I noticed in the key settings (from tab menu) that a lot of things that aren't needed are assigned as either n/a or none. Both of these mean that something is unassigned, so why are some things n/a and some are none? What's the difference? I marked a bunch of n/a's as none, just for uniformity, but I wondered if that could possibly have any affect. Also, how do you mark something as n/a again?
Im assuming your talking about MAME? Actually there is a ton of stuff that isnt by default assigned to a key.. Most of which youll probably never use.
However there is alot you would want to reassign.. Like pause, config, ui select,Ui cancel,
Player 2 buttons 5 and 6... You do enjoy streetfighter correct? You really dont need to mark it back as N/A (not available) If you insist on getting your default confg back just delete the default.cfg in the config folder
Yes, I've reassigned most of my keys. I do enjoy street fighter ^_^ I'm using PS2 controllers to play it at the moment (hopefully making a control panel with xarcade stuff soon). Anyway, I was wondering if there is a difference, I don't know why they would have the two at default if there's not. It seems like certain things are marked different ways, for example you'll see areas in the button config that look like this:
None
None
None
N/a
N/a
None
Does anyone know about this?
