I've just setup GameEx again and now all my Roms start to load and all I get is blank screen, then Im returned to the menu. This is happening with Mame and my emulators
My Advanced Mame Settings / Mame options are -triplebuffer -nowindow -joy -skip_gameinfo -nowindow -hwstretch -ddraw
My Display settings:
Game Launch Mode: NO
Run in Arcade Mode: No
I've no idea why they wont run now!!!
Well what happens when you launch the RUNLASTGAME.bat?
Its located in the gameex programs group.
My log file looks like this:
I just went to mame and chose a rom to play
19:25:23.3 21/03/2008: GameEx: Version 9.13: Starting Log
19:25:23.3 21/03/2008: Operating System Platform: Win32NT
19:25:23.3 21/03/2008: Operating System Name: Windows Vista
19:25:23.3 21/03/2008: Operating System Version: 6.0.6000
19:25:23.3 21/03/2008: Vista Aero running
19:25:23.3 21/03/2008: Initializing Vista volume control
19:25:23.3 21/03/2008: Checking for versions of .net Framework installed
19:25:23.3 21/03/2008: .net Framework 1.1 Installed
19:25:23.3 21/03/2008: .net Framework 2.0 Installed
19:25:23.3 21/03/2008: Intel® Core2 Duo CPU E6750 @ 2.66GHz, 2046MB
19:25:23.3 21/03/2008: 2.67Ghz - 2 Cores or CPU's
19:25:23.3 21/03/2008: Running Randomize()
19:25:23.3 21/03/2008: Loading PlugIns
19:25:23.3 21/03/2008: Checking for applications to Launch On Startup
19:25:23.3 21/03/2008: Running Misc startup tasks
19:25:23.3 21/03/2008: Setting Menu types
19:25:23.3 21/03/2008: Opening Configuration File
19:25:23.3 21/03/2008: Getting Configuration Values
19:25:23.3 21/03/2008: Using Theme: Acidbrain Vision
19:25:23.3 21/03/2008: Checking for alternate Image Directory for Theme: Acidbrain Vision
19:25:23.4 21/03/2008: Launching HideOS.exe
19:25:23.4 21/03/2008: Initialising Video/MNG DLL's
19:25:23.4 21/03/2008: Hiding Taskbar
19:25:23.4 21/03/2008: Is Media Center running?
19:25:23.4 21/03/2008: Checking/Creating LCD Registry values
19:25:23.4 21/03/2008: Check Media Center Exit/Start Mode
19:25:23.4 21/03/2008: Media Center Mode 2
19:25:23.4 21/03/2008: Video previews on. Warning: Only recommended on modern systems
19:25:23.4 21/03/2008: Snap Delay set to: 2
19:25:23.4 21/03/2008: Get other settings
19:25:23.4 21/03/2008: Reading MAME hall of fame
19:25:23.4 21/03/2008: Set: Find emulator artwork on best match basis
19:25:23.4 21/03/2008: Start work for Form
19:25:23.4 21/03/2008: Getting Original Screen Size
19:25:23.4 21/03/2008: Opening Database Connection
19:25:23.4 21/03/2008: Initializing Component
19:25:23.5 21/03/2008: Retrieving resolution setting
19:25:23.5 21/03/2008: Creating Radio Station Genres
19:25:23.6 21/03/2008: Succesfully created station genres
19:25:23.6 21/03/2008: Initialising Windows Media Player Component
19:25:23.6 21/03/2008: MAME Path is: E:\Downloads\Mame32
19:25:23.6 21/03/2008: AdvanceMAME Path is: E:\Downloads\AdvanceMAME
19:25:23.6 21/03/2008: AdvanceMAME EXE file is: advmame.exe
19:25:23.6 21/03/2008: Use AdvanceMAME on. advmame.exe will launch games
19:25:23.6 21/03/2008: daphne Path is: E:\Downloads\Daphne
19:25:23.6 21/03/2008: daphne EXE file is: Daphne.exe
19:25:23.6 21/03/2008: Use daphne on. Daphne.exe will launch games
19:25:23.6 21/03/2008: ZiNc Path is: e:\Emulators\ZiNc
19:25:23.6 21/03/2008: ZiNc EXE file is: zinc.exe
19:25:23.6 21/03/2008: Use ZiNc on. zinc.exe will launch PSX games
19:25:23.6 21/03/2008: MAME EXE file is: Mame32.exe
19:25:23.6 21/03/2008: ROM Path is: e:\Downloads\Roms
19:25:23.6 21/03/2008: Catver.ini is located at: E:\Downloads\GameEx\DATA\catver.ini
19:25:23.6 21/03/2008: controls.ini is located at: E:\Downloads\GameEx\data\controls.ini
19:25:23.6 21/03/2008: History.dat is located at: E:\Downloads\GameEx\DATA\history.dat
19:25:23.6 21/03/2008: nplayers.ini is located at: E:\Downloads\GameEx\DATA\nplayers.ini
19:25:23.6 21/03/2008: MAMEinfo.dat is located at: E:\Downloads\GameEx\DATA\mameinfo.dat
