im pretty sure I use lair2.. Mine works fine.
I can verify when I get home. In about 6 hours :(
i get this error in the daphne log .txt
--DAPHNE version 1.0.0
--Command line is: Daphne.exe dlair2 vldp -fullscreen -x 640 -y 480 -nohwaccel -fastboot -cheat daphne.exe lair2 vldp -framefile vldp_dl/lair2/dl2-framefile.txt -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -sound_buffer 2048 -fullscreen -x 1680 -y 1050
--CPU : AuthenticAMD 2400 MHz || Mem : 2048 megs
--OS : Windows NT/2000 || Video : NVIDIA GeForce 8800 GTS
--OpenGL: Compiled In
--RGB2YUV Function: MMX
--Line Blending Function: MMX
--Audio Mixing Function: MMX
Setting alternate home dir:
ERROR: Unknown game type specified : dlair2
Bad command line or initialization problem (see daphne_log.txt for details).
To run DAPHNE, you must specify which game to run and which laserdisc player you are using.
For example, try 'daphne lair noldp' to run Dragon's Lair in testing mode.
But it runs absolutely fine using the Daphne Loader.......? I just played it.......
****Here is my command line in my gameex daphne setup for this game
Just display the command line settings in Daphne Loader to see what exactly is needed to run that game.
1. Click Game
2. Click Configure DAPHNE options
3. Click on the Advanced tab
4. Enable Display command line
Now run your game and use that info in GameEx!
1. Click Game
hi yes thats exactly what i did.....
that is the command line i got from daphne to put into gameex
doesnt work...like i said it works perfectly fine outside gameex....thats whats weird. and space ace and dragons lair run fine
Post some screenys of your daphne config.
please
please
here you go Brian..thx
u guys in this forum are awesome i must say....such good quick responses!
sry for posting so much!! :blink:
hey thx bkenobi!
here it is....
[Daphne]
# (http://www.daphne-emu.com/)
# Daphne is a an arcade Laserdisc emulator, that allows playing of
# games such as Dragon's Lair and Space Ace.
# The following options enable GameEx to act as a Daphne front end
# and presents a list of Daphne games that can be selected from the Start
# Page. DaphnePath, and DapnheSnaps should contain the full path to where
# the Daphne ExE is located (path only), and the path to snaps to use.
# Daphne EXE is the daphne executable file (without the path).
# DaphneSnap is the location of Snap Images
# DapnheOptions are the global command line options applicable to all games.
# Set UseDapnhe to true to enable Daphne support in GameEx
UseDaphne=True
DaphnePath=C:\Users\kingb\Desktop\EMULATION\daphne
DaphneExe=Daphne.exe
DaphneSnap=C:\Program Files\EMULOADER\glvideodir\Daphne Videos
DaphneOptions=vldp -fullscreen -x 640 -y 480 -nohwaccel -fastboot -cheat
# Set up the following options for each Daphne Game. Suffix the end of the
# option with an underscore and a number between one and 30. With Each
# game having a seperate number.
# ROMName is the ROM filename
# GameName is the friendly name shown in the GameEx list
# GameOptions are the specific command line options for each game
# Enabled is true or false and whether the game will appear in the list.
Enabled_1 =True
ROMName_1 =dle21
GameName_1 =Dragon's Lair
GameOptions_1 =daphne.exe lair vldp -framefile vldp_dl/lair/lair.txt -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 11111001 -bank 1 00100111 -latency 100 -sound_buffer 2048 -fullscreen -x 1680 -y 1050
Enabled_2=True
ROMName_2 =ace
GameName_2 =Space Ace
GameOptions_2 =daphne.exe ace vldp -framefile vldp_dl/ace/ace.txt -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 00000000 -bank 1 00000001 -sound_buffer 2048 -fullscreen -x 1680 -y 1050
Enabled_3=True
ROMName_3 =dlair2
GameName_3 =Dragon's Lair 2
GameOptions_3 =daphne.exe lair2 vldp -framefile vldp_dl/lair2/dl2-framefile.txt -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -sound_buffer 2048 -fullscreen -x 1680 -y 1050
Enabled_4=False
ROMName_4 =cliff
GameName_4 =Cliff Hanger
GameOptions_4 =-framefile j:\daphne\mpeg\cliff_framefile.txt
Enabled_5=False
ROMName_5 =cobraab
GameName_5 =Cobra Command
GameOptions_5 =-framefile j:\daphne\mpeg\cc_framefile.txt
Enabled_6=False
