Hello All,
I've built a cocktail mame and I have one problem left to fix.
I have the "Advance MAME Settings" set to "Only Vertical Cocktail Games", and my problem is the menu buttons are to small.
I hope this is just some setting I have overlooked.
Ourgrace
Hello All,
Ourgrace
Can you post a screen? I dont know what you mean.
Sorry
I meant to put up screen shots,
When I played around with it today I also got an error so here is my log also.
Thanks all.
07:21:41.2 5/1/2005: GameEx: Version 8.96: Starting Log
07:21:41.3 5/1/2005: Operating System Platform: Win32NT
07:21:41.3 5/1/2005: Operating System Name: Windows XP
07:21:41.3 5/1/2005: Operating System Version: 5.1.2600
07:21:41.3 5/1/2005: Checking for versions of .net Framework installed
07:21:41.3 5/1/2005: .net Framework 1.1 Installed
07:21:41.3 5/1/2005: .net Framework 2.0 Installed
07:21:41.3 5/1/2005: AMD Duron, 255MB
07:21:41.3 5/1/2005: 1.6Ghz
07:21:41.3 5/1/2005: Running Randomize()
07:21:41.3 5/1/2005: Loading PlugIns
07:21:41.4 5/1/2005: Checking for applications to Launch On Startup
07:21:41.4 5/1/2005: Running Misc startup tasks
07:21:41.4 5/1/2005: Setting Menu types
07:21:41.4 5/1/2005: Opening Configuration File
07:21:41.4 5/1/2005: Getting Configuration Values
07:21:41.4 5/1/2005: Using Theme: Default - Default
07:21:41.4 5/1/2005: Checking for alternate Image Directory for Theme: Default - Default
07:21:41.4 5/1/2005: Launching HideOS.exe
07:21:41.4 5/1/2005: Initialising Video/MNG DLL's
07:21:41.4 5/1/2005: Hiding Taskbar
07:21:41.4 5/1/2005: Using Cabinet Friendly Control System
07:21:41.4 5/1/2005: Is Media Center running?
07:21:41.4 5/1/2005: Checking/Creating LCD Registry values
07:21:41.4 5/1/2005: Check Media Center Exit/Start Mode
07:21:41.4 5/1/2005: Media Center Mode 0
07:21:41.5 5/1/2005: Video previews on. Warning: Only recommended on modern systems
07:21:41.5 5/1/2005: Snap Delay set to: 2
07:21:41.5 5/1/2005: Get other settings
07:21:42.0 5/1/2005: Desktop set to Hide ICONS and set Background to Black
07:21:42.0 5/1/2005: Backing up Registry Wallpaper Settings
07:21:42.0 5/1/2005: Start work for Form
07:21:42.0 5/1/2005: Getting Original Screen Size
07:21:42.0 5/1/2005: Opening Database Connection
07:21:44.7 5/1/2005: Initializing Component
07:21:45.0 5/1/2005: Retrieving resolution setting
07:21:45.0 5/1/2005: Creating Radio Station Genres
07:21:45.6 5/1/2005: Succesfully created station genres
07:21:45.6 5/1/2005: MAME Path is: C:\MAME
07:21:45.7 5/1/2005: MAME EXE file is: mame.exe
07:21:45.8 5/1/2005: ROM Path is: C:\MAME\roms
07:21:45.8 5/1/2005: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
07:21:45.8 5/1/2005: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
07:21:45.8 5/1/2005: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
07:21:45.8 5/1/2005: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
07:21:45.8 5/1/2005: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
07:21:45.8 5/1/2005: Loading Controls.ini map file
07:21:45.9 5/1/2005: Snap Path is: C:\MAME\snap
07:21:45.9 5/1/2005: AVI Snap Path: Not Found
07:21:45.9 5/1/2005: Flyer Path is: C:\MAME\flyers
07:21:45.9 5/1/2005: Cabinet Path is: C:\MAME\cabinets
07:21:45.9 5/1/2005: Title Path is: C:\MAME\titles
07:21:45.9 5/1/2005: PCB Path: Not Found
07:21:45.9 5/1/2005: Artwork Preview Path: Not Found
07:21:45.9 5/1/2005: Panel Path: Not Found
07:21:45.9 5/1/2005: Manual Path: Not Found
07:21:45.9 5/1/2005: Icon Path is: C:\MAME\icons
