Hi, I'm new to emulators and gameex in general, but is there any step by step documentation on how to setup gameex with different emulators.
I can't even get MAME32 to work playing asteroids.
Here is my log.txt file:
18:05:07.0  8/12/2005:  GameEx: Version 4.73: Starting Log
18:05:07.1  8/12/2005:  Operating System Platform: Win32NT
18:05:07.1  8/12/2005:  Operating System Name: Windows XP
18:05:07.1  8/12/2005:  Operating System Version: 5.1.2600
18:05:07.1  8/12/2005:  Running Randomize()
18:05:07.1  8/12/2005:  Running Misc startup tasks
18:05:07.1  8/12/2005:  Hiding Cursor
18:05:07.1  8/12/2005:  Setting Menu types
18:05:07.1  8/12/2005:  Opening Configuration File
18:05:07.1  8/12/2005:  Getting Configuration Values
18:05:07.2  8/12/2005:  Using Theme: Default - GameEx - Animated
18:05:07.2  8/12/2005:  Checking for alternate Image Directory for Theme: Default - GameEx - Animated
18:05:07.2  8/12/2005:  Using Images from theme: Default - GameEx\MEDIA\
18:05:07.2  8/12/2005:  Text/Language: English
18:05:07.2  8/12/2005:  Applying Language/Text
18:05:07.2  8/12/2005:  Creating Scancodes.txt (List of DirectInput scan codes)
18:05:07.2  8/12/2005:  Snap Delay set to: 1
18:05:07.2  8/12/2005:  Is Media Center running?
18:05:07.2  8/12/2005:  Check Media Center Exit/Start Mode
18:05:07.2  8/12/2005:  Media Center Mode 2
18:05:07.2  8/12/2005:  Checking for applications to Launch On Startup
18:05:07.2  8/12/2005:  Get other settings
18:05:07.3  8/12/2005:  Launching HideOS.exe
18:05:08.5  8/12/2005:  Hiding Taskbar
18:05:08.6  8/12/2005:  Start work for Form
18:05:08.6  8/12/2005:  Getting Original Screen Size
18:05:08.6  8/12/2005:  Loading ICON
18:05:08.6  8/12/2005:  Initializing Component
18:05:08.6  8/12/2005:  Initialising Bass Audio Library
18:05:08.9  8/12/2005:  Loading default loading screen
18:05:08.9  8/12/2005:  Using General Font: HandelGothic BT
18:05:08.9  8/12/2005:  Using Title Font: HandelGothic BT
18:05:08.9  8/12/2005:  Initialising DirectDraw
18:05:08.9  8/12/2005:  Applying GameEx is Loading Image
18:05:09.1  8/12/2005:  Creating DirectDraw Device
18:05:09.1  8/12/2005:  Using Device: GIGABYTE RADEON 9600 PRO
18:05:09.3  8/12/2005:  Setting Resolution to 800x600 32 bit color
18:05:10.6  8/12/2005:  Creating DirectDraw Surfaces
18:05:10.6  8/12/2005:  Creating Primary Surface - Full Screen Mode
18:05:10.6  8/12/2005:  Creating Back Buffer
18:05:10.6  8/12/2005:  Loading graphic surfaces
18:05:10.6  8/12/2005:  Creating Surfaces Misc and Dialogs
18:05:10.7  8/12/2005:  Creating Surface Volume
18:05:10.7  8/12/2005:  Creating Surfaces Arrows
18:05:10.8  8/12/2005:  Creating Surfaces GameEXlogo Text
18:05:10.8  8/12/2005:  Creating Surfaces Toolbar
18:05:10.9  8/12/2005:  Creating Surfaces Backgrounds
18:05:11.9  8/12/2005:  Creating Surfaces Toolbar Controls
18:05:12.0  8/12/2005:  Creating Surfaces GameEx Logo
18:05:12.0  8/12/2005:  Creating Surfaces Home & Exit
18:05:12.0  8/12/2005:  Creating Surfaces Snaps
18:05:12.0  8/12/2005:  Creating Surfaces Menu and List Bars
18:05:12.2  8/12/2005:  Creating Fonts
18:05:12.2  8/12/2005:  Creating Menu Font
18:05:12.6  8/12/2005:  Creating Game Font
18:05:13.0  8/12/2005:  Creating Game Font Standard Size
18:05:13.2  8/12/2005:  Creating Font Black
18:05:13.3  8/12/2005:  Creating Font Black Small
18:05:13.4  8/12/2005:  Creating Game Font Faded
18:05:13.7  8/12/2005:  Creating Title Font
18:05:14.3  8/12/2005:  MAME Path is: C:\Program Files\GameEx\Emu\MAME
18:05:14.4  8/12/2005:  MAME EXE file is: Mame32.exe
18:05:14.4  8/12/2005:  ROM Path is: C:\Program Files\GameEx\Emu\MAME\roms
