I have MAME working very well - I LOVE it BTW !!!
Anyway I am trying to setup a few others and no matter what i try it won't work.
I am sure I just have something in the wrong place but I can't figure it out - any suggestions??
THANKS !!!
1:14.8 4/2/2008: GameEx: Version 9.19: Starting Log
15:11:14.8 4/2/2008: Operating System Platform: Win32NT
15:11:14.8 4/2/2008: Operating System Name: Windows XP
15:11:14.8 4/2/2008: Operating System Version: 5.1.2600
15:11:14.8 4/2/2008: Checking for versions of .net Framework installed
15:11:14.8 4/2/2008: .net Framework 2.0 Installed
15:11:14.8 4/2/2008: Intel® Pentium® 4 CPU 2.80GHz, 1022MB
15:11:14.8 4/2/2008: 2.79Ghz
15:11:14.9 4/2/2008: Running Randomize()
15:11:14.9 4/2/2008: Loading PlugIns
15:11:14.9 4/2/2008: Checking for applications to Launch On Startup
15:11:14.9 4/2/2008: Running Misc startup tasks
15:11:14.9 4/2/2008: Setting Menu types
15:11:14.9 4/2/2008: Opening Configuration File
15:11:14.9 4/2/2008: Getting Configuration Values
15:11:14.9 4/2/2008: Using Theme: Default - Media Center
15:11:14.9 4/2/2008: Checking for alternate Image Directory for Theme: Default - Media Center
15:11:14.9 4/2/2008: Launching HideOS.exe
15:11:14.9 4/2/2008: Initialising Video/MNG DLL's
15:11:15.1 4/2/2008: Hiding Taskbar
15:11:15.2 4/2/2008: Is Media Center running?
15:11:15.2 4/2/2008: Checking/Creating LCD Registry values
15:11:15.2 4/2/2008: Check Media Center Exit/Start Mode
15:11:15.2 4/2/2008: Media Center Mode 2
15:11:15.2 4/2/2008: Video previews on. Warning: Only recommended on modern systems
15:11:15.2 4/2/2008: Snap Delay set to: 2
15:11:15.2 4/2/2008: Get other settings
15:11:15.2 4/2/2008: Reading MAME hall of fame
15:11:15.2 4/2/2008: Set: Find emulator artwork on best match basis
15:11:15.3 4/2/2008: Start work for Form
15:11:15.3 4/2/2008: Getting Original Screen Size
15:11:15.3 4/2/2008: Opening Database Connection
15:11:16.0 4/2/2008: Initializing Component
15:11:16.1 4/2/2008: Retrieving resolution setting
15:11:16.1 4/2/2008: Creating Radio Station Genres
15:11:16.2 4/2/2008: Succesfully created station genres
15:11:16.2 4/2/2008: Initialising Windows Media Player Component
15:11:16.2 4/2/2008: MAME Path is: C:\Emulators\Mame32
15:11:16.2 4/2/2008: daphne Path is: C:\Emulators\Daphne
15:11:16.2 4/2/2008: daphne EXE file is: Daphne.exe
15:11:16.2 4/2/2008: Use daphne on. Daphne.exe will launch games
15:11:16.2 4/2/2008: ZiNc Path is: C:\Emulators\ZiNc
15:11:16.2 4/2/2008: ZiNc EXE file is: zinc.exe
15:11:16.3 4/2/2008: Use ZiNc on. zinc.exe will launch PSX games
15:11:16.3 4/2/2008: MAME EXE file is: Mame32.exe
15:11:16.3 4/2/2008: ROM Path is: C:\Emulators\Mame32\roms
15:11:16.3 4/2/2008: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
15:11:16.3 4/2/2008: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
15:11:16.3 4/2/2008: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
15:11:16.3 4/2/2008: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
15:11:16.3 4/2/2008: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
15:11:16.3 4/2/2008: Loading Controls.ini map file
15:11:16.3 4/2/2008: Snap Path is: C:\Emulators\Mame32\snap
15:11:16.3 4/2/2008: AVI Snap Path is: C:\Emulators\Mame32\avisnap
15:11:16.3 4/2/2008: Flyer Path is: C:\Emulators\Mame32\flyers
15:11:16.3 4/2/2008: Cabinet Path is: C:\Emulators\Mame32\cabinets
15:11:16.3 4/2/2008: Title Path is: C:\Emulators\Mame32\titles
15:11:16.3 4/2/2008: PCB Path: Not Found
15:11:16.3 4/2/2008: Artwork Preview Path: Not Found
15:11:16.3 4/2/2008: Panel Path is: C:\Emulators\Mame32\cpanel