07:21:45.9 5/1/2005: Marquee Path is: C:\MAME\marquees
07:21:46.0 5/1/2005: Loading Custom Emulators
07:21:46.5 5/1/2005: Using 2D Animations
07:21:46.5 5/1/2005: Using General Font: Trebuchet MS
07:21:46.5 5/1/2005: Using Title Font: Trebuchet MS
07:21:46.5 5/1/2005: Attempting to load game list
07:21:48.1 5/1/2005: Initialising DirectDraw
07:21:48.2 5/1/2005: Warning: GameEx cannot rotate the display in 32 bit colour
07:21:48.2 5/1/2005: Turning on 16 Bit Colour
07:21:48.2 5/1/2005: Warning: GameEx cannot rotate the display and wait for Vsync
07:21:48.2 5/1/2005: Turning off Vysnc and SleepWait
07:21:48.3 5/1/2005: Applying GameEx is Loading Image
07:21:48.7 5/1/2005: Creating DirectDraw Device
07:21:48.7 5/1/2005: Using Device: ATI Radeon 9550 / X1050 Series
07:21:49.2 5/1/2005: 252mb video memory available
07:21:49.8 5/1/2005: Setting Resolution to 800x600 16 bit color
07:21:51.0 5/1/2005: Creating DirectDraw Surfaces
07:21:51.0 5/1/2005: Creating Primary Surface - Full Screen Mode
07:21:51.2 5/1/2005: Creating Back Buffer
07:21:51.3 5/1/2005: Loading graphic Surfaces
07:21:51.4 5/1/2005: Display is running at: 800x600 16bit color, 60hz
07:21:51.5 5/1/2005: Creating Surfaces Misc and Dialogs
07:21:51.9 5/1/2005: Creating Surfaces Volume
07:21:51.9 5/1/2005: Creating Surfaces Arrows
07:21:52.0 5/1/2005: Creating Surfaces GameEXlogo Text
07:21:52.0 5/1/2005: Creating Surfaces Toolbar
07:21:52.1 5/1/2005: Creating Surfaces Backgrounds
07:21:52.7 5/1/2005: Creating Surfaces Toolbar Controls
07:21:52.8 5/1/2005: Creating Surfaces GameEx Logo
07:21:52.8 5/1/2005: Creating Surface Unselected
07:21:52.8 5/1/2005: Creating Surfaces Home & Exit
07:21:52.9 5/1/2005: Creating Surfaces Snaps
07:21:52.9 5/1/2005: Creating Surfaces Menu and List Bars
07:21:53.3 5/1/2005: Creating Fonts
07:21:53.3 5/1/2005: Creating Menu Font
07:21:53.4 5/1/2005: Restoring Menu Font From Cache
07:21:54.1 5/1/2005: Creating Game Font
07:21:54.3 5/1/2005: Creating Font Black
07:21:54.5 5/1/2005: Creating Font Black Small
07:21:54.7 5/1/2005: Creating Game Font Faded
07:21:54.8 5/1/2005: Creating Title Font
07:21:54.9 5/1/2005: Restoring Title Font From Cache
07:21:56.4 5/1/2005: Fonts Created Succesfully
07:21:56.4 5/1/2005: 238mb video memory left available
07:21:56.4 5/1/2005: Creating instance of global keyboard hook
07:21:56.5 5/1/2005: Text/Language: English
07:21:56.5 5/1/2005: Applying Language/Text
07:21:56.6 5/1/2005: Initialising Bass Audio Library
07:21:57.5 5/1/2005: MAME CMD options: -triplebuffer -nowindow
07:21:57.5 5/1/2005: Loading last used Game List
07:21:57.5 5/1/2005: Setting Music Volume
07:21:57.5 5/1/2005: Cannot Load Play List. Check Path and filename
07:21:57.5 5/1/2005: Creating DirectSound Device
07:21:57.5 5/1/2005: Trying: Primary Sound Driver
07:21:57.6 5/1/2005: Loading Sound Files
07:21:58.0 5/1/2005: DirectSound Device Created Successfully
07:21:58.0 5/1/2005: Creating ICONS
07:21:58.1 5/1/2005: Restoring Cached ICONS from File
07:21:59.6 5/1/2005: Initialising DirectInput for Gamepad support
07:21:59.8 5/1/2005: Unable to create a joystick device
07:21:59.9 5/1/2005: Playing intro sound file
07:21:59.9 5/1/2005: Initializing MCE Remote
07:21:59.9 5/1/2005: Initialization OK! Starting GameEx!
07:22:00.0 5/1/2005: Testing Main Loop Once: Processing Frame
07:22:01.3 5/1/2005: Testing Main Loop Once: Main Loop ran successfully
07:22:04.0 5/1/2005: 21 Consecutive Exceptions Occured
07:22:04.0 5/1/2005: Error in the application.