19:25:23.6 21/03/2008: Loading Controls.ini map file
19:25:23.6 21/03/2008: Snap Path: Not Found
19:25:23.6 21/03/2008: AVI Snap Path: Not Found
19:25:23.6 21/03/2008: Flyer Path: Not Found
19:25:23.6 21/03/2008: Cabinet Path: Not Found
19:25:23.6 21/03/2008: Title Path: Not Found
19:25:23.6 21/03/2008: PCB Path: Not Found
19:25:23.6 21/03/2008: Artwork Preview Path: Not Found
19:25:23.6 21/03/2008: Panel Path: Not Found
19:25:23.6 21/03/2008: Manual Path: Not Found
19:25:23.6 21/03/2008: Icon Path: Not Found
19:25:23.6 21/03/2008: Marquee Path: Not Found
19:25:23.6 21/03/2008: Loading Custom Emulators
19:25:23.6 21/03/2008: Loading Emulator 1: Nintendo 64 Games
19:25:23.6 21/03/2008: Loading Emulator 2: Nintendo SNES games
19:25:23.7 21/03/2008: Loading Emulator 4: Nintendo NES Games
19:25:25.8 21/03/2008: Using 2D Animations
19:25:25.8 21/03/2008: Using General Font: Trebuchet MS
19:25:25.8 21/03/2008: Using Title Font: Trebuchet MS
19:25:25.8 21/03/2008: Attempting to load game list
19:25:26.1 21/03/2008: Initialising DirectDraw
19:25:26.1 21/03/2008: Applying GameEx is Loading Image
19:25:26.8 21/03/2008: Creating DirectDraw Device
19:25:26.8 21/03/2008: Using Device: NVIDIA GeForce 6500
19:25:26.9 21/03/2008: 886mb video memory available
19:25:27.1 21/03/2008: Setting Resolution to 1024x768 32 bit color
19:25:27.6 21/03/2008: Creating DirectDraw Surfaces
19:25:27.6 21/03/2008: Creating Primary Surface - Full Screen Mode
19:25:27.6 21/03/2008: Creating Back Buffer
19:25:27.6 21/03/2008: Version 2 Theme being used. Loading.
19:25:27.6 21/03/2008: Loading Button Data
19:25:27.6 21/03/2008: Loading Font Data
19:25:27.6 21/03/2008: Loading Layout Data
19:25:27.6 21/03/2008: Loading Taskbar Data
19:25:27.6 21/03/2008: Loading graphic Surfaces
19:25:27.6 21/03/2008: Display is running at: 1024x768 32bit color, 75hz
19:25:27.8 21/03/2008: Creating Surfaces Misc and Dialogs
19:25:27.8 21/03/2008: Creating Surfaces Volume
19:25:27.8 21/03/2008: Creating Surfaces Arrows
19:25:27.8 21/03/2008: Creating Surfaces GameEXlogo Text
19:25:27.8 21/03/2008: Creating Surfaces Toolbar
19:25:27.9 21/03/2008: Creating Surfaces Backgrounds
19:25:28.0 21/03/2008: Creating Surfaces Toolbar Controls
19:25:28.0 21/03/2008: Creating Surfaces GameEx Logo
19:25:28.0 21/03/2008: Creating Surface Unselected
19:25:28.1 21/03/2008: Creating Surfaces Home & Exit
19:25:28.1 21/03/2008: Creating Surfaces Snaps
19:25:28.1 21/03/2008: Creating Surfaces Menu and List Bars
19:25:28.1 21/03/2008: Creating Fonts
19:25:28.1 21/03/2008: Creating Game Font
19:25:28.2 21/03/2008: Creating Menu Font
19:25:28.2 21/03/2008: Restoring Menu Font From Cache
19:25:28.2 21/03/2008: Creating Font Black
19:25:28.3 21/03/2008: Creating Font Black Small
19:25:28.3 21/03/2008: Creating Game Font Faded
19:25:28.4 21/03/2008: Creating Title Font
19:25:28.4 21/03/2008: Restoring Title Font From Cache
19:25:28.4 21/03/2008: Fonts Created Succesfully
19:25:28.4 21/03/2008: 831mb video memory left available
19:25:28.4 21/03/2008: Creating instance of global keyboard hook
19:25:28.4 21/03/2008: Text/Language: English
19:25:28.4 21/03/2008: Applying Language/Text
19:25:28.4 21/03/2008: Initialising Bass Audio Library
19:25:28.5 21/03/2008: MAME CMD options: -triplebuffer -nowindow -joy -skip_gameinfo -nowindow -hwstretch -ddraw
19:25:28.5 21/03/2008: Loading last used Game List
19:25:28.5 21/03/2008: Setting Music Volume
19:25:28.5 21/03/2008: Creating DirectSound Device
19:25:28.5 21/03/2008: Trying: Primary Sound Driver
19:25:28.5 21/03/2008: Loading Sound Files
19:25:28.5 21/03/2008: DirectSound Device Created Successfully
19:25:28.5 21/03/2008: Initialising DirectInput for Gamepad support
19:25:28.6 21/03/2008: Unable to create a joystick device
19:25:28.6 21/03/2008: Playing intro sound file
19:25:28.6 21/03/2008: Initializing MCE Remote
19:25:28.6 21/03/2008: Initialization OK! Starting GameEx!
