Hi Tom,
This GameEx project of you is really getting incredable! I like it very much, although I seem to have a few issues:
1. I just installed 4.81, and I noticed that in he configuration fe the emulators are grouped by 5, up to 15. However, I have 18 emulator configs. Al 18 are in the config file, but why are the last 3 not in the configuration fe?
2. since A long time (for me: from the first time I started to use GameEx), the configuration fe freezes if I click a few times for the next page. I have then to CTRL-ALT-DEL to go out of the configuration fe. Why?
3. I have some newspaper web sites installed in GameEx, in which I can navigate with my remote control arrows and OK button for a link. However, if I clicked on a link and want to go back to the previous web page, it does not work on the back button. If I hit the back button I get back to GameEx, not to the previous webpage. Why?
4. I can navigate in the configuration fe with my mouse, but not with the remote control. Why not?
Are above issues caused because I have not made the right configuration choices, or is it something else?
Greetings,
Poldermamer
Hi Tom,
Greetings,
Poldermamer
1. Did you click next page, they are there.
2. Dont know, it works for me, and noone else has reported it. What .net framework are you using?
3. Because that's how its coded at the moment, until i think up something very clever.
4. Because i have not coded it to do that yet.
Nothing to do with config choices that I can see.
