Hi guy,
i have problem launching NullDC with Xpadder.
I'm using the last GameEx available in a WindowsXP SP2 machine.
NullDC work very well ( stand alone )
GameEx work very well in MAME, i'm using the new UltraStick plug ins ( thanks for it :) )
Xpadder work very well ( stand Alone ).
If i run Xpadder and then nullDC both work very well toghether.....
If i lunch Xpadder outside Gameex, and then start NullDC inside Gameex it work well.
Until now i cant run Xpadder with a specific configuration inside Gameex, i try to put a string like $PATH/Xpadder.exe /M where $PATH is extended path in the run before and then put $PATH/Xpadder.exe /C in the run after, but when i start NullDC in Gameex it start Xpadder and whait something if i kill xpadder manualy the control retun to Gameex.
I cant start end end Xpadder inside GameEX :(
I find out many thread abaut it but i cant solve my problem.
I'm using nullDC with NullDC_Loader.exe
Thanks for support.
Please reply me general speacking, i wont to use also Xpadder with some different config for DAPHNE and other emus.
  Loris Cortina said:
Hi guy,
Thanks for support.
Well.. Save your xpaddre config... The file extention is really long like *.xpadderconfig ...
Anyways make sure when you double click it it opens xpadder along with the config... If it works... configure the launch before and put the path along with the full file name... eg c:\configs\nulldc.xpadderconfig
That will launch your xpadder config before nulldc.
In the launch after you can configure it to be
TSKILL.exe xpadder.exe
That will kill the xpadder process.
Thats all folks
Thats all folks
My xpadder config is called nulldc.xpadderprofile, if i duoble click it it open and work!
Also TSKILL work: TSKILL xpadder
I add:
c:\PATH\xpadder\nulldc.xpadderprofile in start before
tskill xpadder in start after
When i run a game in NullDC menu it block before starting the emulator :(
Where i can find some debug istruction?
I add:
try using
Launch dont wait
