First off, GameEx is a beautiful, full featured program and it is my first choice for a MAME32 front end, I just can't get it to run correctly!
Specs:
AMD 2800+ processor
512 MB ram
Integrated video, 64MB shared
MAME32 v.98
latest GameEx
Wells Gardner D9200 monitor running at 640x480, 31.5 Khz
Ok, here is the situation.
I have MAME32 configured and running, no problems on both a regular PC monitor and the Arcade monitor. The games are fast, sized correctly, everything, no problems.
I use GameEx to load the MAME32.exe (as a front end) and the games are about half speed, and the music skips. All other aspects of GameEx are operating correctly. To be more specific, when a game is loaded and the intro screen appears, the video is smooth, but a bit slower than it should be. The music skips, like it is repeating every half second. I don't know if the music is repeating to keep up with the slow video, but it seems like that is what is happening. Anyway, in game, this problem continues.
I am pretty skilled with computers and understand what changing config options in Mame and GameEx will do. Let me just say that I have tried EVERYTHING to fix the speed problems.
I have tried:
-running the arcade monitor at 800x600, 640x480, 32 bit, 16 bit
-throttling back on the hardware acceleration in windows
-turning VSYNC off along with the Reduce CPU Utilization itea from the FAQ
-running in arcade mode
-turning off direct draw (crash of course), turning on direct 3D
-I have tried all the different configuration settings in MAME32 including the audio option for downsampling thinking that it was robbing CPU cycles.
-I have tried every combination of these options. I did read and utilize the FAQ to no avail so I moved into brute force method of figuring out this problem!
What I did learn:
-MAME32 works fine by itself on a regular PC monitor and the arcade monitor.
-Advance Menu works fine with MAME32 on a regular PC monitor and the arcade monitor.
-MAMEWAH works fine with MAME32 on a regular PC monitor and the arcade monitor.
-It is not a CPU problem, MAME32 by itself pegs out the CPU but runs fine
-I don't believe that I need the ArcadeVGA card from Ultimac to run the Wells-Gardner D9200. I could be wrong. Please let me know will all details please. I am using a SlikStik classic and would have to build a custom cable to make the ArcadeVGA work with this monitor. Argh.
Please Help!
Thank You,
Jeff
Specs:
AMD 2800+ processor
512 MB ram
MAME32 v.98
latest GameEx
I have tried:
What I did learn:
Please Help!
Thank You,
Jeff
Ok, to help troubleshoot.
After running a MAME32 game from GameEx that has slowdown, close GameEx, and Select Run Last Game from the GameEx program group.
This will identify if the issue is GameEx or MAME32.
Tom.
Specs:
AMD 2800+ processor
512 MB ram
MAME32 v.98
latest GameEx
I have tried:
What I did learn:
Please Help!
Thank You,
Jeff
Jeff, Could you please provide the GameEx Log.
Thanks for the quick reply.
I did what you wrote and had the same problem, but I have since had and epiphany and figured out the problem.
My mame machine is a shuttle SK43G, and while it is a great computer, the integrated graphics suck!
I moved all of my mame file over to another shuttle that I have (main gaming machine) that has an ATI X700 PCIE card in it, intalled GameEx and launched it. Everything runs great, no problems at all.
I am headed to Fry's to pick up a mid range AGP card for the shuttle!
Jeff
Log from integrated graphics computer: You will notice I have the ArcadeVGA turned on. This was the only way I could get Galaga to load, it must be related to the poor onboard graphics. I did not have to use this setting when I got it working with the ATI x700 card in another machine.
16:38:30.8 7/29/2005: GameEx: Version 4.61: Starting Log
16:38:30.8 7/29/2005: Operating System Platform: Win32NT
16:38:30.8 7/29/2005: Operating System Name: Windows XP
16:38:30.8 7/29/2005: Operating System Version: 5.1.2600
16:38:30.8 7/29/2005: Running Randomize()
16:38:30.8 7/29/2005: Running Misc startup tasks
16:38:30.8 7/29/2005: Hiding Cursor
16:38:30.8 7/29/2005: Setting Menu types
16:38:30.8 7/29/2005: Opening Configuration File
16:38:30.8 7/29/2005: Getting Configuration Values
16:38:30.8 7/29/2005: Using Theme: Default - GameEx
16:38:30.8 7/29/2005: Checking for alternate Image Directory for Theme: Default - GameEx
16:38:30.8 7/29/2005: Text/Language: English
16:38:30.8 7/29/2005: Applying Language/Text
16:38:30.8 7/29/2005: Snap Delay set to: 6
16:38:30.8 7/29/2005: Is Media Center running?