15:11:16.3 4/2/2008: Manual Path: Not Found
15:11:16.3 4/2/2008: Icon Path is: C:\Emulators\Mame32\icons
15:11:16.3 4/2/2008: Marquee Path is: C:\Emulators\Mame32\marquees
15:11:16.3 4/2/2008: Loading Custom Emulators
15:11:16.3 4/2/2008: Loading Emulator 17: [Console] Nintendo N64 (Project64)
15:11:16.3 4/2/2008: Error: Emulator_17: WorkingPath Does Not Exist
15:11:16.3 4/2/2008: --Please correct the error above for this emulator or disable the emulator.
15:11:16.3 4/2/2008: ---------------------------------
15:11:16.4 4/2/2008: Error: Procedure call or argument is not valid.
15:11:16.7 4/2/2008: at Microsoft.VisualBasic.ErrObject.Raise(Int32 Number, Object Source, Object Description, Object HelpFile, Object HelpContext)
15:11:16.7 4/2/2008: at l.a9()
15:11:16.7 4/2/2008: at l.a(Boolean A_0, String A_1, Boolean A_2)
15:11:16.7 4/2/2008: at l..ctor()
15:11:16.7 4/2/2008: Closing database connection
15:11:16.7 4/2/2008: GameEx is exiting with errors
15:11:22.9 4/2/2008: ERRORS DETECTED: EXITING
You have a problem with Emulator 17. Says the path does not exist. If this is one that you setup then you need to check your settings. If not then just disable it and you should be good to go.
yes - I know i can disable it and Gameex then runs fine - but I want to get this setup- so where should I start looking for the problem - please explain in simple terms as I have a simple mind :(
Thanks !
Thanks !
Your WORKINGPATH. is the path the the emulator exe. Basiclly it cant find the EXE.
In order for us to help you out we need to know what your setting up and how your going about it.
The log is fine and all but it lacks the detail of the emu config...
What is the emulator your trying to setup. Also you can Export your config using the gameex configuration app.
Just go into emu 17 and the 2nd or 3rd option is EXPORT. Please post your config and we can tell you how to fix it.
Brian Hoffman
What version of project64 are you using?
Thanks !
Well you're not pointing to the right path for Project64.
Change the path to where you have that emulator in setup wizard. See highlighted in yellow in pic below
thanks guys
I went back in and deleted all emu's and then project 64 in slot #1
I probably messed something else up o this one -
Anyway I think this is what you asked for Brian
[Emulator_1]
Enabled=False
STARTPAGENAME=[Console] Nintendo N64 (Project64)
TITLETEXT=Nintendo N64
StartPageLogo=[Console] Nintendo N64
ROMFilter=
RomPath=C:\Emulation\Assets\Console\Nintendo N64\Roms\
SnapPath=C:\Emulation\Assets\Console\Nintendo N64\Snaps\
TitlePath=C:\Emulation\Assets\Console\Nintendo N64\Titles\
BoxPath=C:\Emulation\Assets\Console\Nintendo N64\Boxes\
CartPath=C:\Emulation\Assets\Console\Nintendo N64\Cartridges\
ManualPath=C:\Emulation\Assets\Console\Nintendo N64\Manuals\
ControlPanelPath=C:\Emulation\Assets\Console\Nintendo N64\Controls\
InstructionsPath=
WorkingPath=C:\Emulators\Project64\Emulator
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=
Command=Project64.exe "[ROMPath]\[RomFile]"
OLDatZip=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PlaySelectionMusic=False
SelectionMusicFolder=
PCGame=False
DATABASE=[Console] Nintendo N64
GamesIn7Zips=False
PlayInScreenSaver=False
ShowMostPlayed=True
RandomMostPlayed=False
CDCheck=False
CDCheckFile=
[GENERAL]
DumbyValue=
Another thing I notice is that when I follow the path c:/emulators/project64/emulator.....their are two items in this folder
Project64.cache (1KB)
setup Project64 1.6
When I launch the setup up file - WHERE should I place it?
