Hi There People,
I am currently using 4.80 and every time I try to use custom Text/language on the config GameEx freezes when I go back into it.
I have tried several themes (Incuding the Default) and I get the same results. GameEx loads, then the intro comes and goes and almost as soon as it has disapeared it locks up. I then have to CTRL-ALT-DELETE and shut it down with task manager. I am fairly sure this is a bug because it works perfectly with default English Text with any theme. Custom Text/Language also worked in previous versions.
Has anyone got any ideas what is causing this.
J
Hi There People,
J
Can you please post GameEx.ini (Program Files\Config\GameEx.ini) please and Ill look into it.
Cheers.
No need anymore Tom. I had to restart my Computer after some Windows updates and it isn't doing it anymore? :huh:
Thanks for the support tho
J