19:25:28.6 21/03/2008: Testing Main Loop Once: Processing Frame
19:25:28.8 21/03/2008: Testing Main Loop Once: Main Loop ran successfully
19:25:44.0 21/03/2008: Running: cmd.exe /c E: E:\Downloads\AdvanceMAME\advmame.exe 9ballsht -device_video_output fullscreen -quiet -dir_rom "C:\Emulators\Mame32\roms"
19:25:56.8 21/03/2008: Exiting GameEx!
19:25:56.8 21/03/2008: Saving Settings
19:25:58.6 21/03/2008: Disposing Plugins
19:25:58.6 21/03/2008: Closing database connection
19:25:58.6 21/03/2008: Checking for applications to Launch On Exit
19:25:58.6 21/03/2008: Media Center was not open when starting GameEx, so not launching
Edit the RunLastGame.bat file and add 'PAUSE' to the end of it. Then, rerun the batch file. This will leave it on the screen so you can see the error.
This is probably not right.... I'm depressed today, don't let it bother you...
To me it looks like maybe your paths are not right. It shows roms @ E:\downloads\roms (or something like that)
You are running advance mame with a path of C:\mame32\roms (or something like that)
Are these correct?
I ran the lastgame.bat and here's the log
21:34:10.3 21/03/2008: GameEx: Version 9.13: Starting Log
21:34:10.3 21/03/2008: Operating System Platform: Win32NT
21:34:10.3 21/03/2008: Operating System Name: Windows Vista
21:34:10.3 21/03/2008: Operating System Version: 6.0.6000
21:34:10.3 21/03/2008: Vista Aero running
21:34:10.3 21/03/2008: Initializing Vista volume control
21:34:10.3 21/03/2008: Checking for versions of .net Framework installed
21:34:10.3 21/03/2008: .net Framework 1.1 Installed
21:34:10.3 21/03/2008: .net Framework 2.0 Installed
21:34:10.3 21/03/2008: Intel® Core2 Duo CPU E6750 @ 2.66GHz, 2046MB
21:34:10.3 21/03/2008: 2.67Ghz - 2 Cores or CPU's
21:34:10.3 21/03/2008: Running Randomize()
21:34:10.3 21/03/2008: Loading PlugIns
21:34:10.3 21/03/2008: Checking for applications to Launch On Startup
21:34:10.3 21/03/2008: Running Misc startup tasks
21:34:10.3 21/03/2008: Setting Menu types
21:34:10.3 21/03/2008: Opening Configuration File
21:34:10.3 21/03/2008: Getting Configuration Values
21:34:10.3 21/03/2008: Using Theme: Acidbrain Vision
21:34:10.3 21/03/2008: Checking for alternate Image Directory for Theme: Acidbrain Vision
21:34:10.3 21/03/2008: Launching HideOS.exe
21:34:10.3 21/03/2008: Initialising Video/MNG DLL's
21:34:10.3 21/03/2008: Hiding Taskbar
21:34:10.3 21/03/2008: Is Media Center running?
21:34:10.3 21/03/2008: Checking/Creating LCD Registry values
21:34:10.3 21/03/2008: Check Media Center Exit/Start Mode
21:34:10.3 21/03/2008: Media Center Mode 2
21:34:10.3 21/03/2008: Video previews on. Warning: Only recommended on modern systems
21:34:10.3 21/03/2008: Snap Delay set to: 2
21:34:10.3 21/03/2008: Get other settings
21:34:10.5 21/03/2008: Reading MAME hall of fame
21:34:10.5 21/03/2008: Set: Find emulator artwork on best match basis
21:34:10.5 21/03/2008: Start work for Form
21:34:10.5 21/03/2008: Getting Original Screen Size
21:34:10.5 21/03/2008: Opening Database Connection
21:34:10.6 21/03/2008: Initializing Component
21:34:10.7 21/03/2008: Retrieving resolution setting
21:34:10.7 21/03/2008: Creating Radio Station Genres
21:34:10.7 21/03/2008: Succesfully created station genres
21:34:10.7 21/03/2008: Initialising Windows Media Player Component
21:34:10.7 21/03/2008: MAME Path is: E:\Downloads\Mame32
21:34:10.7 21/03/2008: AdvanceMAME Path is: E:\Downloads\AdvanceMAME
21:34:10.7 21/03/2008: AdvanceMAME EXE file is: advmame.exe
21:34:10.7 21/03/2008: Use AdvanceMAME on. advmame.exe will launch games
21:34:10.7 21/03/2008: daphne Path is: E:\Downloads\Daphne
21:34:10.7 21/03/2008: daphne EXE file is: Daphne.exe
21:34:10.7 21/03/2008: Use daphne on. Daphne.exe will launch games
21:34:10.7 21/03/2008: ZiNc Path is: e:\Emulators\ZiNc
21:34:10.7 21/03/2008: ZiNc EXE file is: zinc.exe
21:34:10.7 21/03/2008: Use ZiNc on. zinc.exe will launch PSX games
21:34:10.7 21/03/2008: MAME EXE file is: Mame32.exe
21:34:10.7 21/03/2008: ROM Path is: e:\Downloads\Roms
21:34:10.7 21/03/2008: Catver.ini is located at: E:\Downloads\GameEx\DATA\catver.ini
21:34:10.7 21/03/2008: controls.ini is located at: E:\Downloads\GameEx\data\controls.ini
