Hi
i seem to have lost the box and cartridge art of the infomation page on all my emulators and cant seem to find out whats changed
will changing to the new databases have effected this as its the only thing i can think that i have changed. The paths to the art is the same and i ahve double checked it
i must have changed something but cant figure out what :blink:
  Michael said:
Hi
Have you tried changing themes?
  Michael said:
no but il give it a try :lol:
Honestly I'm not sure that will work... When you use the DB's does it change the file name via like a MAP file.... That could be the reason... I haven't checked out the new db's.... Yet..
il try changing an emulator back to the old database and see if it puts the pictues back
if my roms arnt good sets would this be likely to effect the pictues not showing up.
:blink: im just confusing my self now :blink:
although the roms apear to have the right game infomation so id say the database works fine.
Try turning on/off the feature that finds similar matches to the names. I forgot exactly what its called. But I had the same problem and even though my snaps have the same name I had to turn on the search for best match feature.
The databases should have nothing to do with snaps.
your right seems to have sorted it. :lol: im gona put it down to to much junk on the hard drive its nearly full now
its under tweaks / Performance (snap best match)
Thanks Guy you done it again :D
