I have a prob with using vpinball in gameEx, some of the tables sounds are too low, yet the noise of the ball, and the flippers is quite loud, but the music and voice overs are too soft, I have turned up all the sounds to max in vpinball.
some tables are fine, but the majority arent.
am using the latest G/Ex as of today
probs existed in the past with this as well. Is there an option to turn up the table sounds? besides the option in vpinball, audio settings.
( i have turned up the volume in the config for Game Ex as well.)
that isnt a issue with Game-Ex but vpinball ...
let me get you right is it VPinMAME Tables or plain vpinball tables ??
well if its VPinMAME tables then you can press the "end" key to open the coinbox then press 8 and 9 to adjust the volume others tables you can do it just with the 8-9 keys ...