21:34:10.7 21/03/2008: History.dat is located at: E:\Downloads\GameEx\DATA\history.dat
21:34:10.7 21/03/2008: nplayers.ini is located at: E:\Downloads\GameEx\DATA\nplayers.ini
21:34:10.7 21/03/2008: MAMEinfo.dat is located at: E:\Downloads\GameEx\DATA\mameinfo.dat
21:34:10.7 21/03/2008: Loading Controls.ini map file
21:34:10.7 21/03/2008: Snap Path: Not Found
21:34:10.7 21/03/2008: AVI Snap Path: Not Found
21:34:10.7 21/03/2008: Flyer Path: Not Found
21:34:10.7 21/03/2008: Cabinet Path: Not Found
21:34:10.7 21/03/2008: Title Path: Not Found
21:34:10.7 21/03/2008: PCB Path: Not Found
21:34:10.7 21/03/2008: Artwork Preview Path: Not Found
21:34:10.7 21/03/2008: Panel Path: Not Found
21:34:10.7 21/03/2008: Manual Path: Not Found
21:34:10.7 21/03/2008: Icon Path: Not Found
21:34:10.7 21/03/2008: Marquee Path: Not Found
21:34:10.8 21/03/2008: Loading Custom Emulators
21:34:10.8 21/03/2008: Loading Emulator 1: Nintendo 64 Games
21:34:10.8 21/03/2008: Loading Emulator 2: Nintendo SNES games
21:34:10.8 21/03/2008: Loading Emulator 4: Nintendo NES Games
21:34:13.7 21/03/2008: Using 2D Animations
21:34:13.7 21/03/2008: Using General Font: Trebuchet MS
21:34:13.7 21/03/2008: Using Title Font: Trebuchet MS
21:34:13.7 21/03/2008: Attempting to load game list
21:34:14.0 21/03/2008: Initialising DirectDraw
21:34:14.0 21/03/2008: Applying GameEx is Loading Image
21:34:14.0 21/03/2008: Creating DirectDraw Device
21:34:14.0 21/03/2008: Using Device: NVIDIA GeForce 6500
21:34:14.1 21/03/2008: 886mb video memory available
21:34:14.3 21/03/2008: Setting Resolution to 1024x768 32 bit color
21:34:14.7 21/03/2008: Creating DirectDraw Surfaces
21:34:14.7 21/03/2008: Creating Primary Surface - Full Screen Mode
21:34:14.7 21/03/2008: Creating Back Buffer
21:34:14.7 21/03/2008: Version 2 Theme being used. Loading.
21:34:14.7 21/03/2008: Loading Button Data
21:34:14.8 21/03/2008: Loading Font Data
21:34:14.8 21/03/2008: Loading Layout Data
21:34:14.8 21/03/2008: Loading Taskbar Data
21:34:14.8 21/03/2008: Loading graphic Surfaces
21:34:14.8 21/03/2008: Display is running at: 1024x768 32bit color, 75hz
21:34:14.9 21/03/2008: Creating Surfaces Misc and Dialogs
21:34:15.0 21/03/2008: Creating Surfaces Volume
21:34:15.0 21/03/2008: Creating Surfaces Arrows
21:34:15.1 21/03/2008: Creating Surfaces GameEXlogo Text
21:34:15.1 21/03/2008: Creating Surfaces Toolbar
21:34:15.2 21/03/2008: Creating Surfaces Backgrounds
21:34:15.5 21/03/2008: Creating Surfaces Toolbar Controls
21:34:15.5 21/03/2008: Creating Surfaces GameEx Logo
21:34:15.5 21/03/2008: Creating Surface Unselected
21:34:15.5 21/03/2008: Creating Surfaces Home & Exit
21:34:15.6 21/03/2008: Creating Surfaces Snaps
21:34:15.6 21/03/2008: Creating Surfaces Menu and List Bars
21:34:15.6 21/03/2008: Creating Fonts
21:34:15.6 21/03/2008: Creating Game Font
21:34:15.8 21/03/2008: Creating Menu Font
21:34:15.8 21/03/2008: Restoring Menu Font From Cache
21:34:15.8 21/03/2008: Creating Font Black
21:34:15.9 21/03/2008: Creating Font Black Small
21:34:16.0 21/03/2008: Creating Game Font Faded
21:34:16.0 21/03/2008: Creating Title Font
21:34:16.0 21/03/2008: Restoring Title Font From Cache
21:34:16.1 21/03/2008: Fonts Created Succesfully
21:34:16.1 21/03/2008: 831mb video memory left available
21:34:16.1 21/03/2008: Creating instance of global keyboard hook
21:34:16.1 21/03/2008: Text/Language: English
21:34:16.1 21/03/2008: Applying Language/Text
21:34:16.2 21/03/2008: Initialising Bass Audio Library
21:34:16.3 21/03/2008: MAME CMD options: -triplebuffer -nowindow -joy -skip_gameinfo -nowindow -hwstretch -ddraw
21:34:16.3 21/03/2008: Loading last used Game List
21:34:16.3 21/03/2008: Setting Music Volume
21:34:16.3 21/03/2008: Creating DirectSound Device
21:34:16.3 21/03/2008: Trying: Primary Sound Driver
21:34:16.3 21/03/2008: Loading Sound Files
21:34:16.5 21/03/2008: DirectSound Device Created Successfully
21:34:16.5 21/03/2008: Initialising DirectInput for Gamepad support
21:34:16.5 21/03/2008: Unable to create a joystick device
21:34:16.5 21/03/2008: Playing intro sound file
21:34:16.5 21/03/2008: Initializing MCE Remote
21:34:16.5 21/03/2008: Initialization OK! Starting GameEx!