setup Project64 1.6
Oh wow... Umm
First.. run the setup file... Whereever you tell the installer to extract the file to will be your WORKINGPATH. After that verify a file named PROJECT64.exe exists in that folder..
After that. Run project 64.. Configure the emu to launch full screen on rom load and all plugins... Make sure you can launch a game.
After that verify those paths in your gameex config you posted is accurate.
Note: depending on your version of project64 the command may be either
project64.exe "[rompath]/[romfile]"
or
project64.exe [rompath]/[romfile]
Good luck!
OK...
I think I am making progress.
I have a few emu's loading up now and GameEx shows them.
problem one - project64 - when I select a game it just goes to a black screen.
Now I can run project 64 without going thru gameex.
problem two - MESS - I can get the program to run thru GameEx but when it tries to load a game it flashes very quickly and looks to be 10 times as large as it should be then flashes back to the selection menu
Any thoughts??
Thanks !
1) Is there sound? Does it sound like its playing in the background? If so, change:
ShowDesktop=False
to
ShowDesktop=True
2) GameEx is at a different resolution than the other emulator. One option is to tell GameEx not to change resolutions and get them correct in each emulator. I don't know if that will fix the crash, but that's something you need to check outside of GameEx by running the "Run Last Game.bat" file in the GameEx Start menu.
I tried both of these.
the first suggestion did not work - when it opened on the desktop it said "file failed to load"
the same thing when I ran the "run last game" :(
can you take a look at this logfile and see if you see something for me?
16:43:32.9 4/3/2008: GameEx: Version 9.19: Starting Log
16:43:32.9 4/3/2008: Operating System Platform: Win32NT
16:43:32.9 4/3/2008: Operating System Name: Windows XP
16:43:32.9 4/3/2008: Operating System Version: 5.1.2600
16:43:32.9 4/3/2008: Checking for versions of .net Framework installed
16:43:32.9 4/3/2008: .net Framework 2.0 Installed
16:43:32.9 4/3/2008: Intel® Pentium® 4 CPU 2.80GHz, 1022MB
16:43:32.9 4/3/2008: 2.79Ghz
16:43:32.9 4/3/2008: Running Randomize()
16:43:33.0 4/3/2008: Loading PlugIns
16:43:33.0 4/3/2008: Checking for applications to Launch On Startup
16:43:33.0 4/3/2008: Running Misc startup tasks
16:43:33.0 4/3/2008: Setting Menu types
16:43:33.0 4/3/2008: Opening Configuration File
16:43:33.0 4/3/2008: Getting Configuration Values
16:43:33.0 4/3/2008: Using Theme: Default - Media Center
16:43:33.0 4/3/2008: Checking for alternate Image Directory for Theme: Default - Media Center
16:43:33.0 4/3/2008: Launching HideOS.exe
16:43:33.0 4/3/2008: Initialising Video/MNG DLL's
16:43:33.0 4/3/2008: Hiding Taskbar
16:43:33.0 4/3/2008: Is Media Center running?
