MAME Compiler 64 and an error I don't understand.. HELP?!
Maybe you folks can tell me where I have made a mistake in my MAME v123 Compile attempt:
Directory Structure:
MinGW in C:\MinGW
MAME Source in Z:\MAME
Diff/Hi Patch in C:\MinGW\Patches
GameEX (reg'd) in C:\Games\GameEX
When I attempt to patch the first 0123u1.diff I get this report on each notice:
Applying Diff Patch...
can't find file to patch at input line 4
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|diff -Nru src-old/build/build.mak src/build/build.mak
|--- src-old/build/build.mak 2008-01-27 12:19:32.000000000 -0800
|+++ src/build/build.mak 2008-02-12 23:40:12.000000000 -0800
File to patch:
Skip this patch? [y]
Skipping patch.
3 out of 3 hunks ignored
can't find file to patch at input line 55
(example taken from first few lines of Compile Output notes)
Where have I gone wrong?
Thanks folks.
Just as a rule, triple posting is generally frowned upon.... :(
Triple? I only saw a double post.. and I 'closed' that post as best I know how.
Sorry for the double clicking.
I was counting the one in the other thread, I see you changed it.
No problem though, I just thought I'd mention it.
That happens alot.. Some time the forum is slow to respond and you hit post twice.. Its the ones that are 5 and 6 post like spamming that is frowned upon. I removed the duplicate post :)
With luck I won't ever go over 2 posts :P
Now.. anyone have a clue what I am doing wrong here?? ^
I believe its not finding your mame source make file.
Did you download the mame source?
Also they are are in 124 now so you mat want to do that one :)
Are you using the v0.123 or a v0.123u__ release? If you are using a 'u' release, then perhaps the diff isn't happy with patching the source correctly?
I am using MAME v123 (source mame0123b_i686)
The source is extracted into my MAME Folder (and runs just fine in GameEX)
I would like to stick with v123 for now, until I have a v124 rom set.
You are using the binaary... Not the source..
You cannot run the source directly.. If you look at your file name mame0123b_i686
the 123b is binary... the source will be name 123s
Welp, I am a fool.. wrong one I listed. The Source I have is indeed 'mame123s'. *duh*
Do you still have your source in the self extracting Zip file? Perhaps it would be best to start from scratch.
I will try that now.. a complete reinstall will not take me too long since I keep my roms and snap movies on another drive, not CD's. :)
Let me do so now and see if that helps.
FIXED!
Thanks to the ever wise and more than generous BH