21:34:16.5 21/03/2008: Testing Main Loop Once: Processing Frame
21:34:16.8 21/03/2008: Testing Main Loop Once: Main Loop ran successfully
21:34:41.1 21/03/2008: Running: cmd.exe /c E: E:\Downloads\AdvanceMAME\advmame.exe 2020bb -device_video_output fullscreen -quiet -dir_rom "C:\Emulators\Mame32\roms"
21:34:55.9 21/03/2008: Exiting GameEx!
21:34:55.9 21/03/2008: Saving Settings
21:34:57.2 21/03/2008: Disposing Plugins
21:34:57.2 21/03/2008: Closing database connection
21:34:57.3 21/03/2008: Checking for applications to Launch On Exit
21:34:57.3 21/03/2008: Media Center was not open when starting GameEx, so not launching
"C:\Emulators\Mame32\roms" isnt corret but the first part of the line E:\Downloads\AdvanceMAME\advmame.exe is
Where do i change the mame32 settings?
use the setup wizard
choose "custom", then "Advancemame" (not advanced mame settings)
then advancemame options... you may have to go to the right to see it, but the path is there.
It looks like this is set at a "standard" path, because mine is the same as yours. I don't use advancemame, so I never noticed.
Brian - I GOT ONE RIGHT! :lol:
Good job!
Just to note advanced mame isnt regulary updated so it wont support newer rom sets.. There may be quite a few broken games becuase of this. Id recommed not using advanced mame and stick with regular mame. Advanced mame got its popularity because of the obscure video modes it supported. But when you have programs like soft 15hz there really is no need for it. Especially if you want to play newer games mame supports.
Thanks that fixed the problem with Mame!!
No, just tried the snes roms and the same things happening
Here's the log:
21:58:03.4 21/03/2008: GameEx: Version 9.13: Starting Log
21:58:03.4 21/03/2008: Operating System Platform: Win32NT
21:58:03.4 21/03/2008: Operating System Name: Windows Vista
21:58:03.4 21/03/2008: Operating System Version: 6.0.6000
21:58:03.4 21/03/2008: Vista Aero running
21:58:03.4 21/03/2008: Initializing Vista volume control
21:58:03.4 21/03/2008: Checking for versions of .net Framework installed
21:58:03.4 21/03/2008: .net Framework 1.1 Installed
21:58:03.4 21/03/2008: .net Framework 2.0 Installed
21:58:03.4 21/03/2008: Intel® Core2 Duo CPU E6750 @ 2.66GHz, 2046MB
21:58:03.4 21/03/2008: 2.67Ghz - 2 Cores or CPU's
21:58:03.4 21/03/2008: Running Randomize()
21:58:03.4 21/03/2008: Loading PlugIns
21:58:03.4 21/03/2008: Checking for applications to Launch On Startup
21:58:03.4 21/03/2008: Running Misc startup tasks
21:58:03.4 21/03/2008: Setting Menu types
21:58:03.4 21/03/2008: Opening Configuration File
21:58:03.4 21/03/2008: Getting Configuration Values
21:58:03.5 21/03/2008: Using Theme: Acidbrain Vision
21:58:03.5 21/03/2008: Checking for alternate Image Directory for Theme: Acidbrain Vision
21:58:03.5 21/03/2008: Launching HideOS.exe
21:58:03.5 21/03/2008: Initialising Video/MNG DLL's
21:58:03.5 21/03/2008: Hiding Taskbar
21:58:03.5 21/03/2008: Is Media Center running?