16:43:33.0 4/3/2008: Checking/Creating LCD Registry values
16:43:33.0 4/3/2008: Check Media Center Exit/Start Mode
16:43:33.0 4/3/2008: Media Center Mode 2
16:43:33.0 4/3/2008: Video previews on. Warning: Only recommended on modern systems
16:43:33.0 4/3/2008: Snap Delay set to: 2
16:43:33.0 4/3/2008: Get other settings
16:43:33.0 4/3/2008: Reading MAME hall of fame
16:43:33.1 4/3/2008: Set: Find emulator artwork on best match basis
16:43:33.1 4/3/2008: Start work for Form
16:43:33.1 4/3/2008: Getting Original Screen Size
16:43:33.1 4/3/2008: Opening Database Connection
16:43:33.2 4/3/2008: Initializing Component
16:43:33.2 4/3/2008: Retrieving resolution setting
16:43:33.2 4/3/2008: Creating Radio Station Genres
16:43:33.3 4/3/2008: Succesfully created station genres
16:43:33.3 4/3/2008: Initialising Windows Media Player Component
16:43:33.4 4/3/2008: MAME Path is: C:\Emulators\Mame32
16:43:33.4 4/3/2008: daphne Path is: C:\Emulators\Daphne
16:43:33.4 4/3/2008: daphne EXE file is: Daphne.exe
16:43:33.4 4/3/2008: Use daphne on. Daphne.exe will launch games
16:43:33.4 4/3/2008: MAME EXE file is: Mame32.exe
16:43:33.4 4/3/2008: ROM Path is: C:\Emulators\Mame32\roms
16:43:33.4 4/3/2008: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
16:43:33.4 4/3/2008: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
16:43:33.4 4/3/2008: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
16:43:33.4 4/3/2008: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
16:43:33.4 4/3/2008: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
16:43:33.4 4/3/2008: Loading Controls.ini map file
16:43:33.4 4/3/2008: Snap Path is: C:\Emulators\Mame32\snap
16:43:33.4 4/3/2008: AVI Snap Path is: C:\Emulators\Mame32\avisnap
16:43:33.4 4/3/2008: Flyer Path is: C:\Emulators\Mame32\flyers
16:43:33.4 4/3/2008: Cabinet Path is: C:\Emulators\Mame32\cabinets
16:43:33.4 4/3/2008: Title Path is: C:\Emulators\Mame32\titles
16:43:33.4 4/3/2008: PCB Path: Not Found
16:43:33.4 4/3/2008: Artwork Preview Path: Not Found
16:43:33.4 4/3/2008: Panel Path is: C:\Emulators\Mame32\cpanel
16:43:33.4 4/3/2008: Manual Path: Not Found
16:43:33.4 4/3/2008: Icon Path is: C:\Emulators\Mame32\icons
16:43:33.4 4/3/2008: Marquee Path is: C:\Emulators\Mame32\marquees
16:43:33.5 4/3/2008: Loading Custom Emulators
16:43:33.5 4/3/2008: Loading Emulator 1: [Console] Nintendo N64 (Project64)
16:43:33.5 4/3/2008: Loading Emulator 2: [Console] Atari 5200 (MESS)
16:43:33.5 4/3/2008: Loading Emulator 3: [Console] Nintendo SNES (ZSNES)
16:43:33.5 4/3/2008: Loading Emulator 4: [Console] Atari 7800 (MESS)
16:43:33.8 4/3/2008: Using 2D Animations
16:43:33.8 4/3/2008: Using General Font: Trebuchet MS
