I use the Interact PC Gamepad for control. When using the DVD playback feature I have found that when I press button 4 it will quit the DVD playback with a "selected" sound and then go back to the GameEx menu. However, I can no longer play DVDs after this without restarting GameEx. If I try to play DVDs again...the screen turns black and then I hear the "selected" sound and the I end up back at the GameEx menu.
It works fine for me. Which DVD Decoder are you using? Are you using FFDSHOW, which version?
Im using the decoder that came with PowerDVD 6.
Im not using FFDShow. (tho I did try with the newest...and still the same)
It just seems that for some odd reason..it thinks I'm pressing the 4 button again. My controller is not set up for autofire..etc
I think the issue is not to do with your Game Pad. I expect if you press Space or your the mouse to exit yourll get the same thing? I think the DVD Player wont reinitialize for some reason. If it encounters an error thats exactly what it does.
Which version of Windows Media Player do you have? Which version of Windows do you have?
Windows XP Pro SP2
Windows Media Player 10
*** I think your right about the re-init...my log only shows 1 access to the DVD player...even tho i tried it 5 times after