21:58:03.5 21/03/2008: Checking/Creating LCD Registry values
21:58:03.5 21/03/2008: Check Media Center Exit/Start Mode
21:58:03.5 21/03/2008: Media Center Mode 2
21:58:03.5 21/03/2008: Video previews on. Warning: Only recommended on modern systems
21:58:03.5 21/03/2008: Snap Delay set to: 2
21:58:03.5 21/03/2008: Get other settings
21:58:03.5 21/03/2008: Reading MAME hall of fame
21:58:03.5 21/03/2008: Set: Find emulator artwork on best match basis
21:58:03.5 21/03/2008: Start work for Form
21:58:03.5 21/03/2008: Getting Original Screen Size
21:58:03.5 21/03/2008: Opening Database Connection
21:58:03.6 21/03/2008: Initializing Component
21:58:03.6 21/03/2008: Retrieving resolution setting
21:58:03.6 21/03/2008: Creating Radio Station Genres
21:58:03.8 21/03/2008: Succesfully created station genres
21:58:03.8 21/03/2008: Initialising Windows Media Player Component
21:58:03.8 21/03/2008: MAME Path is: E:\Downloads\Mame32
21:58:03.8 21/03/2008: AdvanceMAME Path is: E:\Downloads\AdvanceMAME
21:58:03.8 21/03/2008: AdvanceMAME EXE file is: advmame.exe
21:58:03.8 21/03/2008: Use AdvanceMAME on. advmame.exe will launch games
21:58:03.8 21/03/2008: daphne Path is: E:\Downloads\Daphne
21:58:03.8 21/03/2008: daphne EXE file is: Daphne.exe
21:58:03.8 21/03/2008: Use daphne on. Daphne.exe will launch games
21:58:03.8 21/03/2008: ZiNc Path is: e:\Emulators\ZiNc
21:58:03.8 21/03/2008: ZiNc EXE file is: zinc.exe
21:58:03.8 21/03/2008: Use ZiNc on. zinc.exe will launch PSX games
21:58:03.8 21/03/2008: MAME EXE file is: Mame32.exe
21:58:03.8 21/03/2008: ROM Path is: e:\Downloads\Roms
21:58:03.8 21/03/2008: Catver.ini is located at: E:\Downloads\GameEx\DATA\catver.ini
21:58:03.8 21/03/2008: controls.ini is located at: E:\Downloads\GameEx\data\controls.ini
21:58:03.8 21/03/2008: History.dat is located at: E:\Downloads\GameEx\DATA\history.dat
21:58:03.8 21/03/2008: nplayers.ini is located at: E:\Downloads\GameEx\DATA\nplayers.ini
21:58:03.8 21/03/2008: MAMEinfo.dat is located at: E:\Downloads\GameEx\DATA\mameinfo.dat
21:58:03.8 21/03/2008: Loading Controls.ini map file
21:58:03.8 21/03/2008: Snap Path: Not Found
21:58:03.8 21/03/2008: AVI Snap Path: Not Found
21:58:03.8 21/03/2008: Flyer Path: Not Found
21:58:03.8 21/03/2008: Cabinet Path: Not Found
21:58:03.8 21/03/2008: Title Path: Not Found
21:58:03.8 21/03/2008: PCB Path: Not Found
21:58:03.8 21/03/2008: Artwork Preview Path: Not Found
21:58:03.8 21/03/2008: Panel Path: Not Found
21:58:03.8 21/03/2008: Manual Path: Not Found
21:58:03.8 21/03/2008: Icon Path: Not Found
21:58:03.8 21/03/2008: Marquee Path: Not Found
21:58:03.8 21/03/2008: Loading Custom Emulators
21:58:03.8 21/03/2008: Loading Emulator 1: Nintendo 64 Games
21:58:03.9 21/03/2008: Loading Emulator 2: Nintendo SNES games
21:58:03.9 21/03/2008: Loading Emulator 4: Nintendo NES Games
21:58:04.0 21/03/2008: Using 2D Animations
21:58:04.0 21/03/2008: Using General Font: Trebuchet MS
21:58:04.0 21/03/2008: Using Title Font: Trebuchet MS
21:58:04.0 21/03/2008: Attempting to load game list
21:58:04.2 21/03/2008: Initialising DirectDraw
21:58:04.2 21/03/2008: Applying GameEx is Loading Image
21:58:04.6 21/03/2008: Creating DirectDraw Device
21:58:04.6 21/03/2008: Using Device: NVIDIA GeForce 6500
21:58:04.7 21/03/2008: 886mb video memory available
21:58:04.9 21/03/2008: Setting Resolution to 1024x768 32 bit color
21:58:05.2 21/03/2008: Creating DirectDraw Surfaces
21:58:05.2 21/03/2008: Creating Primary Surface - Full Screen Mode
21:58:05.3 21/03/2008: Creating Back Buffer
21:58:05.3 21/03/2008: Version 2 Theme being used. Loading.
