Not quite a GameEx qestion, more of a rom question in an attempt to make Gameex Look nice. Listed below are the formats that my roms are in. I know that E, U and J stand for Europe, Japan, and US. My question is what on earth are the bracketed text for? I spent half the morning looking around for information regarding the brcketed text and have found nothing relating to it. I want to make sure that my game list is using the original and best rom for the specific game. It seems NES and Genesis use this as I have not found it on any of my other roms.
Rom name (U) [b1].nes
Rom name (J) [p1].nes
Rom name (E) [!].nes
Rom name (U) [b2].nes
Rom name (J) [p1][a1].nes
Rom name (E) [o1].nes
Edit: I copied this from a website, This is not my work!
I'm guessing the emoticon isn't in the original list! Looks like it should have been a "B"....
  Quote
Tags are extremely confusing. Here is a quick list of ones you might come across.
Reigonal tags:
[!] - "Verified" as a good dump.
(J) - Japan.
(U) - USA.
(E) - Europe.
(EU) - Europe and USA.
(JU) - Japan and USA.
(JUE) - All regions.
(W) - World (same as JUE)
(Brazil) - duh.
[R-country] - Specific country dump.
Old MD/Genesis reigonal tags:
(1) - Japan & Korea only
(4) - USA & Brazil NTSC only
(5) - NTSC only
(8) - PAL only
(B) - any non USA
Others tags:
(Proto) - Prototype cartridge. This is an unfinished build of a game.
(Beta) - Beta cartridge. This is an unfinished build of a game.
(V1.0), (V1.1), etc - Version number.
(REV00), (REV01), etc - Revision number.
(Unl) - Unlisenced. Probably a pirate.
[a1], [a2], etc - Alternate version. Another acceptable dump.
[f1], [f2], etc - Fixed. Edited (cracked) to work in emulators.
[h1], [h2], etc - Hack. Something about this cartridge has been changed, probably by pirates. The change is likely not noticeable.
[h1C], [h2C], etc - Hack. Something about this cartridge has been changed, definitly by Chinese pirates.
[p1], [p2], etc - Pirate version. The pirates changed something about the cartridge. Likely a simple removal of copywrites or a multipack.
[t1], [t2], etc - Trained. The ROM has been edited to alter stats or other gameplay mechanics.
[o1], [o2], etc - Overdump. Lots of extra data on the end, which is likely garbage.
[b1], [b2], etc - Bad dump. You almost certainly don't want to download this.
[hI] - Intro hack.
(MP) - Mega Play.
[c] - Checksum.
[x] - Bad checksum.
(multiboot) - GBA multiboot. This is the data booted on a GBA through a link cable.
[T+language_name] - Translation + language translated to _ transator.
notes:
There is some ambiguation between tags like [f1], [h1], [h1C], [p1], and [t1].
[hI] has a cool screen added to the beggining of the ROM!
[o1] or [b1] tags mean that the ROM is essentially garbage. I don't understand why those bad eggs aren't dropped from goodsets.
Bad checksums ([x]) aren't nessisarily bad; a good dump of Dynamite Heddy has a bad checksum.
I Would give a link to the site, but they have roms....
Awesome! No links necc... that answered my question perfectly!
Visad
To make your life easier, you can just run your roms through a nointro data file.
If your talking about using CMP (and I think you are) I think it is best to rebuild to a new directory as well, the last I knew, CMP doesn't delete extraneous files, so rebulding to a new directory really cleans things up.