16:38:30.9 7/29/2005: Check Media Center Exit/Start Mode
16:38:30.9 7/29/2005: Media Center Mode 2
16:38:30.9 7/29/2005: Checking for applications to Launch On Startup
16:38:30.9 7/29/2005: Get other settings
16:38:30.9 7/29/2005: SlikStik support enabled
16:38:30.9 7/29/2005: Using DirectInput for keyboard input
16:38:30.9 7/29/2005: Launching HideOS.exe
16:38:31.3 7/29/2005: Hiding Taskbar
16:38:31.3 7/29/2005: Start work for Form
16:38:31.3 7/29/2005: Getting Original Screen Size
16:38:31.3 7/29/2005: Loading ICON
16:38:31.4 7/29/2005: Initializing Component
16:38:31.4 7/29/2005: Using General Font: HandelGothic BT
16:38:31.5 7/29/2005: Using Title Font: HandelGothic BT
16:38:31.5 7/29/2005: Initialising DirectDraw
16:38:31.5 7/29/2005: Applying GameEx is Loading Image
16:38:31.5 7/29/2005: Creating DirectDraw Device
16:38:31.5 7/29/2005: Using Device: VIA/S3G KM400/KN400
16:38:31.5 7/29/2005: Setting Resolution to 800x600 16 bit color
16:38:31.5 7/29/2005: Creating DirectDraw Surfaces
16:38:31.5 7/29/2005: Creating Primary Surface - Full Screen Mode
16:38:31.6 7/29/2005: Creating Back Buffer
16:38:31.6 7/29/2005: Loading graphic surfaces
16:38:32.0 7/29/2005: Creating Fonts
16:38:32.0 7/29/2005: Creating Menu Font
16:38:32.5 7/29/2005: Creating Game Font
16:38:32.8 7/29/2005: Creating Menu Font Standard Size
16:38:33.2 7/29/2005: Creating Font Black
16:38:33.3 7/29/2005: Creating Font Black Small
16:38:33.3 7/29/2005: Creating Game Font Faded
16:38:33.7 7/29/2005: Creating Title Font
16:38:34.4 7/29/2005: Initialising Windows Media Player Component
16:38:34.5 7/29/2005: MAME Path is: C:\Emulation\Mame32v.98\Mame32
16:38:34.5 7/29/2005: MAME EXE file is: mame32.exe
16:38:34.5 7/29/2005: ROM Path is: C:\Emulation\Mame32v.98\Mame32\roms
16:38:34.5 7/29/2005: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
16:38:34.5 7/29/2005: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
16:38:34.5 7/29/2005: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
16:38:34.5 7/29/2005: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
16:38:34.5 7/29/2005: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
16:38:34.5 7/29/2005: Loading Controls.ini map file
16:38:34.5 7/29/2005: Loading Custom Emulators
16:38:35.0 7/29/2005: Snap Path is: C:\Emulation\Mame32v.98\Mame32\snap
16:38:35.0 7/29/2005: AVI Snap Path is: C:\Emulation\Mame32v.98\Mame32\snap
16:38:35.0 7/29/2005: Flyer Path is: C:\Emulation\Mame32v.98\Mame32\flyers
16:38:35.0 7/29/2005: Cabinet Path is: C:\Emulation\Mame32v.98\Mame32\cabinets
16:38:35.0 7/29/2005: Title Path is: C:\Emulation\Mame32v.98\Mame32\titles
16:38:35.0 7/29/2005: Panel Path is: C:\Emulation\Mame32v.98\Mame32\cpanel
16:38:35.0 7/29/2005: Icon Path is: C:\Emulation\Mame32v.98\Mame32\icons
16:38:35.0 7/29/2005: Marquee Path is: C:\Emulation\Mame32v.98\Mame32\marquees
16:38:35.0 7/29/2005: Using Ultimarc AradeVGA
16:38:35.0 7/29/2005: MAME CMD options: -skip_disclaimer -skip_gameinfo -triplebuffer -nowindow -joy
16:38:35.0 7/29/2005: Attempting to load game list
16:38:35.2 7/29/2005: Running: mame32.exe -help
16:38:35.3 7/29/2005: Running: C: C:\Emulation\Mame32v.98\Mame32\mame32.exe -help > C:\Emulation\Mame32v.98\Mame32\help.txt
16:38:35.6 7/29/2005:
16:38:35.6 7/29/2005: Now Outputing mame32.exe - Help
16:38:35.6 7/29/2005: --BEGIN--
16:38:35.6 7/29/2005: M.A.M.E. v0.98 (Jul 10 2005) - Multiple Arcade Machine Emulator
16:38:35.6 7/29/2005: Copyright © 1997-2005 by Nicola Salmoria and the MAME Team
16:38:35.6 7/29/2005: MAME is an emulator: it reproduces, more or less faithfully, the behaviour of
16:38:35.6 7/29/2005: several arcade machines. But hardware is useless without software, so an image
16:38:35.6 7/29/2005: of the ROMs which run on that hardware is required. Such ROMs, like any other
16:38:35.6 7/29/2005: commercial software, are copyrighted material and it is therefore illegal to
16:38:35.6 7/29/2005: use them if you don't own the original arcade machine. Needless to say, ROMs
16:38:35.6 7/29/2005: are not distributed together with MAME. Distribution of MAME together with ROM
16:38:35.6 7/29/2005: images is a violation of copyright law and should be promptly reported to the
16:38:35.6 7/29/2005: authors so that appropriate legal action can be taken.