18:05:14.4  8/12/2005:  Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
18:05:14.4  8/12/2005:  controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
18:05:14.4  8/12/2005:  History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
18:05:14.4  8/12/2005:  nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
18:05:14.4  8/12/2005:  MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
18:05:14.4  8/12/2005:  Loading Controls.ini map file
18:05:14.4  8/12/2005:  Loading Custom Emulators
18:05:14.6  8/12/2005:  Snap Path is: C:\Program Files\GameEx\Emu\MAME\snap
18:05:14.6  8/12/2005:  AVI Snap Path: Not Found
18:05:14.6  8/12/2005:  Flyer Path is: C:\Program Files\GameEx\Emu\MAME\flyers
18:05:14.6  8/12/2005:  Cabinet Path is: C:\Program Files\GameEx\Emu\MAME\cabinets
18:05:14.6  8/12/2005:  Title Path is: C:\Program Files\GameEx\Emu\MAME\titles
18:05:14.6  8/12/2005:  Panel Path: Not Found
18:05:14.6  8/12/2005:  Icon Path is: C:\Program Files\GameEx\Emu\MAME\icons
18:05:14.6  8/12/2005:  Marquee Path is: C:\Program Files\GameEx\Emu\MAME\marquees
18:05:14.6  8/12/2005:  MAME CMD options: -skip_disclaimer -skip_gameinfo -triplebuffer -nowindow -joy
18:05:14.6  8/12/2005:  Attempting to load game list
18:05:15.0  8/12/2005:  Loading last used Game List
18:05:15.0  8/12/2005:  Cannot Load Play List. Check Path and filename
18:05:15.0  8/12/2005:  Creating DirectSound Device
18:05:15.0  8/12/2005:  Trying: Primary Sound Driver
18:05:15.0  8/12/2005:  Loading Sound Files
18:05:15.1  8/12/2005:  DirectSound Device Created Successfully
18:05:15.1  8/12/2005:  Creating ICONS
18:05:15.5  8/12/2005:  Initialising DirectInput for Gamepad support
18:05:15.6  8/12/2005:  Using Device Saitek X52 Flight Stick (USB)
18:05:15.6  8/12/2005:  Playing intro sound file
18:05:15.6  8/12/2005:  Initializing MCE Remote
18:05:15.6  8/12/2005:  Initialization OK! Starting GameEx!
18:05:15.6  8/12/2005:  Testing Main Loop Once: Processing Frame
18:05:15.8  8/12/2005:  Testing Main Loop Once: Main Loop ran successfully
18:05:29.0  8/12/2005:  Running: cmd.exe /c C: C:\Program Files\GameEx\Emu\MAME\Mame32.exe asteroi1 -rompath C:\Program Files\GameEx\Emu\MAME\roms -skip_disclaimer -skip_gameinfo -triplebuffer -nowindow -joy
18:05:51.5  8/12/2005:  Exiting GameEx!
18:05:51.5  8/12/2005:  Saving Settings
18:05:51.5  8/12/2005:  Writing Game List to disk
18:05:53.7  8/12/2005:  Checking for applications to Launch On Exit
Thanks for any help provided! :D
How exactly is it no working, what exactly happens? Do any MAME games work?
Sorry, there is no step by step guide, perhaps someone will write one some day. GameEx is mostly a one man band (me), and I have not had time to document everything completely. I certainly welcome people who want to help out though.
No problem Tom, just thought I'd ask before bugging you guys too much. :)
Basically, I ran the update list option and it did it's thing. I guess GameEx or MAME32 comes with a bunch of games already because I was only expecting one game to be listed but there was a ton. So I went to select Asteroids to play and the screen refreshes a couple time(it's black the entire time though) and I can tell it even resizes, but then it just goes back to GameEx. This happens for every game I try.
Can you go to the start menu, the gameex program group, and select run last game. See if it runs. If it does not its not a GameEx issue but a MAME32 issue. You've probably got bad roms, although with the default options GameEx should have filtered these out when updating the list.
GameEx and MAME32 dont come with any games. Where did you get them from?
