New to GameEx, but not the scene by a long shot, great work!
Few questions here.
How do I show the box art for NES, SNES, etc? I have the path setup in config, all the shots are there, where do you enable it? Also, for some reason im not getting screenshots to work in those either? I got all of the screens/box art from screenshotarchive.
The paths are correct.
Also, where can I get this launchbefore.bat for zsnes?
One last thing, what is the defacto place to grab mame snaps from now? IS there one big file? I got a few of crash's packs, but they are all seperated in to folders by version.
Any help appreciated, once again, great stuff here!
Few questions here.
You need to extract the images in the root of the folder you specify, not in subdirectories and not in a zip. I think thats your problem. The box art etc can be viewed after selecting the game in GameEx. Assuming everything setup right you should see them on that page, below where it says play this game. You dont need launchbefore.bat its just there for example purposes for the launchbefore feature that allows you to run programs or scripts before GameEx runs the game.
Dunno about screeenshots, I got mine from crashtest. It was a pain do download each file, but I think he has a torrent available now.
Tom
Tom
No, the art is in the right place, there is no subdir, it is in E:\Roms\NES\Snap\Box
from there, all the single images are in that dir. That is also the dir that is specified for gameex
For the snaps, i have the snaps downloaded, but they are in seperated folders by release (eg. Pack 1 has .1 folder, .2, etc.)