21:58:05.3 21/03/2008: Loading Button Data
21:58:05.3 21/03/2008: Loading Font Data
21:58:05.3 21/03/2008: Loading Layout Data
21:58:05.3 21/03/2008: Loading Taskbar Data
21:58:05.3 21/03/2008: Loading graphic Surfaces
21:58:05.3 21/03/2008: Display is running at: 1024x768 32bit color, 75hz
21:58:05.4 21/03/2008: Creating Surfaces Misc and Dialogs
21:58:05.4 21/03/2008: Creating Surfaces Volume
21:58:05.4 21/03/2008: Creating Surfaces Arrows
21:58:05.4 21/03/2008: Creating Surfaces GameEXlogo Text
21:58:05.4 21/03/2008: Creating Surfaces Toolbar
21:58:05.4 21/03/2008: Creating Surfaces Backgrounds
21:58:05.6 21/03/2008: Creating Surfaces Toolbar Controls
21:58:05.6 21/03/2008: Creating Surfaces GameEx Logo
21:58:05.6 21/03/2008: Creating Surface Unselected
21:58:05.6 21/03/2008: Creating Surfaces Home & Exit
21:58:05.6 21/03/2008: Creating Surfaces Snaps
21:58:05.6 21/03/2008: Creating Surfaces Menu and List Bars
21:58:05.7 21/03/2008: Creating Fonts
21:58:05.7 21/03/2008: Creating Game Font
21:58:05.7 21/03/2008: Creating Menu Font
21:58:05.7 21/03/2008: Restoring Menu Font From Cache
21:58:05.7 21/03/2008: Creating Font Black
21:58:05.8 21/03/2008: Creating Font Black Small
21:58:05.9 21/03/2008: Creating Game Font Faded
21:58:05.9 21/03/2008: Creating Title Font
21:58:06.0 21/03/2008: Restoring Title Font From Cache
21:58:06.0 21/03/2008: Fonts Created Succesfully
21:58:06.0 21/03/2008: 831mb video memory left available
21:58:06.0 21/03/2008: Creating instance of global keyboard hook
21:58:06.0 21/03/2008: Text/Language: English
21:58:06.0 21/03/2008: Applying Language/Text
21:58:06.1 21/03/2008: Initialising Bass Audio Library
21:58:06.1 21/03/2008: MAME CMD options: -triplebuffer -nowindow -joy -skip_gameinfo -nowindow -hwstretch -ddraw
21:58:06.1 21/03/2008: Loading last used Game List
21:58:06.1 21/03/2008: Setting Music Volume
21:58:06.2 21/03/2008: Creating DirectSound Device
21:58:06.2 21/03/2008: Trying: Primary Sound Driver
21:58:06.2 21/03/2008: Loading Sound Files
21:58:06.2 21/03/2008: DirectSound Device Created Successfully
21:58:06.2 21/03/2008: Initialising DirectInput for Gamepad support
21:58:06.2 21/03/2008: Unable to create a joystick device
21:58:06.2 21/03/2008: Playing intro sound file
21:58:06.2 21/03/2008: Initializing MCE Remote
21:58:06.2 21/03/2008: Initialization OK! Starting GameEx!
21:58:06.2 21/03/2008: Testing Main Loop Once: Processing Frame
21:58:06.4 21/03/2008: Testing Main Loop Once: Main Loop ran successfully
21:58:47.7 21/03/2008: Validating: Emulator_1: Custom Background: D:\BitTorrent-Downloads\EmuMovies N64 AVI Game Previews for Mamewah
21:58:47.7 21/03/2008: Warning: Emulator_1: Custom Background Does not exist
21:58:47.7 21/03/2008: Validating: Emulator_1: Snap Path: D:\BitTorrent-Downloads\EmuMovies N64 AVI Game Previews for Mamewah
21:58:47.7 21/03/2008: Warning: Emulator_1: Snap Path Does not exist
21:58:47.7 21/03/2008: Validating: Emulator_1: Control Panel Path:
21:58:47.7 21/03/2008: Warning: Emulator_1: Control Panel Path Does not exist
21:58:47.7 21/03/2008: Validating: Emulator_1: Instructions Path:
21:58:47.7 21/03/2008: Warning: Emulator_1: Instructions Path Does not exist
21:58:47.7 21/03/2008: Validating: Emulator_1: Database: [Console] Nintendo N64
21:58:47.7 21/03/2008: Validating: Emulator_1: Title Snap Path:
21:58:47.7 21/03/2008: Warning: Emulator_1: Title Snap Path Does not exist
21:58:47.8 21/03/2008: Validating: Emulator_1: Box Art Path: G:\zsnes\Boxscans_SNES_(USA)_28May04
21:58:47.8 21/03/2008: Warning: Emulator_1: Box Art Path Does not exist
21:58:47.8 21/03/2008: Validating: Emulator_1: Cart Art Path: G:\zsnes\CartScans SNES USA
21:58:47.8 21/03/2008: Warning: Emulator_1: Cart Art Path Does not exist
21:58:47.8 21/03/2008: Validating: Emulator_1: Manual Path:
21:58:47.8 21/03/2008: Warning: Emulator_1: Manual Path Does not exist
21:58:47.8 21/03/2008: Loading OfflineList Dat File for emulator: 1
21:58:47.8 21/03/2008: Cannot Find Offline List Dat File
21:58:47.8 21/03/2008: Validating: Emulator_2: Custom Background: G:\zsnes\titles
21:58:47.8 21/03/2008: Warning: Emulator_2: Custom Background Does not exist
21:58:47.8 21/03/2008: Validating: Emulator_2: Snap Path: G:\zsnes\titles
21:58:47.8 21/03/2008: Warning: Emulator_2: Snap Path Does not exist
21:58:47.8 21/03/2008: Validating: Emulator_2: Control Panel Path:
21:58:47.8 21/03/2008: Warning: Emulator_2: Control Panel Path Does not exist
21:58:47.8 21/03/2008: Validating: Emulator_2: Instructions Path:
21:58:47.8 21/03/2008: Warning: Emulator_2: Instructions Path Does not exist
21:58:47.8 21/03/2008: Validating: Emulator_2: Database: [Console] Nintendo SNES
21:58:47.8 21/03/2008: Validating: Emulator_2: Title Snap Path: G:\zsnes\Boxscans_SNES_(USA)_28May04