16:43:33.8 4/3/2008: Using Title Font: Trebuchet MS
16:43:33.8 4/3/2008: Attempting to load game list
16:43:34.0 4/3/2008: Initialising DirectDraw
16:43:34.0 4/3/2008: Applying GameEx is Loading Image
16:43:35.2 4/3/2008: Creating DirectDraw Device
16:43:35.2 4/3/2008: Using Device: Primary Display Driver
16:43:35.3 4/3/2008: 90mb video memory available
16:43:35.9 4/3/2008: Setting Resolution to 800x600 32 bit color
16:43:36.6 4/3/2008: Creating DirectDraw Surfaces
16:43:36.6 4/3/2008: Creating Primary Surface - Full Screen Mode
16:43:36.7 4/3/2008: Creating Back Buffer
16:43:36.8 4/3/2008: Loading graphic Surfaces
16:43:36.8 4/3/2008: Display is running at: 800x600 32bit color, 60hz
16:43:36.8 4/3/2008: Creating Surfaces Misc and Dialogs
16:43:36.8 4/3/2008: Creating Surfaces Volume
16:43:36.9 4/3/2008: Creating Surfaces Arrows
16:43:36.9 4/3/2008: Creating Surfaces GameEXlogo Text
16:43:36.9 4/3/2008: Creating Surfaces Toolbar
16:43:36.9 4/3/2008: Creating Surfaces Backgrounds
16:43:37.0 4/3/2008: Creating Surfaces Toolbar Controls
16:43:37.0 4/3/2008: Creating Surfaces GameEx Logo
16:43:37.0 4/3/2008: Creating Surface Unselected
16:43:37.0 4/3/2008: Creating Surfaces Home & Exit
16:43:37.0 4/3/2008: Creating Surfaces Snaps
16:43:37.0 4/3/2008: Creating Surfaces Menu and List Bars
16:43:37.0 4/3/2008: Creating Fonts
16:43:37.0 4/3/2008: Creating Game Font
16:43:37.2 4/3/2008: Creating Menu Font
16:43:37.2 4/3/2008: Creating Font Black
16:43:37.4 4/3/2008: Creating Font Black Small
16:43:37.5 4/3/2008: Creating Game Font Faded
16:43:37.5 4/3/2008: Creating Title Font
16:43:37.5 4/3/2008: Restoring Title Font From Cache
16:43:37.6 4/3/2008: Fonts Created Succesfully
16:43:37.6 4/3/2008: 46mb video memory left available
16:43:37.6 4/3/2008: Creating instance of global keyboard hook
16:43:37.6 4/3/2008: Text/Language: English
16:43:37.6 4/3/2008: Applying Language/Text
16:43:37.7 4/3/2008: Initialising Bass Audio Library
16:43:37.8 4/3/2008: MAME CMD options: -triplebuffer -nowindow -joy -skip_gameinfo
16:43:37.8 4/3/2008: Loading last used Game List
16:43:37.8 4/3/2008: Setting Music Volume
16:43:37.8 4/3/2008: Creating DirectSound Device
16:43:37.9 4/3/2008: Trying: Primary Sound Driver
16:43:37.9 4/3/2008: Loading Sound Files
16:43:37.9 4/3/2008: DirectSound Device Created Successfully
16:43:37.9 4/3/2008: Creating ICONS
16:43:37.9 4/3/2008: Recreating ICONS
16:43:38.1 4/3/2008: Initialising DirectInput for Gamepad support
16:43:38.2 4/3/2008: Unable to create a joystick device
16:43:38.2 4/3/2008: Playing intro sound file
16:43:38.2 4/3/2008: Initializing MCE Remote
16:43:38.2 4/3/2008: Initialization OK! Starting GameEx!
