Working on getting tg16 cd working thru GameEX. MagicEngine will from the game on its own but can't get to run thru GameEX. Below is my ini file
[Emulator_34]
STARTPAGENAME=[Console] NEC TurboGrafx CD
TITLETEXT=NEC TurboGrafx CD
StartPageLogo=TGCD
ROMFilter=*.iso
RomPath=Z:\Emulation\Assets\Console\NEC TurboGrafx CD\Transfer
SnapPath=Z:\Emulation\Assets\Console\NEC TurboGrafx CD\Snaps
TitlePath=Z:\Emulation\Assets\Console\NEC TurboGrafx CD\Titles
BoxPath=Z:\Emulation\Assets\Console\NEC TurboGrafx CD\Boxes
CartPath=Z:\Emulation\Assets\Console\NEC TurboGrafx CD\Cartridges
ManualPath=Z:\Emulation\Assets\Console\NEC TurboGrafx CD\Manuals
ControlPanelPath=
InstructionsPath=
WorkingPath=Z:\Emulation\Emulator\Console\MagicEngine
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=False
Capitals=True
RemoveBrackets=False
ShowDesktop=False
Debug=False
MAPFile=C:\Program Files\GameEx\Map Files\[Console] NEC TurboGrafx 16 Cd Directory.map
AlsoLaunch=
Command=Z:\Emulation\Emulator\Console\MagicEngine\Super CD-ROM2 System V3.01 (U).pce
OLDatZip=
LaunchBefore=""C:\Program Files\DAEMON Tools\daemon.exe" -mount 0,"[RomPath]\[RomFile]""
LaunchAfter="C:\Program Files\DAEMON Tools\daemon.exe" -unmount 0
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
DontShowInfo=
PlaySelectionMusic=
SelectionMusicFolder=
PCGame=
DATABASE=TURBOGRAPHIX16
GamesIn7Zips=
PlayInScreenSaver=True
ShowMostPlayed=True
RandomMostPlayed=True
CDCheck=
CDCheckFile=
[GENERAL]
DumbyValue=
When you hit run in GameEx, it goes to a blank screen and then says game over
Correct me if im wrong but it seems like the same mistake i have been making all week. Looks like your command for the launch is just for pce bios image file and not for the executable. if you add for example "pce.exe" followed by the bios image file it should be fine.
Looked at that after I posted. And that didn't work for me either. Could you post your working ini file for me to compare.
[Emulator_34]
StartPageLogo=TGCD
ROMFilter=*.iso
ControlPanelPath=
InstructionsPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=False
Capitals=True
ShowDesktop=False
Debug=False
AlsoLaunch=
OLDatZip=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
DontShowInfo=
PlaySelectionMusic=
PCGame=
GamesIn7Zips=
ShowMostPlayed=True
CDCheck=
CDCheckFile=
[GENERAL]
DumbyValue=
I'm not even close to being qualified to answer this, but I did stay at a holiday inn express last night...
Then only thing that I see as odd is in the two lines I have in bold above... The first has qoute's around the entire command, while the second one does not. I don't know if it makes a difference or not, it's just that I'm a pattern guy, and I don't see the pattern...
Well after spending lots of hours today, reading every thread I can find stll can't run TG16 Cd thru GameEX. To run it outside of Gameex, I must preload the iso thru Dameon Tools. Thru GameEx it never mounts the iso. Can't get Dameon to load cues at all. IU have my roms in folders, but I'm referring to that in the line
[Emulator_34]
StartPageLogo=TGCD
ROMFilter=*.cue
ControlPanelPath=
InstructionsPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=False
Capitals=True
ShowDesktop=False
Debug=False
AlsoLaunch=
Command=Pce.exe "Z:\Emulation\Emulator\Console\MagicEngine\Super CD-ROM2 System V3.01 (U).pce"
OLDatZip=
LaunchBefore=""C:\Program Files\DAEMON Tools\daemon.exe" -mount 0,"[RomPath]\[Rom]\[RomFile]""
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
DontShowInfo=
PlaySelectionMusic=
PCGame=
DATABASE=
GamesIn7Zips=
ShowMostPlayed=True
CDCheck=
CDCheckFile=
[GENERAL]
DumbyValue=