ROMName_6=lair2
GameName_6=Dragon's Lair II
GameOptions_6=daphne.exe lair2 vldp -framefile vldp_dl/lair2/dl2-framefile.txt -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -sound_buffer 2048 -fullscreen -x 1680 -y 1050
Enabled_7=False
ROMName_7=cobraab
GameName_7=Cobra Command
GameOptions_7=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_8=False
ROMName_8=cobraab
GameName_8=Cobra Command
GameOptions_8=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_9=False
ROMName_9=cobraab
GameName_9=Cobra Command
GameOptions_9=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_10=False
ROMName_10=cobraab
GameName_10=Cobra Command
GameOptions_10=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_11=False
ROMName_11=cobraab
GameName_11=Cobra Command
GameOptions_11=-framefile h:\daphne\mpeg\cc_framefile.txt
Enabled_12=False
ROMName_12=cobraab
GameName_12=Cobra Command
GameOptions_12=-framefile h:\daphne\mpeg\cc_framefile.txt
GameName_23=
Enabled_13=False
ROMName_13=
GameName_13=
GameOptions_13=
Enabled_14=False
ROMName_14=
GameName_14=
GameOptions_14=
Enabled_15=False
ROMName_15=
GameName_15=
GameOptions_15=
Enabled_16=False
ROMName_16=
GameName_16=
GameOptions_16=
Enabled_17=False
ROMName_17=
GameName_17=
GameOptions_17=
Enabled_18=False
ROMName_18=
GameName_18=
GameOptions_18=
Enabled_19=False
ROMName_19=
GameName_19=
GameOptions_19=
Enabled_20=False
ROMName_20=
GameName_20=
GameOptions_20=
Enabled_21=False
ROMName_21=
GameName_21=
GameOptions_21=
Enabled_22=False
ROMName_22=
GameName_22=
GameOptions_22=
Enabled_23=False
ROMName_23=
GameOptions_23=
DaphneFlyer=C:\Emulators\Daphne\flyers
DaphneCabinet=C:\Emulators\Daphne\cabinets
DaphneTitle=C:\Emulators\Daphne\titles
DaphneMarquee=C:\Emulators\Daphne\marquees
DaphnePanel=C:\Emulators\Daphne\cpanel
UseGamepad=True
Your config is phucked.
I dont know how anything works.. make 3 look like this.
Enabled_3=True
ROMName_3 = lair2
GameName_3 = Dragon's Lair 2
GameOptions_3 = -framefile vldp_dl/lair2/dl2-framefile.txt
Enabled_3=True
ROMName_3 = lair2
hmm weird....well that was easy.....all good now!!!
thx man
  • 1 month later...
I don't mean to post in an older thread. But I'm having a similar problem. When trying to load Astronbelt and Thayer's Quest I get the following error (In Daphne log)
--DAPHNE version 0.99.7
--Command line is: Daphne.exe tq vldp -fullscreen -x 640 -y 480 -nohwaccel -framefile C:\Emulators\Daphne\Mpeg\Thayer's Quest\Thayer's Quest.txt
--CPU : GenuineIntel 3450 MHz || Mem : 1024 megs
--OS : Windows NT Derivative || Video : Radeon X1950 Pro
Setting screen width to 640
Setting screen height to 480
Unknown command line parameter:
Quest\Thayer's
Quest.txt
Here's two screenshots
Any ideas? I'm becoming a regular having problems :lol: I spent some time trying to figure it out changing command lines and whatnot with a no go. Dragon's Lair 1 and 2 and Space Ace seem to work without any problems btw. Thanks.
Quest\Thayer's
Quest.txt
I'm going to say that it's because you have spaces in the path. The reason I say that, is because the log seems to think that you are using command line parameters called "Quest\Thayers", and "Quest.txt"
Commandlines generally look like: program.exe parameter1 parameter2
So with the spaces, Dos thinks you are sending parameters on your command line.
Either enclose the path with qoutes:
-framefile "C:\Emulators\Daphne\Mpeg\Thayer's Quest\Thayer's Quest.txt"
Or change the path name:
-framefile C:\Emulators\Daphne\Mpeg\Thayer'sQuest\Thayer'sQuest.txt
Of course, if Cobra Command is working, then I'm totally wrong! :blink:
Hey Tempest thanks for your help! The one with the quotes worked! It's kind of strange that Dragon's Lair 1 and 2 without quotes will work but not Thayer's Quest :rolleyes: I also tried it with Astron Belt as well and worked as well thanks again. I feel like I'm becoming a pest with my problems lol
You don't have any spaces in your path with Dlair, so it will work without quotes...I'm suprised Cobra Command works...
  Quote
No Problem! :)
Oh I see now lol I don't think Cobra Command works now that I think of it :P
10-4! :P (end of transmission)
