Hi guys
First thanks for all the help you guys have given me - it's like learning a whole new language for me with all the roms, chd,s dats, compiler etc etc etc - LOL I still don't have the foggest idea what i am doing.
Anyway - I have Mame, PJ64, & ZSNES working (with your help !) and I have decided to let the other emus go for the time being.
So I downloaded soft-15khz to this PC before I attempt to connect it to the CAB - it's build 38 so i hope its the newest - but when I run the tool - the box comes up with all the selections in grey - nothing is in black and it will not allow me to select anything.
Any Ideas??
  • Replies 59
  • Created
  • Last Reply
Top Posters In This Topic
Hi guys
Any Ideas??
Your monitor wont support those refreshrates I assume...
What display are you using?
its a protron lcd tv that i use for my pc in my office - i currently have both PC's hooked to it
Why do you need soft15 if you are running a LCD TV? That software is meant to set the resolution of the monitor as close as possible to the original resolution and refresh rate the game was playing at. BUT, you are using an LCD that only has 1 refresh rate (probably), and you want to run in the native resolution whenever possible. Perhaps I'm missing something, but I don't see why you would want to run that app if you aren't using a CRT...
Yeah Bk - you are missing something - ;)
In my fisrt post I say i am prepping this PC to place it in my CAB - its a D&D (mystra) machine and I want to make sure all is right before I attempt to connect this by way of JPAC.
So are you saying I cannot "run" the soft-15khz while connected to this LCD TV?
VIPER
this is just an onboard video - would I need special drivers for the soft-15khz software??
Thanks Guys !!
I have an onboard video in my laptop (with LCD screen) and it installed just fine. I then hook my laptop up to my cabinet with no problems. I made a hotkey to switch to 640x480 (what I run in my cab) and the external screen adapter.
This is how it looks for me:
(The two options greyed out here are already installed)
If your adapter is supported, it should show up to the left.
Emph
VIPER
Thanks Guys !!
Soft-15khz is for use with arcade (CRT) monitors.
Emph
So - since nothing is on the left, this means i have to buy something else?
another video card?
Below I have listed the PC I bought to install in my CAB
Can you tell from this what I need?.
THANKS
Brand:
Dell
Memory (RAM):
1,024 MB
Family:
OptiPlex
Hard Drive Capacity:
160 GB
Processor Type:
Intel Pentium 4 HT
Operating System:
Windows XP Professional
Processor Model:
Primary Drive:
DVD+/-RW
Processor Speed:
2,800 MHz
Condition:
Refurbished
another video card?
THANKS
Brand:
Dell
Memory (RAM):
1,024 MB
Family:
OptiPlex
160 GB
Processor Type:
Intel Pentium 4 HT
Operating System:
Processor Model:
Primary Drive:
DVD+/-RW
Processor Speed:
2,800 MHz
Condition:
Refurbished
FYI - your Dell should have a service tag # on the outside, if you go to Dell.com, and enter that # (you probably have to go to "support") it will tell you exactly what was in the computer when it was built. I don't know if it makes a difference or not, but you don't list a video card, so you probably have "onboard" video. Or maybe you knew that already.....
Yes, I am sure it is onboard videocard - I was told that this would be ok - this will only be used for my arcade cab and will have no other uses and with my limited funds I need to try to spend as little as possible.
I went to DELL and entered the service tag number but it provided no video card info.... and it also showed a different sized HD from what I have - maybe because its a refurb?? anyway the tag number is G00RW41..
any idea's...
any idea's...
Do you have a spare CRT monitor to try?
no, I don't...
I have an old TV, but no way to connect it to the PC..
Do you think I should go ahead and attempt to connect it to the CAB
no, I don't...
What type of monitor is in the CAB?
It is a Phillips MO8X
That's only the tube.....
Any other ID on the chassis ?
Like WG K 7000 ?
Like WG K 7000 ?
There are several tags on the chassis
one says " ser no WG065228"
another says "Model no. 25k7193 wells gardner elecronics"
25k may be referring to 25hz.. Its a wells gardner..
Im not to familiar with using actual arcade monitors.. I wish I could be more help :(
Sorry, I can't help with an actual arcade monitor since apparently I'm too cheap to buy one :(
If you rip out the arcade monitor and put in a decent TV or PC CRT, then I might be able to help :P (btw, don't do that, I'm joking...)
If you rip out the arcade monitor and put in a decent TV or PC CRT, then I might be able to help :P (in case it's not obvious, don't do that, I'm joking...)
OMG - LOL - you scared the Sh@t outta me :lol: :lol:
Hi Spuds. I'd leave the arcade monitor in the cab and use it (i think it's a 25"). Best bet for help with the arcade monitor and Soft-15Khz is over at the BYOAC Monitor/Video Forum. They should be better able to help with your dilemma.
http://forum.arcadecontrols.com/index.php?board=4.0
Yah, I was planning on using the Cab as it is AWESOME at 7' tall and the picture is great - so anyway thanks for the tip - I will go over there and see if they have some ideas also
Thanks !
If I were in your shoes, I would buy a really cheap ATI card and install in the DELL. First check the classifieds in your local paper or eBay. If you find a nice card, check it againt the supported cards in the Soft15hz forum. Should be able to get one for a couple of bucks. Running on that arcade monitor is the way to go, believe me. If it has 25khz it might even support higher resolutions like 640x480 (like I'm running on my EGRET II) and it looks awesome.
Emph
Emph
Thanks emphatic, I appreciate your advice and all the other guys advice as well.
I will start looking for a video card
when you say
If it has 25khz
how can I tell?
I did a google search on the monitor and found several sites which talk about it but nothing about 15khx/25khz - I even went to WG site and tried a product search for it to no avail...
when you say how can I tell?
Hey spuds. I just thought of something. I got a dell optiplex gx-240 out of work (it was considered outdated) and put xp pro on it. The graphics card that came with had an ati chipset on it (rage pro 128, i think). When i tried to put a different graphics card in it (ArcadeVGA2 agv version) i could get no picture past the bios screen - it was just blank. On asking about this over on the Ultimarc forum, i was told that on some models dell have custom bios that will not allow you to use any old graphics card (just ones approved by dell). It's just a word of warning. Like Emphatic suggested don't spend much money on the card (as it may not work). I'm wondering if it's possible to change the bios to get around this problem. Anyone ?