07:22:05.6 5/1/2005: at Microsoft.DirectX.DirectDraw.Surface.DrawFastInternal(Int32 xcoord, Int32 ycoord, Surface sourceSurface, tagRECT* srcRectangle, DrawFastFlags flags)
at Microsoft.DirectX.DirectDraw.Surface.DrawFast(Int32 xcoord, Int32 ycoord, Surface sourceSurface, Rectangle srcRectangle, DrawFastFlags flags)
at w.a(Int32 A_0, Int32 A_1, String A_2, Int32 A_3, Boolean A_4)
at w.l(Boolean A_0)
at w.at()
07:22:05.6 5/1/2005: Trying reinitialising the display after sleeping for 4 seconds
07:22:05.6 5/1/2005: Exception count will be dropped to 15
07:22:09.9 5/1/2005: Warning: GameEx cannot rotate the display in 32 bit colour
07:22:09.9 5/1/2005: Turning on 16 Bit Colour
07:22:09.9 5/1/2005: Warning: GameEx cannot rotate the display and wait for Vsync
07:22:09.9 5/1/2005: Turning off Vysnc and SleepWait
07:22:10.6 5/1/2005: Cannot Set Resolution to: 802x602 16 bit color
07:22:10.6 5/1/2005: Error in the application.
07:23:00.3 5/1/2005: --**--
07:23:00.3 5/1/2005: 21 Consecutive Exceptions Occured: Exiting
07:23:00.3 5/1/2005: Closing database connection
07:23:00.4 5/1/2005: First Exception:
07:23:00.4 5/1/2005: Error in the application.
07:23:00.4 5/1/2005: at Microsoft.DirectX.DirectDraw.Surface.DrawFastInternal(Int32 xcoord, Int32 ycoord, Surface sourceSurface, tagRECT* srcRectangle, DrawFastFlags flags)
07:23:00.4 5/1/2005: at Microsoft.DirectX.DirectDraw.Surface.DrawFast(Int32 xcoord, Int32 ycoord, Surface sourceSurface, Rectangle srcRectangle, DrawFastFlags flags)
07:23:00.4 5/1/2005: at w.a(Int32 A_0, Int32 A_1, String A_2, Int32 A_3, Boolean A_4)
07:23:00.4 5/1/2005: at w.l(Boolean A_0)
07:23:00.4 5/1/2005: at w.at()
07:23:00.4 5/1/2005: It was detected you experienced a DirectX error.
07:23:00.4 5/1/2005: Please note the following for possible solutions to your problem:
07:23:00.4 5/1/2005: 1. Ensure you have the latest version of DirectX installed.
07:23:00.4 5/1/2005: 2. Ensure you have the latest Manufacturer provided video card drivers.
07:23:00.4 5/1/2005: NOTE: Windows/Microsoft Update does not contain the latest.
07:23:00.4 5/1/2005: NOTE: Manufacturer normally means ATI, NVidia, or Intel. Not the brand.
07:23:00.4 5/1/2005: www.ati.com www.nvidia.com
07:23:00.4 5/1/2005: 3. If you do not have a modern video card try the following. 1. Turn off advanced Graphics. 2. Try a lower resolution. 3. Try turning on and using 16-bit colour
07:23:00.4 5/1/2005: 4. Ensure any required video codecs are installed.
07:23:00.4 5/1/2005: 5. Try a different theme, or try running the theme at the resolution it was designed for
07:23:00.4 5/1/2005: Last Exception:
07:23:02.6 5/1/2005: Exiting GameEx!
07:23:02.6 5/1/2005: Saving Settings
07:23:04.3 5/1/2005: Disposing Plugins
07:23:04.3 5/1/2005: Checking for applications to Launch On Exit
one other thing I forgot to add is the mouse pointer does not line up with the buttons right. if you look at the image in my last post you can see where the pointer is 2 lines below the last button highlighted, if I point it at the top button on the list it lines up the right way.
ourgrace
ourgrace
Error log
change to 800 x 600
And just out of curiousity does it do the same off centering in landscape mode?
Hey Brian,
I don't know where the 802x602 comes from, and in landscape it works just fine.
I am thinking it might be something related to the setting in - Advance cofig - Display Settings - Rotate Display. I know when you select Rotate Display GameEx makes other changes. Such as setting game list to vertical games only.
ourgrace
Hey Brian,
ourgrace
Well does your videocard drivers come with rotating software? Id be tempted to try those and see if the centering problem persists. Also is your monitor a TRUE vertical monitor? eg.. 800x600 really needs to be 600x800?
Anyways if the above works id be tempted to just use those and manualy go into the gameex config and tell it to only show vertical games..
Can you provide more info about your hardware?
Hey Tom
Yes I did, it didn't make any differance.
Brian,
I don't think it is with the video card, I have tried with a old MX 440, a 128 meg ATI 5700 and the 256 meg ati 9550. It is the same problem with all three. I have also tried two differnt pc monitors and a flat panel. I'll try to have the video card do the rotation and see what happens, I think the last time I tried that it seemed to slow down alot, anyway I'll let you know what happens.
ourgrace