16:43:38.2 4/3/2008: Testing Main Loop Once: Processing Frame
16:43:38.7 4/3/2008: Testing Main Loop Once: Main Loop ran successfully
16:43:51.4 4/3/2008: Validating: Emulator_1: Custom Background: C:\Emulators\Project64\snaps
16:43:51.4 4/3/2008: Warning: Emulator_1: Custom Background Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_1: Snap Path: C:\Emulators\Project64\snaps
16:43:51.4 4/3/2008: Validating: Emulator_1: Control Panel Path:
16:43:51.4 4/3/2008: Warning: Emulator_1: Control Panel Path Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_1: Instructions Path:
16:43:51.4 4/3/2008: Warning: Emulator_1: Instructions Path Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_1: Database: [Console] Nintendo N64
16:43:51.4 4/3/2008: Validating: Emulator_1: Title Snap Path: C:\Emulators\Project64
16:43:51.4 4/3/2008: Validating: Emulator_1: Box Art Path: C:\Emulators\Project64
16:43:51.4 4/3/2008: Validating: Emulator_1: Cart Art Path: C:\Emulators\Project64
16:43:51.4 4/3/2008: Validating: Emulator_1: Manual Path: C:\Emulators\Project64\NTSC-US Nintendo 64 Manuals
16:43:51.4 4/3/2008: Validating: Emulator_2: Custom Background: C:\Emulators\MESS\Atari 5200
16:43:51.4 4/3/2008: Warning: Emulator_2: Custom Background Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_2: Snap Path: C:\Emulators\MESS\Atari 5200
16:43:51.4 4/3/2008: Validating: Emulator_2: Control Panel Path:
16:43:51.4 4/3/2008: Warning: Emulator_2: Control Panel Path Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_2: Instructions Path:
16:43:51.4 4/3/2008: Warning: Emulator_2: Instructions Path Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_2: Database: [Console] Atari 5200
16:43:51.4 4/3/2008: Validating: Emulator_2: Title Snap Path:
16:43:51.4 4/3/2008: Warning: Emulator_2: Title Snap Path Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_2: Box Art Path:
16:43:51.4 4/3/2008: Warning: Emulator_2: Box Art Path Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_2: Cart Art Path:
16:43:51.4 4/3/2008: Warning: Emulator_2: Cart Art Path Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_2: Manual Path:
16:43:51.4 4/3/2008: Warning: Emulator_2: Manual Path Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_3: Custom Background: C:\Emulators\ZSNES\Complete NTSC-US Super Nintendo Roms - Videos - Manuals Collection\NTSC-US Super Nintendo Videos - Snaps
16:43:51.4 4/3/2008: Warning: Emulator_3: Custom Background Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_3: Snap Path: C:\Emulators\ZSNES\Complete NTSC-US Super Nintendo Roms - Videos - Manuals Collection\NTSC-US Super Nintendo Videos - Snaps
16:43:51.4 4/3/2008: Validating: Emulator_3: Control Panel Path: C:\Emulation\Assets\Console\Nintendo SNES\Controls
16:43:51.4 4/3/2008: Warning: Emulator_3: Control Panel Path Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_3: Instructions Path:
16:43:51.4 4/3/2008: Warning: Emulator_3: Instructions Path Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_3: Database: [Console] Nintendo SNES
16:43:51.4 4/3/2008: Validating: Emulator_3: Title Snap Path: C:\Emulation\Assets\Console\Nintendo SNES\Titles
16:43:51.4 4/3/2008: Warning: Emulator_3: Title Snap Path Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_3: Box Art Path:
16:43:51.4 4/3/2008: Warning: Emulator_3: Box Art Path Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_3: Cart Art Path: C:\Emulators\ZSNES\SNESART
16:43:51.4 4/3/2008: Validating: Emulator_3: Manual Path: C:\Emulation\Assets\Console\Nintendo SNES\Manuals
16:43:51.4 4/3/2008: Warning: Emulator_3: Manual Path Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_4: Custom Background: C:\Emulators\MESS\Atari 7800
16:43:51.4 4/3/2008: Warning: Emulator_4: Custom Background Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_4: Snap Path: C:\Emulators\MESS\Atari 7800
16:43:51.4 4/3/2008: Validating: Emulator_4: Control Panel Path:
16:43:51.4 4/3/2008: Warning: Emulator_4: Control Panel Path Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_4: Instructions Path:
16:43:51.4 4/3/2008: Warning: Emulator_4: Instructions Path Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_4: Database: [Console] Atari 7800
16:43:51.4 4/3/2008: Validating: Emulator_4: Title Snap Path:
16:43:51.4 4/3/2008: Warning: Emulator_4: Title Snap Path Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_4: Box Art Path:
16:43:51.4 4/3/2008: Warning: Emulator_4: Box Art Path Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_4: Cart Art Path:
16:43:51.4 4/3/2008: Warning: Emulator_4: Cart Art Path Does not exist
16:43:51.4 4/3/2008: Validating: Emulator_4: Manual Path:
16:43:51.4 4/3/2008: Warning: Emulator_4: Manual Path Does not exist
16:43:51.5 4/3/2008: Restoring Emulator from Cache
16:43:51.5 4/3/2008: Restoring Emulator Database From Cache
16:43:59.6 4/3/2008: Running: cmd.exe /c C: mess.exe a5200 -cart C:\Emulators\MESS\good5200\5200ren\defender (1982) (atari) [b1].zip -joy -now -nonewui
16:45:51.6 4/3/2008: Exiting GameEx!