16:38:35.6 7/29/2005: Usage: MAME gamename [options]
16:38:35.7 7/29/2005: MAME -list for a brief list of supported games
16:38:35.7 7/29/2005: MAME -listfull for a full list of supported games
16:38:35.7 7/29/2005: MAME -showusage for a brief list of options
16:38:35.7 7/29/2005: MAME -showconfig for a list of configuration options
16:38:35.7 7/29/2005: MAME -createconfig to create a mame.ini
16:38:35.7 7/29/2005: For usage instructions, please consult the file windows.txt
16:38:35.7 7/29/2005: --END--
16:38:35.7 7/29/2005: Loading last used Game List
16:38:36.1 7/29/2005: Initialising Bass Audio Library
16:38:36.4 7/29/2005: Creating DirectSound Device
16:38:36.4 7/29/2005: Trying: Primary Sound Driver
16:38:36.4 7/29/2005: Loading Sound Files
16:38:36.4 7/29/2005: DirectSound Device Created Successfully
16:38:36.4 7/29/2005: Creating ICONS
16:38:37.0 7/29/2005: Gamepad/Joystick disabled
16:38:37.0 7/29/2005: Initialising DirectInput for Keyboard support
16:38:37.1 7/29/2005: Playing Startup Video
16:38:37.1 7/29/2005: Playing intro sound file
16:38:37.1 7/29/2005: Initialization OK! Starting GameEx!
16:38:37.1 7/29/2005: Testing Main Loop Once: Processing Frame
16:38:37.1 7/29/2005: Testing Main Loop Once: Getting Tick count
16:38:37.3 7/29/2005: Testing Main Loop Once: Checking for song change
16:38:37.3 7/29/2005: Testing Main Loop Once: Checking Keyboard for Input
16:38:37.3 7/29/2005: Testing Main Loop Once: Front buffer exists?
16:38:37.3 7/29/2005: Testing Main Loop Once: Surfaces need restore?
16:38:37.3 7/29/2005: Testing Main Loop Once: Checking Joystick for input
16:38:37.3 7/29/2005: Testing Main Loop Once: Drawing Background
16:38:37.3 7/29/2005: Testing Main Loop Once: Drawing Logo
16:38:37.4 7/29/2005: Testing Main Loop Once: Flipping Surfaces
16:38:37.4 7/29/2005: Testing Main Loop Once: Main Loop ran successfully
16:39:16.7 7/29/2005: 224-288-V-True-640-288
16:39:16.7 7/29/2005: Running: cmd.exe /c C: C:\Emulation\Mame32v.98\Mame32\mame32.exe galaga -rompath C:\Emulation\Mame32v.98\Mame32\roms -skip_disclaimer -skip_gameinfo -triplebuffer -nowindow -joy -resolution 352x256 -hwstretch -effect sharp
16:41:21.2 7/29/2005: Exiting GameEx!
16:41:21.2 7/29/2005: Saving Settings
16:41:21.4 7/29/2005: Writing Game List to disk
16:41:23.7 7/29/2005: Checking for applications to Launch On Exit
16:41:23.7 7/29/2005: Media Center was not open when starting GameEx, so not launching
I think if you turn off the -triplebuffer in the MAME CMD line options (in gameex) your onboard gfx will work.
Also go get the latest version of GameEx theres been a ton of speed improvements since version 4.61
I updated and turned off the -triplebuffer and it is working smoothly again.
Thanks for the support, I really appreciate it.
One last question, is the -triplebuffer removal, or the lack of a better AGP card hurting the visual clarity of the games? I would still consider getting a card if it would improve the visuals. As it stands, the games and gameEx look great, I don't think that any clarity is diminished, but can't me sure without a side by side comparison.
Jeff
P.S. I am off to the donate page!
Jeff
Hey Jeff,
It does not affect the clarity, but without it sometimes you get what is known as a tearing affect. This is where MAME is drawing to the screen when your physical display is updating the screen itself, therefore one frame is being drawn while its still displaying another. Its mostly noticable in vertical scrolling games.
It basically makes scrolling games a bit smoother.
Taken from MAME help file:
Enables or disables "triple buffering". Normally, MAME just draws
directly to the screen, without any fancy buffering. But with this
option enabled, MAME creates three buffers to draw to, and cycles
between them in order. It attempts to keep things flowing such that one
buffer is currently displayed, the second buffer is waiting to be
displayed, and the third buffer is being drawn to. Unfortunately, due
to some DirectDraw issues, this doesn't always work out as well as it
should. This is still being investigated. The default is OFF
(-notriplebuffer). This option required -ddraw and -nowindow.
