i have tried to place the images fr the various emulators and to change the main images under MEDIA / LOGOS -
but it doesn't work, can anyone tell me where tey go please?
and is any size PNG or JPG file can be used?
Apologies if it seems like a newbie question
(NOTE: I'm using the GameEx animated menu)
They need to go under the theme you're using. For example, because I'm using the Default - Default theme, my custom images go in
\Program Files\GameEx\THEMES\Default - Default\MEDIA\LOGOS
I do not think that the size of the image matters.
thanks. although the animated one it appeas grabs al the images from the normal default - gameex folder and not the default - gameex animated folder?!!!
Default - GameEx - Animated is the same as Default - GameEx, just with animation turned on. You can see in the themes.ini
ThemeImages=Default - GameEx
It just grabs the images from the former folder.
-- Rob