16:45:51.6 4/3/2008: Saving Settings
16:45:52.6 4/3/2008: Disposing Plugins
16:45:52.6 4/3/2008: Closing database connection
16:45:52.7 4/3/2008: Checking for applications to Launch On Exit
You must have it running outside of GameEx before it will ever work inside. I don't use MESS, so I can't advise you on how to set it up, but there are tons of threads both here and at other forums that deal with that or perhaps another member can guide you. Once you have it running outside of GameEx, then it's just a matter of sending the right command line and changing a couple settings in the GameEx configuration file to get it going.
I can see only one thing that you can try. In your configuration for the command line, you need to have quotes around the path.
should be:
16:43:59.6 4/3/2008: Running: cmd.exe /c C: mess.exe a5200 -cart "C:\Emulators\MESS\good5200\5200ren\defender (1982) (atari) [b1].zip" -joy -now -nonewui
So you need to set the command line to something like:
mess.exe a5200 -cart "[rompath]\[rom]" -joy -now -nonewui
Also, it looks like there is no path for mess.exe. I think it should look like:
C:\Emulators\MESS\mess.exe a5200 -cart "C:\Emulators\MESS\good5200\5200ren\defender (1982) (atari) [b1].zip" -joy -now -nonewui
I fixed the quote problem, but still did not help
maybe I should try something other then MESS.
what do you use for atari?
Also, did you have any other ideas about
Also
I setup ZSNES
it is doing the same thing as PJ64
goes to the game and I can hear the music but its a BLACK screen.
This is the same error that I'm getting on pj64. The sad thing is I (with help from Brian) had it working before. So if you guys would hurry up and help Spuds get this working, then I'm sure mine will work too! ;)
Like I said, I don't use MESS and I don't currently have any Atari roms. I have a few TI-99/4A roms, but that's another story :D Of course, they aren't set up, so that doesn't help either. Sorry.
Ok. Brian helped me get PJ64 working....
the command line should be: project64.exe [rompath]/[romfile]
Apparently some version of PJ64 require Quotes, and some don't....
Thanks for your help Brian! :)
ok
thanks Brian
did you give some thought to the black screen I am getting with ZSNES and PJ64??
Sorry it takes me so long to respond - I hate it when work gets in the way of my projects !!
Also
I setup ZSNES
Your emu isnt launching fullscreen.. And
you have showdesktop=FALSE in your emu config (gameex)
I thought you had something hard for me ;)
hmmm
when I set ..showdesktop=true - it begins to load the game - then a window appears (PJ64) and an error pops up "attempt to open file failed"
So then on the error box - if I click the "ok" button or try to "X" (close) the box the window fully expands to fullscreen but is white.
If then I go to file..then Open ROM and select a ROM it goes right back to a windowed screen but is now running the game correctly.
P.S> The blood on my forehead is from banging my head repeatedly on my desk.. :blink: :blink:
hmmm
P.S> The blood on my forehead is from banging my head repeatedly on my desk.. :blink::blink:
That's what mine was doing, although I didn't have any blood on my forehead... :P
This is how Brian helped me:
Thanks Tempest - but no worky for me :(
Now when I run it the window appears and the error reads " File loaded does not appear to be a valid Nintendo64 ROM. Verify your ROM's with GoodN64
P.S> in no way do i blame you for the fresh blood splatter on my keyboard !! ;)
If you read the error message, I'm pretty sure you'll find the answer. If there's any doubt about whether or not it's a Gameex problem, try running PJ64 on it's own (not through the Gameex FE) and starting the same game you tried previously...
As for the other problem:
I highly recommend that you keep a pillow handy (although one of those "keyboard wrist rests" will do)! :P
Yeah - I CAN run PJ64 without going thru GameEx