21:58:47.8 21/03/2008: Warning: Emulator_2: Title Snap Path Does not exist
21:58:47.8 21/03/2008: Validating: Emulator_2: Box Art Path: G:\zsnes\Boxscans_SNES_(USA)_28May04
21:58:47.8 21/03/2008: Warning: Emulator_2: Box Art Path Does not exist
21:58:47.8 21/03/2008: Validating: Emulator_2: Cart Art Path: G:\zsnes\CartScans SNES USA
21:58:47.8 21/03/2008: Warning: Emulator_2: Cart Art Path Does not exist
21:58:47.8 21/03/2008: Validating: Emulator_2: Manual Path:
21:58:47.8 21/03/2008: Warning: Emulator_2: Manual Path Does not exist
21:58:47.8 21/03/2008: Loading OfflineList Dat File for emulator: 2
21:58:47.8 21/03/2008: Validating: Emulator_4: Custom Background:
21:58:47.8 21/03/2008: Warning: Emulator_4: Custom Background Does not exist
21:58:47.8 21/03/2008: Validating: Emulator_4: Snap Path:
21:58:47.8 21/03/2008: Warning: Emulator_4: Snap Path Does not exist
21:58:47.8 21/03/2008: Validating: Emulator_4: Control Panel Path:
21:58:47.8 21/03/2008: Warning: Emulator_4: Control Panel Path Does not exist
21:58:47.8 21/03/2008: Validating: Emulator_4: Instructions Path:
21:58:47.8 21/03/2008: Warning: Emulator_4: Instructions Path Does not exist
21:58:47.8 21/03/2008: Validating: Emulator_4: Database: NES
21:58:47.8 21/03/2008: Warning: Emulator_4: Database Does not exist
21:58:47.8 21/03/2008: Validating: Emulator_4: Title Snap Path:
21:58:47.8 21/03/2008: Warning: Emulator_4: Title Snap Path Does not exist
21:58:47.8 21/03/2008: Validating: Emulator_4: Box Art Path:
21:58:47.8 21/03/2008: Warning: Emulator_4: Box Art Path Does not exist
21:58:47.8 21/03/2008: Validating: Emulator_4: Cart Art Path:
21:58:47.8 21/03/2008: Warning: Emulator_4: Cart Art Path Does not exist
21:58:47.8 21/03/2008: Validating: Emulator_4: Manual Path:
21:58:47.8 21/03/2008: Warning: Emulator_4: Manual Path Does not exist
21:58:55.6 21/03/2008: Running: cmd.exe /c E: nesemu2.exe C:\Users\Mike\Desktop\NES ROMS\American Gladiators (U).nes
21:59:08.7 21/03/2008: Exiting GameEx!
21:59:08.7 21/03/2008: Saving Settings
21:59:10.7 21/03/2008: Disposing Plugins
21:59:10.7 21/03/2008: Closing database connection
21:59:10.8 21/03/2008: Checking for applications to Launch On Exit
21:59:10.8 21/03/2008: Media Center was not open when starting GameEx, so not launching
The roms in this case are located on my desktop
You need to put quotes on the command.
nesemu2.exe "[rompath]/[romfile]"
Id also use nestopia for the emulator.. In the future please create a new thread for new issues as it easier to follow and helps others having the same issues.
So would I be better off going into the setup again and select Custom??
I use the advanced configuration.
Check out my screenshot. When you have spaces in the path you need quotes.. on the [rompath]/[romfile]
To setup nestopia.. Create a new entry and fill in all the paths.. For the command it would read
nestopia.exe "[rompath]/[romfile]"
The only paths that are required are
title
page name
working path
rompath
command
so it will build the command as follows.
Working path... C:\emus\nes
rompath c:\roms\nes\
romfilter *.zip (if your roms are zipped)
command nestopia.exe "[rompath]/[romfile]"
so when you choose the rom it will build this
C:\emus\nes\nestopia.exe "c:\roms\nes\smb.zip"
How would I setup Nestopia?
I'm on a one answer roll, so I'll give it a shot...
Sure, go ahead and use the setup wizard again go to Custom, this time select "set up emulators" If I remember right, you have to choose your emulator from a drop down list, and then there are four pages for each emulator to set them up in Gameex.
Also in the setup wizard there is a place to download emulators. This time choose "search", and use "download emulators" as the search words. If the emulator you are looking for is in the list, then use gameex to download it.
I think it is best to set up an emulator outside of gameex first, to make sure everything is working, then get it to work in gameex.
There is a good guide to setting up Gameex here
http://www.hfc-essentials.net/gameex/
courtesy of Adultery (I hope that's right)
and a guide to setting up various emulators here:
http://www.mameworld.net/easyemu/
I hope I was right, and I hope this helps....(I've got my fingers crossed)
Not that it matters at this point since the problems appear to be solved. However, when I suggested running the "runlastgame.bat", I meant running it from windows. It sounds as though you were running it from within GameEx. The purpose for this is that the dos command prompt window that launches with the batch file will remain on the screen. The GameEx log file in that case won't display the error though since GameEx successfully launched the command and it successfully returned after finishing.
