30th July 2005
- GameEx 4.70
  • Modified all themes to work
    with VMWare, Virtual PC, and older graphics cards.
    If GamEx ended when creating surfaces and you weren't
    using the default theme this release should fix
    that.
  • Better SlikStik, X-Arcade and
    Gamepad support.
    • Ability to exit all
      emulators and applications with these devices
      (always on for MAME and Zinc. Use the MapKeys
      setting for emulators and apps).
    • Ability to not exit
      attract mode with a Gamepad.
    • See the docs page for
      controls
    [*]Kills VPAuto.exe process when
    running Visual Pinball. The MapKeys setting works
    fine for me with the latest version of Visual
    Pinball.
Kills VPAuto.exe process when running Visual Pinball. The MapKeys setting works fine for me with the latest version of Visual Pinball.
One thing you might consider is having LaunchAfter run even if you kill an application. Then you could just put taskkill /im vpauto.exe (or maybe a BAT file that does whatever other "cleanup" is necessary like dismounting a CD image or killing off additional helper applications) in GameEx.ini.
Thanks Rob, good idea, Ill do that.
ok i understand know why it didnt work but i still cant get it to work because
on my control setteings it says that button A is button 1 but in gameex button A is button 2 and B is button 4 but in setteings it is button 2 how do i find out what button is number 6
how do i find out what button ,5,6 so i can use that to exit game
In Windows - go into Control Panel, Select Game Controllers, Select your controller, select properties. See which buttons are what.
Cheers
Rob, it should still actually run launchafter. Is it not working?
Hmm, you're right, looks like it's working now. It definitely didn't when I tried to use it that way some weeks back. Nice, that opens a lot of possibilities. :)
-- Rob
i found out what the buttons are but it still doesnt exit the game
with enable custom keys they keys i have to push are start+back+B and left-up that didnt work so i turned off custominput and the keys are now Y+black+white left-up and this doesnt woth to
Yes, it was not working right unless GameEx was showing in a window. Its fixed in 4.72 which I just uploaded. Go try it!
